Question about HP DesignJet 750c plus InkJet Printer
Hp design jet 750c plus. while plotting auto cad drawing,i command it to plot black/white (mono) but it plots all in color instead.I selected mono button on the printer as well.
  • alkl6 Feb 20, 2009
    I knew about what you mentioned and had tried earlier,it didn't heip
  • alkl6 Feb 21, 2009
    whatever you mentioned I had tried earlier, it didn't help
  • 53 Answers
Your plotter driver needs to be set to either black or greyscale. The driver will overide the settings on the plotter unless you set up the plotter in manual. ie the pen thicknesses, colour etc are set in the control panel to manual. The driver takes priority always.
Posted on Feb 20, 2009
How should I set my ti 83 plus for my statistics course? I keep trying to sort L1 in ascending order and every time I get ERR: INVALID DIM 1: QUIT ...
If some of the lists are missing press the STAT button then select SetUpEditor and ENTER to restore all of them (without data, of course.)
If the statistical plots are turned OFF you can turn one of them back ON again. Press SHIFT Y1= to access STAT PLOTS. Press 4:Plots Off. A good habit to avoid problems. After you turn all plots OFF, you must turn one of them ON if you intend to draw statistical graphs. You can for example Turn Plot1 ON.
  1. To do so Press SHIFT Y1=, select say 1:Plot 1 ENTER.
  2. Highlight ON and press ENTER.
  3. Press DownArrow to move to line TYPE
  4. Then you can set the plot type. You have 6 choices. Use the left/Right arrows to select one of the 6. The selected plot type icon will remain highlighted when cursor is moved.
  5. Use DownArrow to move to XLIST line and select the x-values LIST. etc.
  6. When finished Press 2nd QUIT to exit the stat plts configuration settings.
One statistical value that may be of interest to you is the R, R^2 coefficients. To have it displayed (if the regression model has it), you must set DiagnosticsON.
Press SHIFT 0 to enter catalog. Press x^-1 key to jump to the first command that starts with D.
Scroll down to reach DiagnosticsON, highlight it and press ENTER then ENTER.
Sep 16, 2011 | Texas Instruments TI-83 Plus Calculator
Color won't print! Test shows continuity.
I stand corrected, but this sounds strange. The black cartrige on a 650c is a no40, the colors are No50. It is impossible to place a color cartrige in the black posotion. You must remove all your cartriges and wipe them off at the bottom with a very hot wet cloth (not boiling) Let them stand on the wet cloth for quite some time and then give them a good shake (dont be shy). Be VERY careful not to get ink on your clothes or nearby objects. Once you have done this wipe them down again with a dry lint free cloth or tissue paper and try again.
May 18, 2009 | HP DesignJet 750c plus InkJet Printer
When i try to graph a scatter plot on my ti-83 plus it says ERR:INVALID DIM or it gives me a blank graph, how do i graph it?
Your stat plots are on, and may not be filled out/ correctly filled out.
go to [Y=] and go up to the stat plots ([Plot 1], [Plot 2], [Plot 3] ) and turn off the ones that are "ON" ( highlighed black w/ white text.) and press [ENTER] on the ones that are on and the problem is no more.
May 12, 2009 | Texas Instruments TI-83 Plus Silver...
Why does the plotter use color even if we do not plot in color?
If you print in some CAD programm try the following....
Print Target:Line Drawing
Color Mode:Color CAD when the CTB is color and Monochrome when the CTB is monochrome
Resolution:Draft 600
For your situation use CTB monochrome and ColorMode Monochrome.
The print head prints max resolution 2400X1200
Jan 28, 2009 | Canon iPF700 InkJet Printer
Incomplete Plot of PDF file
This is a common problem on the 500 range, not so common on the 1050. A quick way around the problem (using the parallel port only) is to load the HP Designjet 750c drivers. Send the drawing to the 750 using memory in computer option and it WILL print.
Jan 12, 2009 | HP DesignJet 1050c plus InkJet Printer
Partial plot
if connected via ethernet cable then i believe you have a bad network card, if connected via parrallel, then check to make sure the cable is not over 15 feet in length. also try to uninstall and reinstall the drivers on your computer as they sometimes become corrupt. Good luck!
Aug 17, 2008 | HP DesignJet 750c plus InkJet Printer
HP 755CM
**you need a good driver:
whilst ordinary printer drivers may treat plotters like very large, slow, desktop printers, our driver uses the native vector graphics capabilities of your large format plotter to render CAD and line drawings at maximum speed.
Go here
Third Party Product;
and they are those recommended from HP, Autodesk and work great with Corel Draw, Power Point, Micrografx Designer, EXCELL, Lotus, Word and all vectorial-oriented Windows applications, under W95, W98, WME, NT 4.0, W2000, WinXP, Win VISTA.
You'll find all informations
Aug 08, 2008 | HP DesignJet 750c plus InkJet Printer
HP DesignJet 750c plus InkJet Printer Logo
349 people viewed this question
Ben Johnson
