Question about Nikon D50 Digital Camera with 18-55mm Lens
Nikin D50 autofocus
Has worked fine for 3 years but suddenly just stopped auto focusing.
  • scu62578 Mar 26, 2009
    all the button are on the auto sections put another lens in and it works put mine back on it sdoesnt
  • leon7877 Apr 06, 2009
    auto focus doest work. Also, the lens won't seat tight and flush. The screws on ring act like the are stripped. Anyone know if the two are related. The autofocus failed first. Any ideas?
I figured out that when changing lenses my finger must have hit the little switch and flipped it over to manual focus. I changed it back and it now works. Thanks.
Posted on Feb 20, 2009
Nikon D50 will not autofocus, the menue item 02 Autofocus is no highlighed and I can not set it
You should check two switches.
First, on your lens, be sure it's set to M/MA not M. That puts the lens in auto focus mode.
On the camera there should be a switch that shows C/S/M. If switched to M, it's on manual focus. Change this to S for single auto focus or C for continuous auto focus.
Jul 02, 2014 | Nikon D50 Digital Camera
Autofocus problem with 70-300mm is usm
Replace the broken ribbon cable in the lens
Sep 23, 2012 | Canon EF 70-300mm f/4-5.6 IS USM Lens
Nikon D50 with Nikon DX 18-55 lens will not focus
Sorry to hear about your lens. If you are able to autofocus and take pictures with any other lens, then it means that your problem lies with the kit lens. If you can take picture in manual mode, but not in autofocus mode, then the AF motor in the lens in not functioning. I had the same thing happen to my 50mm 1.4 lens.
Depending on your location, there are Nikon repair centers in Melville, NY and Torrance, CA.
Hope this helps,
Andrew
Apr 16, 2010 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
Nikon d40 autofocus
Look on the left side of the lens. Make sure the button is on A for auto focus and not M for manual. OR not stuck in the middle. Hopefully that will solve the problem.
Jul 11, 2008 | Nikon D40x Digital Camera
Nikkon d50 wont auto focus
the D50 will only auto focus with an AF-S lens...make sure you are using an AF-S lens.
Also, check the swithc on the lens is set to "A" not "M" ...
Also, in the menu, check you set the camera as autofocus, not manual focus
Jun 07, 2008 | Nikon Cameras
Nikon D80 Autofocus problem
sir, replace ur lens image reading sensor
Apr 06, 2008 | Nikon D50 Digital Camera
Nikon D50 Does Not Autofocus
replace the lithium battery 1.5X2 . then press then ok good, but does not work the drive motor was broken.
Nov 05, 2007 | Nikon D50 Digital Camera with 18-55mm Lens
Camera won't autofocus
Auto-focus technology on this camera is controlled by several contacts on the mount that physically mate with other contacts on your lens. It sounds like your mount may be malfunctioning due to wear and tear (if cleaning does not work). This is between $100 and $300 fix depending on which part(s) need replacement.
Oct 24, 2007 | Nikon D50 Digital Camera
Won't autofocus
First try another lens on the body and see if the problem is the lens or the body,if its the body the autofocus mirror could be out of adjustment, if its the lens, it sounds like the lens took an impact and needs a pro repair. you should be able to set body to manual focus and focus lens to infinty.
Jun 11, 2007 | Nikon D50 Digital Camera
Nikon D50 Digital Camera with 18-55mm Lens Logo
186 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
