Question about Dacor Epicure EDW24 Built-in Dishwasher
Broken rollers inside top rack slides
The rollers inside the slides for the top rack on my Dacor EDW24 dishwasher have broken and fallen out. I need to replace some/all of them, but I can't find them - no part number.
I found the slides, but apparently the little rollers aren't pre-installed on the slides.
Please help! I don't want to have to buy a brand new dishwasher because of a few plastic pieces!
Thanks in advance.
  • clairelichte Mar 16, 2009
    Lost one of the rollers and they want *Gasp* $72 for 4 little rollers.  Want an alternative
We got rollers recently from Johnstone Supply, 501 Third Avenue, South, Nashville, TN telephone 615-259-3440 or 254-0702. I don't know the cost, but I'm pretty sure it was not $72. I suggest that you have the model #.
I am planning to buy some for another dishwasher at the moment.
Posted on Apr 12, 2009
Middle arm loose
Hello Mike Hilgers - There are two main reasons why the middle spray arm could possibly be loose. Either it is not installed properly or the bracket that mounts it to the bottom of the rack is broken or loose. Carefully remove rack, spray arm and reposition correctly with all rack wheels inside rack slides. If you have already done so, replacement parts may need to be ordered or it could possibly be a more serious issue coming from the interior dishwasher.
Mar 03, 2013 | Frigidaire FGHD2433KF Builtin Dishwasher
DFUD142 Dishwasher. Plastic clips holding Cutlery/Utensil Cradle sliding tray have broken. Looking for new clips or an alternative solution. Thanks
Hello, welcome to fixya
Here's what works for me, take the lower basket out and set it aside to give yourself a more work friendly environment. Now move the rack stops to the left if you haven't already and then the rack itself...example
and
Now you'll need to remove the bumpers at the back of the rack rail, example...
push down on the bumper as shown
and pull it down and out at the same time...it takes some force, you can use a small screwdriver.
Now you'll need to slide the rail all the way out as shown, but careful not to let the ball bearings fall into the sump area in the process.
I usually hold the broken piece in place while removing the rail...
...( they come in a kit at "repairclinic.com" under number 1394379 like shown here individual holders # 8058638-77 from the link I pasted below at allvikingparts )
http://www.allvikingparts.com/Guide_Rail_Ball_Holder_p/pd110003.htm
The trick now is to install the balls into the holders first
and the holders into the stationary part of the rail on the inside wall...
The inside wall rail will keep the holders in place as you slide the inside rail into place...this will usually require holding the holder with one hand while pushing the sliding rail back into place...
Once this is done, re-install the back rail bumpers followed by the rack and then finally the front rack stoppers and that should do it.
Hope that explain it for you or gives you an idea of how it needs to be done. Please take a moment to rate the assistance I provided here today favorable and a brief testimony is also appreciated when providing free solutions.
Thanks for visiting "fixya" today for your repair help and good luck. Let me know if you require further assistance.
Regards,
Macmarkus :)
P.S.
I should also mention you as I alluded to, be sure none of the old 8 ball bearings didn't fall down into either the drain pump or circulation/wash pump. This is something I've seen far too often on Asko dishwashers with the end result being a broken impeller in either pump...or both, yikes ! I use a telescopic magnet to fish around as it will be the only object made of metal...unless something else has fallen in the sump well area, it's good to check.
Sep 13, 2011 | Viking DFUD142 Built-in Dishwasher
D1776 asko dishwasher upper basket ball bearing asssembly falling apart
Here's what works for me, move the rack stops to the left if you haven't already and then the rack itself.
i.e.
and
Now you'll need to remove the bumpers at the back of the rack rail...
i.e.
...( they come in a kit at "repairclinic.com" under number 1394379 like shown here )
Thanks for visiting "fixya" today for your repair help. Let me know if you require further assistance.
Good luck.
Regards,
Macmarkus :)
P.S.
Again, good luck :)
May 16, 2011 | Asko D1776 Built-in Dishwasher
How do you replace the rail replacements in
Welcome to fixya.
i.e.
1d854c5.jpg and
i.e.
and pull it down and out at the same time...it takes some force as evident by my finger tip ha ha, you can use a small screwdriver...I'm just stubborn.
Good luck.
Regards,
Macmarkus :)
P.S.
Again, good luck :)
Oct 27, 2010 | Asko D1776 Stainless Steel Built-in...
Replace upper basket and bearings on Asko dishwasher 1805
Welcome to FixYa.
Yes the upper rack is pretty straight forward, but the bearings are tricky.
i.e.
1d854c5.jpg and
i.e.
The trick now is to install the balls into the holders first...
Thanks for visitng "fixya" today for your repair help. Let me know if you require further assistance.
Good luck.
Regards,
Macmarkus :)
P.S.
Again, good luck :)
Sep 23, 2010 | Asko D1876 Dishwasher
Dacor dishwasher wont drain
You need to determine if the output pump in line with the outlet hose is working and that the outlet pipe is not blocked or obstructed. The pump should spin and just by looking at the pump this can be tdetrmined. With the washer off you could spin the impeler of the pump just to determine that the impeler is free to spin. You could test for power on the 2 terminals of the pump and if present and the pump does not spin this indicates that the pump is "open circuit" and needs to be replaced. "one of the easy jobs on washers"
Mar 21, 2010 | Dacor Epicure EDW24 Built-in Dishwasher
My kitchenaid dishwasher won't stay shut. It pops
Check that there isn't something still in the very back of the rack (top or bottom) that's sticking out and keeping the rack from sliding all the way in. Similarly, if the problem goes away when you take the racks out, the problem is with the racks. Otherwise, it's the latch: either the eye (attached to the top of the machine) is bent/broken, or the hook (inside the top of the door) is broken. Good luck.
Mar 03, 2010 | KitchenAid 24 in. KUDS01FLBL Built-in...
Top rack rail contently comming off the rollers. The rollers are wobbly, tried to tighten but will not go any tighter. are there better rollers available? PLD2850RDC2
Typically the roller wheels and the post tabs that hold them onto the sliding rack/guides will wear over time and depending on how heavily your family loads the racks, the sooner you'll need to replace them.
You can order new ones and do the job yourself which is the best solution for the situation you're describing. The only other thing to check is for the rack section that is attached to the inside dishwasher walls to make sure those screws are snug (don't overtighten and strip them out!) other than that, you still will need to replace the rollers on the extendable portion of the rack supports, etc. Hope that helps.
Jul 13, 2009 | GE 24 in. GSD4030Z Built-in Dishwasher
GE Adora Dishwasher Upper Rack Binding Issue
I have a GE Profile model PDW7800.... and just replaced the rollers on one side since one of them had broken. There is a 'magical' way to reinstall the rack so the side guides ride inside the roller guides without touching. I suspect that the rack has not been reinstalled in the precise manner - which I am still trying to figure out. The new roller assembly which attach to the rack fit differently than the original ones. I found that you do have to remove the rollers screwed into the wall to get the glides out and that could also cause rough gliding. Part of the 'binding' is designed, I believe, to keep the racks from coming out too easily.
Sep 17, 2008 | Dishwashers
MDB7601AWS Maytag dishwasher
hi there,
go to www.whirlpooparts.ca and type in the model # under Repair Parts. it will show you the exploded view of the racks.
May 13, 2008 | Maytag 24 in. MDB7600A Jetclean® II...
Dacor Epicure EDW24 Built-in Dishwasher Logo
275 people viewed this question
Top Dacor Dishwashers Experts
Mike Cairns
Mike Cairns
Are you a Dacor Dishwasher Expert? Answer questions, earn points and help others
