Question about Sony KP-51WS500 51" Rear Projection Television
Tv Red Screen
Tv turns on with the power light flashing but the picture is normal then it starts to turn red and gets more red until it becomes completely red and then shuts off.
  • Sony Master
  • 5,138 Answers
There is only a few reasons for this problem and it is a bad video IC on RED CRT board or Defective RED TUBE disconnect CRT board at end of neck on red tube Look at IC on That board while disconnected from tube turn TV on if it keeps playing without shutting off Tube is defective.
Posted on Feb 20, 2009
Loud buzzing sound from tv with no picture
It sounds as though your SMPS is seriously faulty and normally one can buy a kit to correct the problem if you are a TV engineer, however there could also be many other reason for the condition that you describe its almost impossible to guess correctly, it really needs a qualified engineer to assess the problem along with he or she having the set with them.
Sep 04, 2016 | Samsung PN42C450 42 in. TV
Hi, We have a 42" hslc10668phz
generally when you get a constant green light all is ok. these different lights indicate different problems within the tv. so the pattern of lights you mention suggests there is a fault of some kind (is there a troubleshooting section in your manual)? either way it needs to be looked at.
Nov 28, 2010 | Hisense Televison & Video
When i turn on the tv, it takes maybe a minute or two to turn it on.. red light flashes as it try to turn on what is wrong with the TV
The reason your television takes a while to come on and have a red light flashing before it comes on is because it is about to develop a problem and it is most likely a power problem.
If your television does not get properly shut down and power goes off on it without the proper procedures, it would start to flash the red light which is to sound a warning that your television would become faulty within a short period of time.
So ensure you go through the normal procedure in turning off your television.
Take care
Oct 08, 2010 | Samsung Televison & Video
Red lines on Sony KP51HW40 Rear projection TV
Yeah, seen that more times than I shoulda in the last 4 years. The red picture tube has a cathode to heater short. That means it's no good. That red picture tube is no longer availible. But all is not lost. There is a company that rebuilds those tubes reasonably. Most reputable tv shops will know this. The ones I've done cost around $450 out the door. One minor hitch is that with all the shipping involved the job usually takes about three weeks. That can be expidited but then the price goes up.
May 28, 2009 | Sony KP-51HW40 51" Rear Projection...
Red power light and buzzing sound with red lamp light.
My Sony lost its picture and had a flashing light. Unplugging for 36 hours solved the problem.
Mar 29, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Mar 13, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Red Light Flashing 6 times
When the lamp fails in this unit, often the thermal fuse opens. The error code is 6 blinks. To replace this part requires a great deal of deal of disassembly.
Mar 29, 2008 | Sony KDF-E55A20 55 in. LCD Television
Initially No Picture when Turned on but sound normal and 5 minutes later Picture is all RED and then Picture becomes NORMAL (all normal colors)
theres a high voltage block that all three of the anode leads attach to and sometimes a small crack happens across this block and will not let some or all of the crt's get the high voltage all at once untill it heats up a bit. now if this is not your problem i would make sure that all three crt sockets are attached to there tubes all the way as maybe justy maybe there loose and will only work after ther expand a bit. Now another problem that could cause this problem to occor origially would be that someone left off a crt ground strap and the crt arched and popped and caused the problem with the High voltage block. And no I cant see a tube being bad then comming on at first UNLESS when you say the red comes on is the picture all red with small retrace lines(small white lines)in the screen with no picture except for red???? No video only a red blank screen is what i mean. If thats what its doing then yes Ive seen heater to cathode shorts on a picture tube that would cause this problem but to be sure your really gonna need to have the set looked at.. Good Luck
May 17, 2006 | Toshiba 40H80 40" Rear Projection...
Sony KP-51WS500 51" Rear Projection Television Logo
321 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
