Question about InFocus Proxima DP6155 Multimedia Projector
Bulb hours? How do I check the bulb life/hours on a Infocus projector?
    Scholar:
  • 167 Answers
The lamp timer hours can be found at the very first thing in the "ABOUT"menu
Cheers
Posted on Jan 16, 2010
The bulb dont turn on
Projector Lamp Life and Brightness - Projector Reviews
www.projectorreviews.com/articles-guides/lamp-life-and-brightness-2/
Feb 26, 2015 - There are still a number of 2000 hours at full power projector still on the... brighter, like projector Y, but Y just doesn't have the picture quality.".
Resetting Lamp Hours on a Sharp Projector - Spiceworks
https://community.spiceworks.com/.../2235-resetting-lamp-hours-on-a-sh...
Jun 12, 2011 - However, once you change the lamp the projector still won't turn on ...If it still doesn't work then there is some other problem with the projector.
How to Repair InFocus Projector Power Issue (LP290 ...
? 1:56
https://www.youtube.com/watch?v=sPGZSJXpxqI
May 7, 2012 - Uploaded by zibodiz
A common problem with older InFocus LCD Projectors causes them to turn off at ... How to Repair InFocus Projector PowerIssue (LP290/LP280) ... How to Install a Bare Projector Lamp into your Projector - Duration: 4:05. by ..
Dec 14, 2015 | Office Equipment & Supplies
When I try to power the projector up, a red light flashes and then it switches itself off. We have had a message saying replace bulb prevoius to the problem. Thank you
You will need to replace the bulb for this to work again. This is very easy to do. There will be a compartment to open with a screwdriver more than likely on the underside of the projector behind the lens. Remove that and you will see the bulb cartridge. Get the numbers off of that, order a couple of them and replace it. This should start up nicely after that. Every bulb has a projected hour life as well which is not like a home bulb. The life is considerably shorter so I would make sure you turn this off when not in use to get longer life out of it.
Feb 25, 2011 | InFocus ScreenPlay 5700 Multimedia...
Infocus projector powers on the green light
Hi I am Vortash check in your user manual this may be the signal to tell you that the projector is telling you that the number of hours for your bulb is up ( or indeed the bulb may have blown but this usually shows a red light if so ) if the bulb life monitior is at it's extent it wont let the light opperate and you have to reset the lamp hours you can find out how to do this in the manual under replacement bulbs .. if you have no manual you may be able to download one from off the net .from the manufactures support site .alternately you may have a ballast problem and it requires an engineer to sort it out . regards Vortash
Mar 30, 2010 | InFocus IN24 Multimedia Projector
Comp screen to projector, bulb light turns on
Try resetting the lamp hours it can go into a safe mode if you exceed the expected life of the lamp. It can be done even if there is no image have a look at the infocus website all models vary on the procedure if not try a firmware update to wipe its brain but you will need the leads it was shipped with.
Feb 11, 2010 | InFocus Work Big IN32 DLP Projector
Infocus 4805
You may have got finger prints inside the unit. Use alcohol and a paper towel or q tip/swab to clean all the glass surfaces including the bulb. You should never touch these bulbs because the oils from your hand will decrease the life of the bulb. Also make sure you put all the parts back and that they are tight. Last item is the lens may screw for focus.
Aug 29, 2009 | InFocus ScreenPlay 4805 Multimedia...
Power problem with infocus lp70+ projector
It seems the power supply board problem. shoud be checked by the trained technician only.
Feb 03, 2009 | InFocus LP70+ Multimedia Projector
Infocus screenplay 4805 projector
check the wireing in the new bulb . My new one had the wires in the wrong holes like if there are 4 slots in the connector then my orignal was in slots 1 and 4 the new one was in slots 1 and 3 so I took the wire out and put it in the #4 slot and put it in and unpluged the machine and did a reset and restart and it came on green. Hope this helps.
Oct 24, 2008 | InFocus ScreenPlay 4805 Multimedia...
Bulb failures
I experienced the same thing, only to discover it was the ballast that powers the lamp. I believe INFOCUS repairs for $390.00 per the technician that I spoke with on the phone at INFOCUS.
Jun 29, 2008 | InFocus IN72 Multimedia Projector
Infocus X2
I can almost guarantee that your bulb is out. We probably have 20-30 projectors of this model in the school and bulb life averages a little over 100 hours even though they advertise 3000 hours. Infocus has been known most for their poor cooling system to the bulb over the years and most owners won't get the life expectancy of the bulb. If you remove the bulb you will find a small restrictive vent screen on the bulb and commonly it will be filled with collected dust. This model really doesn't have any removable/cleanable filtering system installed - again a cheap and poorer design then many other brands. We have decided not to purchase infocus projectors anymore in the district. They were a seller at one time because they were cheap, but because they don't last they weren't really a deal after all. Sometimes though a ballast for a projector will go out and it will be unable to power up a good bulb. I wouldn't consider fixing it because of their overall poorer reliability.  If your looking for a cheap but more reliable brand of projectors I'd steer towards Epson projectors. They tend to have lower costing projectors and bulbs then most and I have seen in person that they last well above their advertised lamp hours in different models. Their are many good brands out there but InFocus is not really one of them - they have under built projectors and poor phone support.
Hope this helps a little. - Scott
Feb 18, 2008 | Office Equipment & Supplies
2 bulbs blown.
To be honest, most people who experience short lamp life on the Infocus X2 is on the genuine infocus lamps. If you read the user opinions here, you'll know what I mean. Me personally think that the X2 lamp filter some how manage to block the vents with dust which results in inefficient cooling in effect reducing the life of the lamp. The best thing to do is vacuum the lamp filters regularly and stick to cheap lamps as the oem ones on the Infocus X2 are also no good. Or better still, just replaace the bulb on it's own from here and save a lot of money.
Jan 26, 2008 | InFocus ScreenPlay 4805 Multimedia...
InFocus Proxima DP6155 Multimedia Projector Logo
94 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
