Question about XION PSU XION|XON-800R14N 800W RT
Whining sound with xion 800 watt power supply.
I replaced my blown 600w xion with an 800 Watt version. When I start the PC I get a high pitch whining noise. any ideas what that is? do you know where I can find an installation schematic. The new supply has nicely loomed wires. I doubt the fan is rubbing a wire.. any help on installing would be great if you could recomend a source for instruction. Thanks,
    Novelist:
  • 171 Answers
There is a fan insine the power supply, and also a fan on the CPU. Occasionally there is also a fan on the chassis of the computer itself.
Turn on the computer, take the case off, and listen to identify the source of the noise. If it's inside the PSU, return it and get a new one.
Posted on Feb 20, 2009
What is the power supply values
The power supply values was in watt
usually a 500 watt power supply was enough for a regular PC
but for gaming PC it require about 800 watt power supply
Jan 23, 2016 | Power Computers & Internet
With Electric down, I just plugged my 12 in. fan into the XPower 200 PLUS after 15 min. the unit started to mum loudly.....and the fan stopped....is that as long as it will work before charged again
That sounds about right. 200 watts isnt alot of power, its enough to power small electronics such as phone chargrers, but if you want to power a high energy product, try a 650-800 watt supply. More watts = longer run time for your devices.
Mar 30, 2011 | Xantrex Technology XPower Powerpack 200...
Sould the ULT_LS6000P(600W) have a -5v?
Yes, if it follows ATX standards That should be the White wire.
May 26, 2010 | Ultra Products Ultra LS600 Lifetime Series...
Whining sound will not stop
The toroidal core transformer(s) is going bad. This will call for a unit replacement. Is it under warranty?
Oct 06, 2009 | APC UPS/Surge Protector 330-Watt Power...
New replacement power supply makes continuous high-pitch sound
If the computer turns and works (other than the noise) then the wiring is correct. The ATX plug should be keyed so it is almost impossible to hook up incorrectly, and the wiring is for the most part standardized. However, there could be a problem if it is an older computer and your replacement power supply is from a Dell. Dell ATX power supplies, mostly from the PII to PIII era were not wired to the standard ATX pinouts. So, if you put a non-Dell power supply in an older Dell, or if you put an older Dell power supply in a non-Dell PC of any age, your wiring will not be correct. Usually incorrect wiring means either it fries or just doesn't start at all.
Specialized PC's or high end servers may also use non standard power connectors.
If you paid less than $40.00 for the power supply, the problem is most likely just a bad / poorly made power supply. Most of the budget power supplies are extremely cheaply made. They will sometimes have a lot of noise/whine/hum, and often fail quickly. In a lot of cases you will be able to tell the quality of the power supply just by the weight. The cheap ones are usually as light as can be. A good power supply will have some heft to it, as it will have large heatsinks and heavy duty components. If you have a Radio Shack nearby you could pick up a Thermaltake 300 to 450 watt power supply and try it and see if the problem goes away. They have a pretty flexible return policy. If you have a high quality power supply, it could be that you just got a bad one. Try another to confirm. If you try a Thermaltake and it still whines (and never made noise before this problem came up) then it could be that other components in the PC are near failure--possible as a result of your previously failing power supply. My experience though has been that unless the power supply popped (as in literally blew out) the motherboard and other internals aren't usually affected.
I am assuming here that the computer is starting up. If not, make sure that that all the necessary power leads are hooked up. Newer motherboards may have have a 20 or 24 pin main ATX power connector. They may also have a secondary 4-pin 12v connector to power the CPU. If you are mixing a really old or new revision power supply with an opposite age motherboard there may be a problem of not having the appropriate connections available.
Finally, if you are under-powered, you could also experience problems. What is the wattage of your new power supply and what type of computer/CPU? If you are running a 200 watt power supply to power a modern motherboard/CPU you may not be able to supply the power needed. This could result in a stressed power supply, which may make noise, or just power offs or system instability.
