Question about Creo Computers & Internet
Have a creo power pro 500 problem with board fusion IK error
The power pro 500 creo print controller connects to Ikon (Konica Color Printer) when connected will not print ( thru scuzzi cable) does not see printer
Error when booting up when installing drivers is: Fusion IK error reboot
In the CPU is this Creo made Fusion IK board
Can you find the problem and repair or exchange for good board?
SOURCE: Printer does not print. Error message:-
Printer was replaced
Posted on Jun 03, 2008
  • 86 Answers
SOURCE: microsoft outlook error
these threads help you in identifying your problem..
http://forums.msexchange.org/m_1800444455/mpage_1/key_/tm.htm#1800503805
http://www.experts-exchange.com/Networking/Email_Groupware/Exchange_Server/Q_21520561.html
Posted on Jul 09, 2009
inadeem
  • 38 Answers
SOURCE: I get error 5100 when trying to print. I have
5100 is a Carriage Home Position Error.
try cleaning the plastic strip that runs the length of the carriage, it may be contaminated.
Use alcohol and a swab.
Posted on Jul 11, 2009
  • 3741 Answers
SOURCE: Cant print Xerox Docucolor 240 with Creo CX250
its the problem of connecting cable.and other error 212 is for internal circuit board error.you will have to contact xerox service center and get the resetter for this online.or if its board problem you will have to order the parts.
http://www.office.xerox.com/multifunction-printer/color-multifunction/docucolor-240-250/sprt-enus.html
click the link directly and check out your areas service center or the nearest to your area.
thanks.
Please do rate the solution. Thank you for using fixya.keep updated. thanks.
Posted on Jul 19, 2009
firecontrol7
  • 6674 Answers
SOURCE: Creo Rip with Konica 6500 printer ''cable no connected error''
System Code issue For a bizhub PRO C6500/C5500 with the Creo? controller, install version 2.0 system code on the controller ( IC-304 ). Install the patch fileif still using version 1.0. Note : The latest version firmware or system software is available via the Konica Minolta Download Selector. There is several CERO firmware updates and solutions at The KonicaMinolta web site for service techinicians. Mite want to let a Service Technician check these solutions for you machine only a certified techncian can acess these solutions
Posted on Aug 09, 2009
Error code c0101 - Konica Minolta Bizhub Pro C6500 Color Copier Color Printer
Printer control board (PRCB) or Paper feed motor (M41) is bad hope its the motor board will be expensive!!!!!!! check behind the draws paper stuck!!!!! also pull out each draw find if thats the problem
Sep 25, 2017 | Konica Minolta Office Equipment & Supplies
What is the solution to 59.51 error on HP 500 color LaserJet printer.
59 error refers to a Printer motor Error.
59.51 however should not appear on screen.
59.5 is a "Print Cartriddge motor Startup error". The last character should be a letter for which Toner (ie. C, M, Y or K). However I would suggest that the 1 would be the Black motor (seeing as it is the top one). Considering you have replaced the DC controller recently I would say the most likely cause is you have either misconnected or not connected a cable. recheck all your DC controller connections and pay particular attention to connectors J1013 (Cyan Motor), J1031 (Magenta Motor), J1032 (Yellow Motor) and J1033 (Black Motor).
OR
1. Check the cyan cartridge for broken pieces and make sure the drum spins. if so, replace the cyan cartridge
2. Check that connections on the cyan print-cartridge drive motor and on the driver PCA are seated correctly.
3. Replace the cyan print-cartridge drive motor.
4.If error persists, Replace the driver PCA.
5. Replace the main drive assembly.
Dec 06, 2016 | HP DESIGNJET 500 InkJet Plotter Printer
Konica minolta 6501 error code c-c101
had a circuit board replaced recently??? if so check each and ever connection, pull each connection and reseat each connection one at a time while each connector is removed check all pins for a bent pin. Or replace the Print control board, Interface control board, image control board, and the overall control board, $$$$$$$$$$$$$$$$$$$$$$$$$ more then what you paid for the machine!!!! Then you will still have to remove each connection and reseat them and look for bent pins!!!!!
Jul 03, 2014 | Konica Minolta Bizhub C 6501 Color...
Error f56-1
Nancy,
,Check all of the connections on the printer control board first if no problem with bent pins or not properly seated connector need a new printer control board going to be tough to get you have legacy Konica machine
Mar 31, 2014 | Konica Minolta Bizhub C364 Color Copier /...
IC 601 controller is connected to my konica minolta bizhub C6000 printer but display is showing controller is not connected
check the cable between the print controller/firey and the copier, also is the print controller/firey set up for a c6000
Feb 07, 2014 | Konica Minolta Office Equipment & Supplies
Error code C-2704 mean on C6500 Bizhub Pro
Abnormality in the black charging unit.
Possible causes:
Black charging unit
HV Unit
Print Control Board
My best guess is that you have a faulty charge unit. Try swapping the units around with another colour and see if the fault code shifts.
Dec 30, 2013 | Konica Minolta Bizhub Pro C6500 Color...
Error code c0101
konica monalta c70hc error code c0101
Sep 01, 2013 | Konica Minolta Bizhub Pro C6500 Color...
Computers & Internet Logo
297 people viewed this question
Top Creo Computers & Internet Experts
David Payne
David Payne
Are you a Creo Computer and Internet Expert? Answer questions, earn points and help others
