Question about Olympus Cameras
Re: Olympus 70-300mm lens - how do I use the manual focus ? when I set the lens to to MF I am unable to focus the image
  • krokbait Feb 20, 2009
    thanks - it worked - too bad Olympus couldnt see fit to provide info for newbies - Cheers
    Francois
  • 495 Answers
What is the model name of your camera??
Posted on Feb 20, 2009
  • Manoj Rout
    Manoj Rout Feb 20, 2009
    The outer barrel is used by you to zoom the lens to whatever focal
    length you want to shoot your image with. The inner barrel is operated
    by the camera to focus on the subect you've chosen. Depending on how
    far away your subject is, the inner barrel can be at any position, from
    all the way in to almost fully extended.
    Try this, rotate the outer barrel to 300mm, then try focusing on a
    subject approx. 3 to 4 ft away. The inner barrel should be almost fully
    extended. It's best if you try this outside or in good light.
    President:
  • 2,976 Answers
You not only have to set the lens but, you have to set the camers for manual focus. There is an electrical interlock button for this.
Olympus om 30 manual
The OM-30 has focusing system limitations. Most of the time, you can use the LED in the viewfinder to help you focus an image. If the lens you attach has a maximum aperture of F4 or smaller, (F5.6, etc) you set this switch to F4, then focus the lens manually using the prism gridlines visible in the viewfinder.
In short, just set the F4/F2 switch to whichever is the closest to the maximum aperture of the lens you are using. With an F1.8 lens, for example, you would use the F2 setting. For a lens with a maximum aperture of F3.5, you would use the F4 switch setting.
Aug 19, 2014 | Olympus Om Auto Extension Tube 7 For Om-1...
K100D AF/MF SWITCH STUCK IN AF
Can you be more clear with your problem . When you are facing this problem ?
Have you done basic troubleshooting techniques like replacing new batteries, gentle tapping on camera
Oct 04, 2008 | Cameras
Olympus om-2 cvamera lenses
You are able to use your old OM lenses with a new Olympus digital SLR camera. You will need to purchase an MF-OM 1 lens adapter to be able to connect these lenses to the digital SLR camera. Also when using these lenses you will only be able to use the camera in manual focus mode as these lenses are not capable to shhot with an auto focus mode.
Apr 06, 2009 | Olympus FE-330 Digital Camera
Nikon d40 wont autofocus
Your 28-90 AF-D lens can't autofocus with the D40, which requires AF-S lenses with a focus motor in the lens. Sigma lenses with "HSM" (HyperSonic Motor) in the name also have the focus motor.
Feb 23, 2009 | Sigma f/NIKON- 28-90/3.5-5.6 Aspherical...
How to use a manual zoom lens with Evolt 510
By manual zoom lens I am assuming you mean a film camera lens. If it is one of our OM 1 or 2 lenses they can be used on our Olympus digital SLR camera but you will need to purchase an MF-OM1 converter to be able to adapt those lenses to fit on our digital SLR camera. Then you will only be able to shoot using those lens in manual focus mode. Auto focus mode will not be available.
Sep 25, 2008 | Olympus Cameras
Olympus C-765 does not focus
Dear Benjamin,
I also own an olympus c765 and was wondering how to use the manual focus option when I came across your post. Actually I have been wondering whether manual focus is of any use in an olympus c765 because the manual does not talk anything about it.
However, I just found out that there is a way of activating/deactivating manual focus. Here it goes:
1. Turn the camera on
2. Switch to any mode - portrait/landscape etc
3. Press and hold the 'OK' button on the centre for a second until you see a MF/AF option on the screen
4. Switch to MF and focus on any subject by pressing the up/down keys.
Most likely, your camera has been turned to Manual Focus option, which is why it is not focussing any more. Follow the steps above and turn it back to Auto Focus option and let me know if your problem gets solved.
Regards
Aug 30, 2008 | Olympus Camedia C-765 Digital Camera
I BOUGHT A PENTAX K10D THAT CAME WITH A VERY NICE AUTO ZOOM LENS. I OWN SEVERAL OLDER PENTAX LENSES THAT I USED ON MY K1000 CAMERA AND I WANT TO USE THEM ON THE K10D. I CANNOT FIGURE OUT THE SETTINGS THAT...
I don't own a K10D, but I do own a K100D which I have successfully used both manual focus & auto-focus lenses from my old Pentax stash!
1) If it is a manual focus lens, you need to turn off Autofocus on the body of your K10D. On my K100D, there is a switch on the side of the lens mount that says [-MF or -AF]. "-MF" is manual focus mode & "-AF" is autofocus mode. Since your lens doesn't have autofocus capability, turn it to the "-MF" mode.
Also . . . When I press "Menu" and go to "Custom Setting", I change two settings . . .
1) I change "Using aperture ring" to "Permitted". This allows you to use manual lenses (M lenses) that do not have an auto(exposure) setting, and also lets you use Auto lenses (A, KA, KA2, FA, etc.) in either the Auto or manual aperture setting modes.
2) I change "Fl with S lens used" so that even with a manual focus lens, although I don't have autofocus capability, my K100D beeps and shows a little red square in the viewfinder when I have successfully focused manually!
The K10D should have the same options.
This should get you up and running!
I have had a load of fun with my old lens on my new digital Pentax!
Take care & Happy Imaging!
Glen
Jul 14, 2008 | Pentax K100D Super Digital SLR Camera
Can the 40-150mm be used in AF mode with EC14?
Tullio,
Olympus 4/3 adapter will work with OM lenses.
All in manual.
Manual focus, zoom and F stop.
atdlee@netzero.com
Jan 11, 2008 | Olympus 40-150mm f3.5/4.5 Zuiko Lens
Manual Focus Problem
Yup, the Oly C5050 MF leaves a lot to be desired... What I did was to use the AF to get a focus lock then while still holding the shutter half way I would change focusing mode to MF - it will keep the distance value of the AF... Hope this helps...
Sep 13, 2005 | Olympus Camedia C-5050 Zoom Digital Camera
Cameras Logo
16 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
