Question about Whirlpool 24 in. GU1200XT Built-in Dishwasher
GU1200xtks0 Blinking Lights
One night it worked and the next morning it didn't. First the Rinse Only light was flashing. I tried disconnecting the power source and allow the machine to reset as instructed by the Whirlpool customer support. Now the RINSE ONLY and the CHINA CRYSTAL lights blink continuously. How do I properly reset the machine to allow it to function again?
  • 38 Answers
Try pressing heated dry, normal, heated dry, normal keys within 6 seconds. All lights should come on and the machine should enter diagnostic mode. If this does not work remove the 2 screws that hold the toe panel on at the bottom front of the dishwasher, attached inside you will find a tech sheet that tells you how to enter the diagnostic mode. Once you get it in diagnostic mode let it do it's thing, will take about 20 minutes total. At the end the control will be reset. If the fault comes back then troubleshoot according to the tech sheet, or call for service.
Posted on Feb 20, 2009
Why is heated dry blinking?
FIXED Kenmore dishwasher lights flashing: "Hi Temp" & "Heat Dry ...
www.applianceblog.com/.../40588-Kenmore-dishwasher-lights-flashing-...
Aug 26, 2013 - 10 posts - ‎3 authors
Thread: Kenmore dishwasher lights flashing: "Hi Temp" & "Heat Dry" ... A few months ago, we had a brief power outage and the next morning, noticed the "Hi Temp" and "Heat Dry" lights were flashing. ... Well since then, the dishwasher intermittently stops mid-cycle and these same lights ... Thread: GE Eterna QuietPower 2 Normal and Heated Dry ...
Feb 24, 2012
Kenmore Elist 665 dishwasher Smart Wash red light ...
Dec 23, 2011
Heated dry blinking +17 times - ApplianceBlog
Nov 14, 2010
Heated Dry light blinking
Nov 7, 2010
More results from www.applianceblog.com
Why won't my dishwasher start and why does the "Heated Dry"
www.shopyourway.com > Manage My Life > Questions
Nov 16, 2009 - When I hold down the Heated Dry button to turn the control lock on it ...my dishwasher start and why does the "Heated Dry" light keep blinking ...
Dec 01, 2015 | Dishwashers
1998 Ford Explorer XLT. Back about a decade ago, parked this SUV in a huge puddle of water in Florida, that night there was an electrical storm. Next morning cranked the SUV up and the lights weren't
There should be two fuzes behide the radio. One is for the radio and the other is for the lighting display. check the lighting display fuze.
Mar 10, 2013 | iPhone Apps
Blinking "Normal" light on a Maytag model
Hi
Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry, Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel.
Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad.
Hope this helps... Please post back if you need more information.
Daniel
May 19, 2011 | Maytag Dishwasher
Vsc and check engine lights keep coming on can reset but keep coming back on
Disconnect the battery over night then hook up the next morning and it will reset it. This was the problem I had and it works.
Jan 23, 2011 | 1998 Lexus LS 400
I have an HP Officejet 6300 all in one. The printer will disconnect and connect all on its own. I can have just printed something and try to print a second page and it will have disconnected. However, it...
Try resetting the printer using following steps:
1. When your printer is on, unplug the wire that goes to the computer.
2. Presee and release (#) and (*) buttons.
ou will see your display say "Support Menu"
3. Scrolls to the right until you see "resets" and pess ok
4. Select "semi-full reset" and hit OK
5. After printer turns off, turn it back on 30 seconds later.
Jun 01, 2017 | HP OfficeJet 6210 All-In-One InkJet...
Good-day! I have a 1991 honda civic. My wife unpluged the block heater for the night, so, it didn`t start in the morning. I repluged it in, took out the battery for the the next night to warm it...
#1 lights inside car mean squat they are very low draw how about radio heater headlights...and trying your ignition...I suggest you clean your battery teminal after fully charging your battery and make sure the terminals are nice and tight and then try starting your car w/out turning anything else on if it starts you have solved it if you drive it and it dies then you are just using juice in battery have alternator and battery lode tested at a reputable garage most will do for free on hopes of selling you what you need if they are ok then cherck your starter good luck
Dec 20, 2009 | 1991 Honda Civic
THe Dishwasher just keeps Washing And Rinesing
Turned Fridgidaire washer on last night before going to bed; this morning, it's running (at least making sounds) but did not wash; 4000 Series Frigidaire; display says Washing Drying Er Clean S; and two lights are flashing - Ultimate Scrub and Rinse only.
I tried turning off the breaker and restarting the machine but that doesn't work.
Sep 05, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Blinking lights on Front Panel
I've finally tracked down the manual and it the fault code is as follows
"Indicates a fault in the heater or in the thermistor"
You can go into a fault tracing mode by pushing the "Rinse Hold" button five times within 15 seconds. The first, third, fifth and seventh lights will flash when in this mode and you can test the following parts by pressing the corresponding button. I'm going to try the heater test below and assume that if that works the fault must be with the Thermistor. The other tests could be useful for other faults.
User manual found here
Rinse Hold - tests detergent solenoid, detergent flaps open after about 60sec
Pots & Pans - tests Rinse Aid Solenoid, rinse aid will flow down door
Normal Wash - tests water inlet valve, water can be heard entering
Light Wash - tests ventilator solenoid, there will be a click followed by a rattling noise
Quick Wash - tests the heater, the element heats up, WARNING don’t touch element HOT
Temp - tests circulation pump, the pump starts
Dry - test outlet pump, the pump starts
Manual says to push 55 and 65 degree button to exit, I have no idea where those are so will probably just switch off at wall to reset.
Hope this helps someone. I rang ASKO and they said they didn’t know what the fault code meant so either they can’t read or their service sucks, probably a bit of both!
Feb 12, 2009 | Asko D1716 Built-in Dishwasher
Whirlpool 24 in. GU1200XT Built-in Dishwasher Logo
548 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
