Question about HP GX613AA Pavilion A6300F Desktop PC
Cd rom drive door
When I open the cd rom the door opens......then when I close the cd rom drive the door stays open. Is there a spring or something that's missing?? How can I repair the doors?
  • karthick_sri May 11, 2010
    u can change the belt which is responsible for the door close or open
  • Mike Davidson
    Mike Davidson May 11, 2010
    It sounds like the lip is broken.
    Is the computer still under a warranty? if so, it may be covered.
    if not, its far cheaper to just go to a place like www.newegg.com and get a new one or Best Buy.
    Please let me know asap.
    Mastersage................................................
    Problem Solver:
  • 7 Answers
Best guess is that a small plastic catch broke. My cousin has similar doors on his CD trays. I personally would take the doors off. As far as repair, again best guess without seeing it, is that you'll need a new door panel.
Posted on Feb 23, 2009
Cd rom drive door will not stay closed. i close it and then seconds later its back open again.
There's a little piece of plastic or metal that's connected to a sprin which clicks into place when you close the dvd drive and keeps it closed. Either the spring or the plastics is stuck or broken. They're very easy to replace and used ones don't cost much
Jan 15, 2011 | HP Pavilion G60-235DX notebook
CD drive stays open
Dirty lense? Best to get a new one. It maybe the motor aswell. CD drives are normally about £10
Jul 14, 2009 | Samsung (SC-152) Internal 52x CD-ROM Drive
My laptop (Samsung R60plus) DVD drive door stays open while powered on, but remains closed while shutdown. D OS recognises it, i can play cd and install programs while holding d door. Pls what can i do to...
The problem is the micro switch that opens the door is allways on.... try press it 10 or 20 times to unlock the switch or try to clean it.... It will work for sure.
Jul 07, 2009 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
DVD Drive door stays open
>One solution is to TAKE A SMALL PIN AND RESET YOUR DRIVE BY POKING THE PIN INTO THE HOLE BELOW THE DOOR..
If this doesnt solve....
You need to necessarily replace the drive..
Jul 07, 2009 | Samsung SC 152 Internal 52x CD-ROM Drive
SGI O2 CD-ROM drive tray repeatedly opens
I am having the same problem. I haven't resolved it entirely, but at least I managed to get it working again by the following steps.
First, disassemble the part of the computer chassis around the CD-ROM drive. Follow the instructions for "replacing the CD-ROM drive" in the SGI 02 hardware maintenance manual. It can be done in 10 minutes with a screwdriver.
After you have gained access to the CD-ROM drive itself, take off the top metal cover. Then you will be able to see the tray and the white gears underneath.
In my case, the problem seems to be caused by some misalignment between some wire springs and the white gears. Note when the CD tray closes, the manual eject button (a black plastic rod on the right) should stick out, and the white piece of plastic with a triangular end on the left should push against the front of the CD tray.
Somehow, the gears failed to push the white plastic piece all the way to the edge of the tray, and the CD-ROM drive thinks the tray wasn't fully-closed, and ejects the disc.
To force the drive to read the disc, pull the white plastic piece on the left with the triangular end towards the edge of the tray. (Pull it towards you if you are facing the front of the drive.) You might need to use some force, but I can get the drive to work this way, even though it still "sticks open" half the time.
Good luck, and if you happen to find a better solution, I look forward to hearing it.
Jan 07, 2009 | SGI Silicon Graphics (P-CDR32-EXT) CD-ROM...
CD ROM
If the drive door sticks after you have used the paper clip to open it, look under the tray at the drive teeth (if any). Apply a liberalm coating of general purpose grease to the rwo inches of teeth at the end of the drive tray nearest you and close the drive door again. Open and close a few times to see if the door is now free. This worked for me on my Dell Inspiron 3100. Try it.
Jun 24, 2008 | Dell Computers & Internet
CD Rom
Well...first lets make sure the drive still can physically open.
http://i36.photobucket.com/albums/e40/freddyhard/CD13.jpg
There in the picture will show you where the manual eject button is. Use a paperclip and push the button in the hole. Once the drive is open enough for you to pull the tray, go ahead and pull it as far as it will come out. It will stop, and it shouldn't come all they way unattached from the rest of the unit.
Go ahead and take any cd or dvds that was in the drive out and turn your computer back on.
Once into windows, push the regular eject button and the drive should close the door itself. Let it sit for a second or two, and try hitting the eject button again. 9 times out of 10, that usually fixes my drives.
Hope this helps!
Jan 15, 2008 | Memorex 32023252 Internal 52x CD-ROM Drive
Windows
hard drives dont read cd's
does the door close?
if not close it.
1)left clik my computer
2)double clik the cd rom drive, making sure theres a disk in it.
3)right clik on my computer
device manager
look for a yellow exclamation point or red X where the cd-rom is.
high light the cd-rom
right clik
uninstall
restart the computer
windows will detect and re-install the cd-rom drive.
try a cd
if that doesnt work update windows
also buy a cd-rom cleaner at your local electronics store
clean the drive w/th cleaner
try a cd
if updating your driver for the cd rom drive and all ive suggested then its time for a new cdrom drive
Dec 09, 2007 | Dell OptiPlex GX260 PC Desktop
Emachines w3507 DVD Rom Broken
There may be a hole but it will be under the lip of the door, kind of impossible to get to. You may have to remove the drive from the emachine and unscrew it and open it manually with a small screwdriver. I regularly buy and repair or use parts from used samsung drives which is what emachines uses almost exclusively. The only upside to this is that once open, you can swap the faceplates and doors onto newer drives. If the led light is not in the middle then you can swap out the little plug in circuit too.
Nov 12, 2007 | E-Machines emachines (emachinees) CD-ROM...
CD Rom Driver door won't open without using the straightened out paper clip or pressing the driver door button upwards of 15, 20 or maybe 25 times. It will eventually open after repeatedly pressing for...
If this happens with all your CDs and everytime, I would suggest you should replace your CD Rom Drive with a new one. After use of some years CD Rom Drives have such problems. Otherwise a software might locking your drive. you should find a tool which unlocks the drive and then press the eject button.
Oct 06, 2007 | Acer Aspire M1640 Refurbished Intel...
HP GX613AA Pavilion A6300F Desktop PC Logo
239 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
