Question about Pioneer PRO-520HD 53" Rear Projection Television
Colors are skewed on Pioneer Pro-520HD
The colors on my Pro-520HD are not aligned. I have a red shadow slightly above everything on the sceen. The TV also has a blue shadow slightly below everything. This happens in both HD and SD.
You can replace your the convergence chips on the convergence board. The board is to identify because it has a large heat sink. The convergence chips normally starts with STK... After you find the chip, you can buy online (ebay has a lot of listing) and costs around $10. If you know how to solder, it is very easy to do. I just replace the convergence chips on myPRO-610HD and it works perfectly.
Posted on May 21, 2012
    Novelist:
  • 184 Answers
The convergence P.C.B. will have to be replaced. The convergence output ICs on that board have failed. Its an expensive repair, expect to spend $350-600.
michtech
Posted on Feb 20, 2009
Red shadows on my 64 inch Pioner HD TV
It is probably in need of an alignment, which is pretty typical for rear-projection TVs. Try calling a TV technician.
Nov 14, 2013 | Pioneer SD-643HD5 64" Rear Projection...
BRIGHTNESS ON A Pioneer Pro-520HD REAR PROJECTION TV
Have you attempted to adjust the brightness setting?
Thanks,
Lee
Jul 26, 2008 | Pioneer PRO-520HD 53" Rear Projection...
Red light on back of pioneer pro-520hd
The most common issue on this model is the power board develops all kinds of bad solder connections--have to remove and in most cases hand solder the entire board.
Dec 16, 2012 | Pioneer PRO-520HD 53" Rear Projection...
Can this be connected to Apple TV?
through HDMI it should be able to im not sure but you can go to
www.google.com
search-the name of your (tv-Pioneer PRO-520HD-specs) the specs should let you know if you can or can't but most likely you should be able to
Jan 08, 2011 | Pioneer PRO-520HD 53" Rear Projection...
Horizontal and vertical lines themselves are off skew. can you adjust these convergence ines. everything else color ok
No,this tv 100% have convergence problems,it dead.Any colors lines R,G,B are mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must be replaced to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 22, 2010 | Mitsubishi WS48511 48" Rear Projection...
My Pioneer PRO-200 60 in. Rear Projection Television picture looks great however it appears to be dark and blacks all blend together on the screen.
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead 2 STK convergence ICS and some or all it resistors are dead.These parts on the convergence board must be replaced to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Nov 03, 2010 | Pioneer PRO-200 60" Rear Projection...
How do I get rid of a red shadow in the upper left of the screen?
U can't tv have parts problems.Ur tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignment anywhere in the picture,have picture colors shadows or 3D pictures look like.The tv have 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced on the tv convergence board to solved the tv convergence picture problems.The Shop,will cost u like $300-350 for parts and labors.
Oct 22, 2010 | Pioneer PRO-200 60" Rear Projection...
Picture has a red hue to it. I have checked the convergence and the lines up and stays put. The TV was working great when I turned it off and when I turned it back on this condition was present.
The problem could be a few things, check your color balance and contrast or try adjusting the guns. If its a fuzzy red haze, kind of like a halo around things, it may just be that the crt coolant fluid needs changed. I, myself, have had a problem with the tinted halo in my rear projection Toshiba tv, I replaced the crt coolant fluid and the picture returned to good as new.
May 15, 2010 | Pioneer PRO-520HD 53" Rear Projection...
Words have shadows and yellow is also blue ex football game yardage lines are yellow and then there is a blue line words are not sharp
Not familiar with this particular model but it should have a convergence menu. If so, try using the convergence menu (which is basically a cross pattern (possibly multiple ones) that you use as a reference to align your colors and make the cross pattern white. When you go to this menu and see the cross patterns, if you see the shadowing of the colors, you will know what I'm talking about. If this adjustment(s) don't work, you may have a problem in your convergence board circuitry. Wish I could be of more help but try the menu.....I've fixed 2 or 3 sets like this now. Good luck!
Jan 25, 2010 | Pioneer PRO-520HD 53" Rear Projection...
TV not working
need mor info the tv when turn on after 15 or 30 minuts works fine ?
Mar 21, 2008 | Pioneer PRO-520HD 53" Rear Projection...
Pioneer PRO-520HD 53" Rear Projection Television Logo
279 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
