Question about E-Machines -T1842-CELERON-1.8GHz,40GB Desktop Computer System
When the machine is turned on the tower doesn't turn on,
It turns on and then turns off repeatly every half second, nothing happens beyond this? A schematic of the tower might help?
    Genius:
  • 2,785 Answers
Plz try by resitting the ram, if the problem is not solved then try with a good power supply unit
Posted on Feb 20, 2009
My emachine won't turn on it only beeps repeatedly. How can I bypass and reset my emachine?
Beeping may be the fault of defective RAM Memory modules. Try pulling out half the RAM, and restarting, the put that back in and pull out the other half, and restart. What are the results?
Jun 23, 2014 | Computers & Internet
Proscan television will not turn on
Work renovation Repeat until the works
Nov 11, 2013 | managemylife.com
Lens on my S7000 doesn't retract when switched off - now permanently extended - and camera dead
This is going to require service / repair at the shop, not something you will be able to correct.
Jan 26, 2013 | Fuji FinePix S7000 Digital Camera
My dell inspiron m5010 doesn't turn on I've tried
You don't turn off a machine when updating the BIOS for any reason.
the system boots from the BIOS, and if the BIOS is corrupt due to an incomplete update. it's going to be very tricky to get it back on. contact Delly on the issue. best of luck Ram
Jan 03, 2013 | Computers & Internet
My w3107 machine tower just beeps repeatedly when you turn it on and the hp vp17 monitor just says no input signal. Any ideas on how to fix it before my husband throws it out the window?????
Constant beeping when you turn a computer on is an indication that you have a RAM memory error. To confirm this, open the tower (after unplugging the unit and pressing and holding the power button in for 10 seconds to confirm there's no charge left). Locate the sticks of RAM memory and remove 1. Then plug the unit back in and reboot. In most cases, the beeping will go away and the machine will boot up. This doesn't usually mean you have a bad RAM memory module, just a bad "bank" on the motherboard. If you like the machine, and removing the RAM works for you, you can either run minus the stick of RAM (the machine will be slower) or do a motherboard upgrade. You can usually get a good motherboard + CPU upgrade in the $90 range. Choose a motherboard that will accommodate the existing RAM memory to keep the project cost effective.
Sep 06, 2011 | HP Computers & Internet
My computer's tower turns on but it doesn't display on the monitor, the monitor shows the normal Self test box so the monitor doesn't seem to be the problem. Also when I press the power off...
Make sure that the cable is connected from your computer to the monitor, and if it is wiggle it and push it in all the way. If it has screws, screw them in. If that does not work, check that your monitor is on the correct input (if it has multiple) then see if anything comes on the monitor. If nothing happens you should buy a new cable from the store. If all of those steps do not work your computer or your monitor might have a more serious problem.
Jul 29, 2011 | Computers & Internet
When i warm machine up the word ventilate appears and nothing
Run the hot water cycle for a few seconds, that will clear the air lock.
Mar 26, 2009 | Saeco Royal Professional Espresso Machine
My tower won't turn on. I checked and it is plugeged in to a working outlet... the screen light is on and even one light on the tower is on -- but when I press the on button NOTHING happens.
hi ,
you can try this solution
unplug all cables , powerflee the system by pressing the start button for 30 sec , release it then replugg all the cables and check wheather it is working or not , secondly check wheather the powers supply fan on the back of tower is working or not, still it doesnt work turn off the tower and unplugg the tower and then openthe tower , check all cables and reset the RAM on the mother board ...you can try this basic troubleshooting , it will help u... waiting for response
May 20, 2008 | Computers & Internet
Bernina Activa 131: buttonhole problem
There are TWO buttons on the machine that have the little u-turn on them. Look for the other one. That is the one that makes the second half of the buttonhole. Look in the owner's manual, it may tell you where it is on your machine. I spent a long time swearing at my machine before I figured out that the reverse is not the only button with the u-turn arrow. The manual is not clear on this. Why they use the same symbol twice is beyond me. Mine is on the front of the machine, down by the needle. Hope this helps.
Feb 28, 2008 | Bernina Activa 130
Computers & Internet Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
