Question about Panasonic KX-FLB756 Plain Paper Laser Fax
Dear Sir! Panasonic KX-FLB758 drum problem
Dear Sir! After having installed a new drum, Panasonic KX-FLB758 still shows the error report "change drum". Where can be the problem?
4 Suggested Answers
  • 22 Answers
SOURCE: Panasonic KX-FL512 fax drum life error
You need to follow the instructions that came with the drum as you need to reset the internal counter.
Posted on Dec 07, 2009
adil_bhaldar
  • 23 Answers
SOURCE: Panasonic KX-FL511 fax, have replaced the drum kit
after replacement of drum when you close the the cover just wait for few seconds to reset the drum
machine will take one cycle. do not open lid before comletion of reset cycle done.
Posted on Apr 01, 2010
Testimonial: "Sounds like this might work. Will try it on the next drum replacement. Thanks..."
SOURCE: I need drivers Panasonic KX-FLB758
KX-FLB758 was apparently a clone of KX-FLB756 and KX-FLB751 model. Drivers available on the following page should work fine:
http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Fax-Printers/Laser-Multifunction-Fax/Drivers-Downloads/model.KX-FLB756.D#ts
Posted on Oct 05, 2011
I am receiving an error in panasonic fax machine KX-MB2025 REPLACE THE DRUM AND CHANGE SUPPLIES
It's not an error - you have to maintenance it and supply new (or refurbished) to get that gone.
May 20, 2014 | Panasonic KX-MB781 All-In-One Laser...
Change drum error in panasonic kx-mb1900
Dear friend , you guided about Brother printers not for Panasonic . There is no any option key on the panel of Panasonic kxmb1900 .
Dec 14, 2012 | Brother IntelliFAX 3800 Plain Paper Laser...
How to reset panasonic kx-mb772
call service 17 in panasonic MB-1500
Dec 13, 2011 | Panasonic KX-MB 772
I need drivers Panasonic KX-FLB758 for windows 7 please... thank I´m from Argentina
Aug 19, 2010 | Panasonic KX-FLB756 Plain Paper Laser Fax
Panasonic KX-FL511 fax, have replaced the drum kit twice now, following the install instructions with drum (and same instructions in manual). Machine still will not reset counter or recognize the new...
Feb 12, 2010 | Panasonic KX-FL511 Plain Paper Laser Fax
Dec 06, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
"DRUM LIFE OVER" KX-FL511
just change with new drum and toner.after replacing when msg gone just press start.u will receive ur faxes in memory.MIAN AKHLAQ
Dec 31, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
Drum life over
have u changed it with new one or used .process in fax when we replace it with new one it take some time for running .when it complete his circle error finishes from memory .if machine is off in this time or any other trouble it will create the problem .just take a drum from any same fax and put this in fax after running i think error will disapeear.
Dec 16, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
Printing not working well
the thermal head, scanner and the body. should be given focus on this problem. if the scanner is not copying well it needs cleaning by wiping the glass part with a alcohol in a cotton bud. if the scanner is really okay then the thermal head is not printing properly so it needs a thermal head replacing . or both are okay. the body is having problem. there must be a dis allignment on the said components. then this is the time to bring your fax machine to the panasonic shop center to do a further check and replace what is needed to be replace.
also try to check if you installed the toner and drum properly by following the installation instruction.
hope this could help you.
Mar 29, 2008 | Panasonic KX-FLB756 Plain Paper Laser Fax
Panasonic KX-FLB756 Plain Paper Laser Fax Logo
224 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
