Question about Kenmore 22422 Top Load Washer
My washer fill with water and it does not working r spin
  • Kenmore Master
  • 3,361 Answers
The water level switch is not sending a signal to the timer to start.
If you can manually go to spin cycle and it works, replace the water level switch.
Posted on Feb 22, 2009
I have a GE spave maker Laundry that fills up with water than stops!
GE Washer Not Agitating Repair Guide
www.appliance-repair-it.com/GE-washer.html
If your washer will not agitate or spin take a look at this page GE Washer Not ... If the washer fills up with water then doesn't do anything at all and you do not hear ... if this were the problem, the water would not stop running, over-filling the tub.
GE washer spin cycle not working - ApplianceBlog
www.applianceblog.com/.../217-GE-washer-spin-cycle-not-working
Mar 12, 2005 - 10 posts - ‎3 authors
I have a GE "Spacemaker Laundry" (Stackable) model number ... Today it filled withwater initially then stopped working all together when it ... Bad motor, something jammed/seized up holding the motor back from running?
Jan 10, 2016 | GE Spacemaker Washer and Dryer Electric...
Washer is working during spin, meaning it's still
Hi, a Kenmore washer that is not filling with water may have clogged inlet screens. Place a bucket underneath the hoses to catch any leftover water. Unplug the washer and turn off the water supply. Remove the water hoses from the back of the washer and inspect the screens inside the inlet ports. Often, these clog with sediment. Clean the screens with a small toothbrush. After cleaning, reattach the hoses and turn the water supply and power back on.
Another reason the washer might not fill is something interfering with the water pump. Check the connecting hoses on the water pump to make sure they are not clogged. With the hoses disconnected, check the water pump for obstructions.
Jun 19, 2011 | Kenmore 24722 Top Load Washer
Will not fill with water but works on spin cycle
If your washer won't fill with water, but works in the spin cycle then the washer is sensing that water is in the tub. If there isn't water in the tub, then it is probably a sensor. If there is water but the spin cycle doesn't get it out, then look at the pump or control board.
Jun 08, 2011 | Maytag Washing Machines
Washer trips circuit while filling tub
Sound like the inlet valve coil may be shorted. Remove console and check wires from water valve to control. If wires look ok, the inlet valve has a problem
Mar 18, 2009 | Maytag PAV2300 Top Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Washer will not fill
not your timer / if anything its eather the water valve or the water slector switch
Nov 23, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 22422 Top Load Washer Logo
Sal De
fordexpert
 Brian Main
Brian Main
