Question about Samsung HCN5529W 55" Rear Projection Television
I have a Samsung HCN5529W projection tv. The
I have a Samsung HCN5529W projection tv. The picture went dark, but the sound was still on. I turned it off thinking I had pushed a button on the remote. When I turned it on the next day I could see smoke coming out the back.
The tv is about 5 years old. Any ideas????
  • 3 Answers
Yeah plenty, on older rear projection t.v.'s the circuit boards tend to over heat as they get older. keep the t.v. off and unplugged. contact a local repair shop.
Posted on Feb 20, 2009
I have sound but no picture.
Check your signal source, if not then the tv will require repair. probably the vertical IC or flyback transformer. in any case it has to be done by an experienced technician.
Dec 16, 2011 | Samsung HCN5529W 55" Rear Projection...
Samsung hcn5529W hmdi input dispaly issue
then try using RY able instead of HDMI input to test if its a cable problem
Mar 29, 2008 | Samsung HCN5529W 55" Rear Projection...
Samsung HCN5529W 55in Rear Projection can't Perfect Focus
hello What you have is a convergence problem. There is 2 modules inside your set that aligns the colors to have the same geometry and superposed . It is a common problem in rear projection tvs ,
You don`t have to worry about your blue tube , i`m sure it is perfectly fine, it just needs to be aligned through the convergence circuit.
Most often the problem is with those convergence modules that are faulty and need to be replaced.
Hope this will help good luck
Dec 07, 2009 | Samsung HCN5529W 55" Rear Projection...
Broken samsung hcn5529w
its not the cap. its the flyback xformer
Aug 29, 2009 | Samsung HCN5529W 55" Rear Projection...
Samsung HCN5529W rear projection TV has no picture but has sound
More likely its one of the Video output ICs which are located on the three CRT drive boards. I have seen that happen when one of the ICs fail they are TDA6111Q heres what they look like they are attached to the aluminum heat sink on the drive board617d21d.jpg
May 11, 2009 | Samsung HCM5525W 55" Rear Projection...
Dark Picture
Symptom: NO PICTURE
Cause: DEFECTIVE 3D/YC COMB FILTER
Symptom: DARK PICTURE
Cause: DEFECTIVE C724
Jan 16, 2008 | Hitachi 50SBX70B 50" Rear Projection...
Samsung HCN5529W television
There are 2 convergence IC's in the typical projection TV, and one of yours has burned out. If you have green sagging from the top then the convergence IC that handles Green Vertical (GV) needs to be replaced. The Samsung sets typically use the STK392-040 IC's. If you have no experience replacing convergence IC's then let a qualified tech change it for you.
Jul 03, 2007 | Samsung HCN5529W 55" Rear Projection...
Samsung HCN5529W 55" Rear Projection Television Logo
204 people viewed this question
Henry  Thomas
Henry Thomas