I very much recommend spending the extra dollars for a well made power supply. I have replaced many of the $20.00 units. Even if they say they are 350 or 450+ watts, they don't hold up. Often the computer will start random power offs and then the supply will fail completely. A good supply will usually come with a 5 year warranty and will be generally problem free.
Here is a link to a wiring diagram for the ATX plug--just to be complete.
http://pinouts.ru/Power/atxpower_pinout.shtml
Oct 03, 2009 | Computers & Internet
Power acoustik gothic OV2 800 manual
Could not get a manual for you but did get the follwing specs. Hope they help.
Power Acoustik Ov2-800 2-Channel Class A/B Gothic Series Amplifier (800-Watt)
POWER ACOUSTIK OV2-800 2-CHANNEL CLASS A/B GOTHIC SERIES AMPLIFIER
800-WATT 2-CHANNEL
4 ohm RMS: 150W X 2
2 ohm RMS: 180W X 2
Bridged mode MONO RMS: 360W
BRIDGED MAX: 800W
FULL MOSFET POWER SUPPLY
PWM CIRCUITRY
FULL SELECTABLE CROSSOVER
3-WAY PROTECTION CIRCUIT
TRI-MODE CAPABLE
VARIABLE LOW PASS 40 HZ - 120 HZ
VARIABLE HIGH PASS 150 HZ - 1.5 KHZ
VARIABLE 18 DB BASS BOOST @ 40 HZ
FREQ RESP: 10 HZ TO 30 KHZ
S/N RATIO: 98 DB
THD: 0.02%
2 ohm STABLE STEREO
SYSTEM DISTRESS INDICATOR
HIGH/LOW LEVEL INPUTS WITH FLOATING GROUND
4-GAUGE POWER/GROUND CONNECTION
PLATINUM RCA CONNECTORS
LINE OUTPUT WITH FLOATING GROUND
BLUE LED
CHROME TOP PLATE PANEL 2-CHANNEL CLASS A/B GOTHIC SERIES AMPLIFIER (800-WATT)
Aug 18, 2009 | Power Acoustik GOTHIC OV2-800 Car Audio...
Advice for buying a new power supply compatible with my videocard
Get a 600 watt they are better and will handle all that you need the price from a 450 W to 600W is not much I run 7 dvd's a ATI Video capture card with a 64 bit AMD processors 1 80 gig Hd 2 Sata Drives 120 gig and sound blaster audio card and more and the 600 watt does fine The Corsair is ok Where to you think your going to get it at on line? or at a store? You can buy them at
tiger direct.com or Fry's.com The 600 watt ATI power supply will have 6 standard HD connecotors and I use three Y's for more and never had any problem with mine.
Jun 05, 2009 | Computers & Internet
Lost power supply need one. what are amps and volts requirements
just get one like the one that went out. id recommend a 600 watt power supply xion.com has good one
make a list or notes if you must or replace one lead at time and make a note of where it goes before you disconnect it '
the reason im recommending a 600 watt is most power supplies are marginal to begin with in my opinion. so getting a higher rated unit allows you to add accessories you might want to adds
i burned up a chief max 600 watt in a month for some reason replaced it with a 425 till i got a new one and bought a 600 watt xion.com power supply the original was 425 watt. i guess i got what i paid for the chief max was only 28 dolara from 3btech.net (a good site to bookmark
May 16, 2009 | Western Digital External USB 2.0 80 GB...
Power Hiccups and Cycles
Faulty electrolytics in the power supply. Buy a new one or get it serviced.
Sep 27, 2008 | XION PowerReal 600 (XON600F14T201)...
XION PSU XION|XON-800R14N 800W RT Logo
295 people viewed this question
Top XION Computers & Internet Experts
Jax Planet
Jax Planet
shuyumeng
shuyumeng
Are you a XION Computer and Internet Expert? Answer questions, earn points and help others
