Question about Onkyo TX-SR606 Receiver
Unsure of audio setting using Onkyo TX-SR606 connected to PS3
Can someone tell me what the audio setting on the TX-SR606 should be when the PS3 passes the signal as full multi-channel. I use an HDMI 1.3a connection. My receiver always seems to say something different i.e. Dolby Digital or TV Logic or DTS Mono --
    Scholar:
  • 93 Answers
The PS3 should default to the DOLBY DIGITAL sound output so your ONKYO should be setup to the Digital input, TV logic is a matrix similated multi-channel and I doubt if any PS software is in the DTS audio format, look at your game software disc`s and they will inform you of the audio capabilities.
Posted on Feb 20, 2009
2 Suggested Answers
  • 6 Answers
SOURCE: Can someone tell me what the audio setting on the
If you're running an optical cable from the PS3 to the receiver, best quality would be through the Dolby Digital, because that broadcasts in 7.1 HD Audio Format. There should be a way to get a default setting when the optical input is detected in your receiver.
I cannot get video signal from my Samsung p1590 Blu Ray player via HDMI to pass through my Onkyo TX-SR606 AV Receiver. I get video if I connect Blu Ray player directly to TV, and have tried all HDMI ports...
I think this one is for the Onkyo wizards:
I would write them via email here:
http://www.onkyousa.com/feedback_form.cfm
1-800-229-1687
However I did find this 2 page hookup manual with nice notes at link listed below that may help you solve the mystery:
(seems you may have to assign the digital input)
http://filedepot.onkyousa.com/Files/QuickHookup/TX-SR606_QSS_En_A.pdf?CFID=918117&CFTOKEN=40624545&jsessionid=f0306ea8a0d68bb60a49102e3e5510576756
Assigning the Digital Input
If there’s no sound, you’ll need to assign the digital inputs as
necessary using the setup menus on the TX-SR606’s display.
If you connect your DVD player to the AV receiver’s COAXIAL 1
DIGITAL IN, and your cable/satellite receiver to the COAXIAL 2
DIGITAL IN, as shown, it’s not necessary to assign the digital input.
The onscreen setup menus appear only on a TV that is
connected to the HDMI OUT. If your TV is connected to the composite video or S-Video MONITOR OUT, or the
COMPONENT VIDEO OUT, use the TX-SR606’s display when changing settings.
Thanks for using FixYa!
Kelly
Feb 19, 2010 | Onkyo TX-SR606 Receiver
Onkyo TX-SR606 Reciever - 20 sec after power on, screen is green
The HDMI version in your receiver is 1.1 or 1.2 which will not pass video as it should. It's not Onkyo's firmware at issue, it's HDMI and in all receivers up to 2008 model year this is a very heated problem! The only fix is to run FIOS directly to the TV via HDMI and run it's audio to your receiver with Digital Coaxial or Optical. Hope this helps
Jun 11, 2009 | Onkyo TX-SR605 Receiver
Remote code for sony playstation 3
you cannot control a ps3 with that remote because the playstation 3 only works with bluetooth. I'm sorry to have to tell you. you can purchase a remote that works with your system at any that sells your system.
hope this helped
please rate well.
Mar 06, 2009 | Onkyo TX-SR606 Receiver
Onkyo TX-SR606 aspect ratio issue
you may want to try changing the aspect ratio on the HD box and the DVD as opposed to the receiver. This should do the thing
Mar 04, 2009 | Onkyo TX-SR606 Receiver
Onkyo TX-SR606 getting no sound from HDMI sources on speakers. I have a motorola cable box and a panasonic DMP BD-35K blueray player both attached to the SR606 via HDMI cables (HDMI3 and 1 respectively)...
Not sure if this is your fix, but I had what I thought was the same problem. I played with my Onkyo quite a bit ensuring the correct assignments for HDMI, audio and all that stuff. Turns out I neglected to make sure the output devices were properly assigned. Many devices aren't default to output sound over HDMI. I changed the audio out settings on the cable box to HDMI and suddenly the Onkyo worked great. I know, I'm an idiot for not checking that in the first place, but maybe someone out there is having the same trouble as well.
Feb 20, 2009 | Onkyo TX-SR606 Receiver
Can someone tell me what the audio setting on the Onkyo TX-SR606 should be when the PS3 passes the signal as full multi-channel. My receiver always seems to say something different i.e. Dolby Digital or TV...
No DTS-HDMA or Dolby TrueHD shown on display
DTS-HDMA and Dolby TrueHD cannot be passed to your receiver via bitstream on the PS3. DTS-HDMA cannot be decoded either so you're out of luck there.
Dolby TrueHD can be decoded internally on the PS3 assuming your firmware is up to date. Set the Blu-ray HDMI output to PCM and you can then pass it to your receiver.
If this doesnt work, do a system update on your PS3.
Jan 24, 2009 | Onkyo TX-SR606 Receiver
ONKYO TX-SR606 Single output to TV
Hi there. for your receiver, the only time it can upconvert is when you go out as HDMI. In your current hookup (component out to tv) the signal from your cable (using a composite) will not be able to pass through the component cable. This means you either have to hook up your cable box using a component cable as well or add a composite cable (yellow) from monitor out of the receiver to the tv. Page 22 of the manual will show a diagram of the video signal flow. hope this helps.. ^_^
Dec 02, 2008 | Onkyo TX-SR606 Receiver
Onkyo TX-SR606 Receiver Logo
871 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
