Question about Sony KP-57HW40 57" Rear Projection Television
My screen turns green and then turns off
When i turn the Tv on the colors fade, flashes green wavy lines, goes totally green and then the TV turns off sometimes before the volume does.
  • 2 more comments
  • captinhowdy4 Feb 26, 2009
    when the tv comes on after a few mins the screen turns blue? mine isnt green could this be the same problem.
  • bluedice16 Mar 05, 2009
    i did this and it helped but didnt stop the problem from occuring again. my colors fade in and out but i have no line anymore. and sometimes it still flashes a green screen.
  • bluedice16 Mar 18, 2009
    I HAD A REPAIRMAN TAKE A LOOK AT MY TV, HE SAID THAT THE GREEN AND RED PICTURE TUBES ARE INTERMITTANT AND NEED TO BE REPLACED.
  • bluedice16 Mar 20, 2009
    where can i find that box and how much is it, and is hard to replace? also if it is the tubes where can i find those to buy?
  • 185 Answers
You need to adjust the screen voltage. behind the front grille and inside cover. a small black box 6 adjusters protruding from it. only adjust the the color counterclockwise that matches the problem in this case it's the green so look for the knob with "G" marked by it. there are 2 with "g" marked by them the row across the top of the box are for focus don't adjust. back the knob off untill the raster is blank with your input set to an inactive input, the picture should be blank and black.
when it is you have the adjuster close to where it should be, now change the input to an active signal and turn the color off so that you wil have black and white picture. adjust that knob untill you do have a truely black and white picture not too green or red or blue. go back to inactive video input and check that there are no lines of any color on the screen. repeat if needed. always adjust these knobs slowly the set will be watching you ! if your autofocus won't work now you have the adjustment set too low. check this function before putting back together again. these adjustments can be real touchy so be patient
Posted on Feb 20, 2009
  • 1 more comment
  • A Schneider Mar 05, 2009
    with the set turned off adjust those knobs ack and forth quickly. this will clean the internal tracks and settle the problem if not replace the block. only adjust the color that give you the trouble. then perform he setup.
  • A Schneider Mar 18, 2009
    nothing wrong with your tubes, if the proceedure didn't work then replace the little box with those adjustors on it.
  • A Schneider Mar 20, 2009
    i doubt those tubes are still availible and that box is the 1 you have been adjusting on.
Tv powers on, see three birds in color then flickers and fades to white
The problem must be with its main digital processor board. It will be best to make it confirm. Contact any service technician. Try this link. http://electronicshelponline.blogspot.com/ There are more than two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help.
May 20, 2013 | ViewSonic N1930W 19 in. LCD TV
TV screen turns totally green and has a wavy line
try remove the casing of ur tv go on the yoke, u see small board connecting to the yoke the try resolder all the part.Look on the main board some part are only lost look for it then resolder.Most especially the of chroma section wherein the colors are blending here i recommend to resloder properly sure to it that it will not jump to other pin.
Jun 18, 2009 | RCA 24F512T 24" TV
Pictures goes to distorded wavy lines.
This could be attributed to tuning reception of your tv. If your using antenna only, it is most probable. If cable, check your line.
If this is a crt type, moving that tv with that size could somehow bend its circuit board. Loose connection is a probability. Could be some minor component is detached from solder. This can be attributed to tuner and vertical IC.
Just for an input.
Apr 20, 2009 | Sanyo DS27910 27" TV
Video distortion
You need to take your tv in and have the picture deflector re-aligned.  This doesn't cost much, My dad had to do that to his a few months ago and it cost 30 bucks.
Mar 21, 2009 | Mitsubishi VS-60705 60" Rear Projection...
Green Screen
Hi, how is the cable box hooked up to the TV? Is it HDMI cable or componet (red/green/blue) ? When you say totally green, do you mean the the picture is only green with the other colors missing or every color looks green ?
Mar 14, 2009 | Protron PLTV-37 37 in. LCD Television
Screen Goes Green TV goes to stand by blinking 8 times
try adjusting your color tuners located inside tv behind speakers.
Nov 25, 2008 | Sony KP-57WS500 57" Rear Projection...
Green flashes then tv turns off
or a new lamp. you could first replace the lamp.
the screen might work fine for a couple of seconds, but then it fades away or deteriorates. This means the lamp is going bad.
Aug 23, 2008 | Sony KP-51HW40 51" Rear Projection...
Green screen crash
i have a projection tv. It is a a Samsung HDTV 55" widescreen. There is a green curvey lines at top of screen. Can you help?
Jan 20, 2008 | Televison & Video
Sony Trinitron K29 inch CRT TV screen shows green shade!
i have the same problem with my sony trinton tv 36 inch if you know how to fix this please email me on amir.dhawan@gmail.com
Dec 30, 2007 | LG Flatron 295LM 22" LCD Monitor
Sony KP-57HW40 57" Rear Projection Television Logo
265 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
