Question about Palm Tungsten T5 - Multilingual Handheld
Fatal alert after i try to synch ....fatal alert appear then i reset but the power stay on and it freese up. I cannot turn it off . i tried reset many times but same problem persist. please help thanks
  • 29 Answers
This is a common problem with the Tungsten line, You can try doing a hard reset. This worked for my E2. If that doesn't work, the battery must be removed for a few hours. Although it still may not work after the battery removal.
** To preform a hard reset, hold down the power button, and push the reset button on the back of the unit. The top of your stylus unscrews to expose a "plastic pin" for this purpose. Keep holding down the reset button while the unit reboots. You should see a palm screen displayed while it restarts, let go of the power button and follow the instructions. Pressing up on the pad ring should erase all data.
Posted on Sep 03, 2009
When i try to sync i get a Fatal Alert MemoryMgr.c,Line:3751,Free handle?
To get rid of the Fatal Alert, perform the Hard Reset on the device.
Note:
A hard reset will erase everything on your device. All your data will be removed, and formats, preferences and other settings are restored to their factory default settings.
Follow the steps below to perform a hard reset on your device.
  1. Open your handheld.
  2. Press and hold the power button on the top panel of the handheld.
  3. While holding the power button, use the tip of your stylus or an unfolded paper clip (or similar object without a sharp tip) to gently press and release the reset button. (The reset button is the tiny hole labeled Reset on the back of the handheld.)
  4. Wait for the Palm Powered logo to appear; then release the power button.
  5. When prompted that you are about to erase all the data stored on your handheld, press Up to complete the hard reset.
  6. When prompted, complete the steps to align the screen.
Sep 21, 2009 | Palm Tungsten E2 Handheld
Fatal Alert Datamgr.c,Line7564 InvalidUniqueIDPassed I get this when I synchronize.
Perhaps you haven't tried performing a more severe reset to break the freeze. You might want to try doing a hard reset. This will erase all data from your hand held so make sure you have everything backed up on your computer so you can sync it again after the hard reset. Note, when I occasionally receive a Fatal Alert error, the Reset on-screen button almost never responds to a tap...I invariably have to depress the reset button in the back of my E2. http://kb.palmone.com/SRVS/CGI-BIN/WEBCGI.EXE?New,Kb=PalmSupportKB,ts=Palm_External2001,case=obj(26419) resets:
http://kb.palmone.com/SRVS/CGI-BIN/WEBCGI.EXE?New,Kb=PalmSupportKB,ts=Palm_External2001,case=obj(887) Depending on a variety of factors including the available memory on your E2 and other installed applications, the problem might or night not be caused directly by the program you were trying out. But once you get the E2 unfrozen, you should refer to this article to troubleshoot the cause of this apparent software conflict:
http://kb.palmone.com/SRVS/CGI-BIN/WEBCGI.EXE?New,Kb=PalmSupportKB,ts=Palm_External2001,Case=obj(27908) Also, I recommend going to the developer of the software you are using, to determine whether there are any compatibility issues at their end, and whether they have an upgrade available.
Here are the directions for the hard reset.
1. Press and hold down the power button.
2. While holding down the power button, use the tip of your stylus (or a similar object without a sharp tip) to gently press and release the reset button inside the hole on the back of your handheld.
3. Wait for the Palm Powered logo to appear and then release the power button.
4. When you see the message that warns you about erasing all your data please continue and then follow the on screen directions.
If this doesn't help then I recommend going to www.palm.com. From there you will need to select PDA's and then the model of yours. It will go to another screen and you should be able to contact palm via free chat. I have had to do this several times and both times I got fast service. Hope this helps.
Aug 24, 2009 | Palm Tungsten E2 Handheld
Everytime I use the search fuction I get a fatal alert message
Make sure you have over 25% remaining space on your HandHeld and try again. Otherwise try a hard reset: Hold down the power button and click the reset button.
For more help:
admin@dec-help.co.cc
DEC Electronics Limited
www.dec-help.co.cc
Feb 26, 2009 | Palm Tungsten E2 (Multilingual) Handheld
Sudden appearance of "alerte fatale" (french)
you will have to do a soft reset. Google on the web how to soft reset the palm tungsten e. It is just slightly complicated. If that does not work you may have to do a hard reset which you can also find out how to do on google but i dont think you will need to
Jan 28, 2009 | Palm Tungsten E Handheld
Tungsten e2
Take a look at your address and birthday sections and see if you can find duplicates bith in your PDA and you desktop.
Jan 05, 2009 | Palm Tungsten E2 Handheld
Fatal alert memorymgr.c,Line:3732
Just happened to me after installing ThinkOffice. There is a reset button just below the labe "Made in China" on the back of the unit. Hold that button in with your stylus.
Nov 18, 2008 | Palm Tungsten E2 Handheld
Getting a fatal alert
Make sure you have over 25% remaining space on your HandHeld and tryagain. Otherwise try a hard reset: Hold down the power button and clickthe reset button.
For more help:
www.dec-help.co.cc
Aug 14, 2008 | Palm Tungsten E2 (Multilingual) Handheld
IQue 3600 Fatal Alert
You'll have to do a hard reset. Push the reset button, then hold the power button until the Palm Power appear and then release the power button. Next it will ask if you want to erase the data. I hate to said this but select yes. No will not work. Then after the inital set up run a HotSync.
Jun 18, 2008 | Garmin iQue 3600 GPS Receiver
Fatal alert
Do you have an MP3 installed on your Palm?
You might have to reinstall it.
Jun 13, 2008 | Palm Tungsten T5 - Multilingual Handheld
Fatal alert [Memory Mgr,C,Line:3751, Free handle
Thoroughly flush (delete) documents to go using the tool below and then reinstall.
Worked for me two times over the past two years when my E2 has gotten sick.
http://support.dataviz.com/support.srch?docid=13445&pid=2000
Dec 01, 2007 | Palm Tungsten E2 Handheld
Palm Tungsten T5 - Multilingual Handheld Logo
139 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
Don Eagan
 steve
steve
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
