Question about Frigidaire FGF316 Gas Kitchen Range
Oven does not maintain temp.
It takes the burner 3 to 4 min, to ignite. Once the oven reaches it's set temp it turns off, then does not turn back on to maintain temp. The broiler works normal once burner is light.
  • Anonymous Mar 15, 2014
    Burner shut off when reaches certain temp then comes back on.
  • 2,976 Answers
It sounds like a thermocouple problem. While using the broiler, you gave the gas set to full and the thermostat is basically out of the loop.
Posted on Feb 20, 2009
Riello 40 gasG900 burner that will ignite but when oven reaches temperature it turns off completely. After temp drops by 4 degrees it turns back on and reheats back to temp then turns off.Why is this?
that would be normal. if it didnt shut off, it would go above the set temperature. the heat is either off or on. it cant me in the middle. it turns 'off' so that the temperature doesnt go too far above 250. when it senses the temperature falling too low below 250, it heats it up again.
Sep 03, 2017 | Ovens
see this instructions and fix it. God bless you
  1. eHow
  2. Home & Garden
  3. Home Appliances
  4. Other Home Appliances
  5. How to Troubleshoot a Gas Range Oven That Won't Heat
By Kefa Olang, eHow Contributor
Although gas range oven may prove useful for cooking and baking, they may fail to ignite if they aren't properly maintained and set up. Lighting a gas range often involves simply turning a knob; however, blockages from food particles and debris caught in the burners, improper burner cap installation and gas supply are common problems that interfere with your gas range oven's performance. A few troubleshooting guidelines may solve these problems safely.
Other People Are Reading
Things You'll Need
  • Toothpick
  • Paperclip
    • 1
      Check you have gas in your tank if your gas range oven won't heat. Contact your gas supplier if you've run out of gas.
    • 2
      Clean the burners if you have gas but your burners still won't ignite. To clean the burners, lift the burner caps 9b4f010f-be4f-4db6-8a88-4c3fd17e3339.gif
    • 3
      Inspect the small vertical holes on the side of your burners for dirt, food and debris. The gas won't ignite if they are clogged. Scrape dirt, debris and food from the vertical holes using a pointy object such as a toothpick or paperclip.
    • 4
      Reinstall the burner caps properly. If they are tilted or wobbly, the gas may not ignite. Install the caps on the right burners. Some burners are smaller than others, so match the caps to the appropriate burners.
    • 5
      Move the burner knob to the "Lite" position and wait for the gas to ignite. If it ignites, rotate the knob to your desired setting. If it doesn't ignite, contact a qualified appliance technician.
Jul 18, 2013 | Ovens
GE profile Spectra gas range/oven is taking approx.20-30 min to preheat. Once it finally reaches temp. it seems to hold at that temp and maintain it. I have noticed occasional puffing sounds when it...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
Apr 17, 2011 | Ovens
Ka gas range the glow bar comes on but it takes sometimes 15 to 20 min before gas is supplied to burner in oven and finaly ignites
Hi, this sounds like a weak igniter, it would have to be a gas oven and the symptoms usually are: takes longer than normal to ignite the burner, may or may not smell gas in the oven, if it does light the burner, there may be delayed ignition (pop), does not maintain set temperature or burner does not come on fully, eventually won't heat at all. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
Jan 22, 2010 | KitchenAid KGST307 Gas Kitchen Range
Oven not working properly
I just solved this problem with my GE gas range. I waited forever for the oven to warm up. The igniter would glow, light the burner and burn for a minute or so and go out. It would repeat this process till oven reached operating temp, which took forever. Problem is in the igniter. It may be glowing, but it is not letting the gas valve stay open, because it is not hot enough to create resistance in it to keep gas valve open. I had replaced the thermostat thinking it was the problem. The good part about it was I could take it back because my buddy works at supply house. Once the igniter was replaced, the oven fired up and stayed lit till operating temp was reached. It will also hold the oven temp much better. Oh yea, the igniter will stay glowing while the burner is on. Hope this helps.
Nov 29, 2008 | GE JGRP20 Gas Single Oven
GE Spectra XL44 oes not heat to desired setting
The oven sensor ( WB21X5301) is suppose to tell the oven control when to turn on and off to reach and maintain oven temp, but before you go replacing it, try to observe how long it takes from the time you turn the oven on to the time the oven ignites. Ignition should be 30 seconds to about 90 seconds. If it is taking a very long time, replace the igniter (
). Ignitors get weaker over time, and this should be looked at first, as both parts are not real cheap, so you don't want to just start throwing parts at it. Here is a trick you can try: On the JGBP90 (model you posted under) the broil ignitor is the same part number as the oven ignitor, so if the broiler, which is generally used much less than the oven, is working fine you can interchange the two ignitors to see if that solves your oven temp problem without having to buy a oven temp sensor first.
Nov 10, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven & broiler not working
you ignitor is going out you will need to replace it the ignitor needs to draw a min of 3.2 amps in order to open the gas valve coil if short of this it will not open at thimes it may just have enough to open
Jun 28, 2008 | Hotpoint RGB528 Gas Kitchen Range
Maytag gas kitchen range/oven model# MGR575 ADW during preheat cycle in oven seems to keep trying to start left bank of burners over and over again. Gas can be heard flowing an ignition occurs and then...
that actually sounds to be pretty normal operating procedure unless im not understanding correctly, the unit will shout off, and cycle back on to maintain proper temp as cooks, the" top lef bank of burners" they show signs of clicking??? but not actually igniting correct??? and do they ever start to click when unit is completly off???
Apr 07, 2008 | Kitchen Ranges
Oven does not maintain temperature. Part 2
sometimes when they get hot that is when they fail
Sep 18, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Frigidaire FGF316 Gas Kitchen Range Logo
212 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
