Question about Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook
2007 white macbook, battery is full, unit will
2007 white macbook, battery is full, unit will not power up not matter what i tried. even pluged in.
  • Krabby May 11, 2010
    Does the unit turn on and just not complete the start up, or is it dead
  • Anonymous May 11, 2010
    What have you tried? Have you cleared the PMU? The PRAM? What symptoms did it show before this happened?
    Problem Solver:
  • 5 Answers
Try tacking the battery out. Holding down the power button for about 10 seconds and then putting the battery back in and giving it a go...
It resets the power management system
Posted on Feb 28, 2009
How do I fix my greyed out volumes in my Seagate 4 TB external drive?
Is it formatted to FAT by any chance?
Have you tried pluging it into another mac?
Or even a to a Windows PC?
Oct 15, 2016 | Apple Customized 15" MacBook Pro Laptop...
Why wont my computer turn on macbook air. what do you think?
could be a number of things including the power block faulty, a break in the power lead, the power regulator in the macbook or even it's just plain old dead. if the macbook lights come on when it's plugged in and nothing else happens when you press the power button, odds on it's just dead.
Jan 30, 2015 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Wq7301kxya2
According to EveryMac and the serial number you provided (assuming the hard drive has not been replaced in this unit and the original factory shipped Apple drive is still in there):
http://www.everymac.com/systems/apple/macbook/specs/macbook-core-2-duo-2.0-white-13-mid-2007-specs.html
Looks like you have a brand-name 80GB SATA 1.5Gbps 5400RPM 2.5" hard drive in there.
If you need to replace the drive, typically any current day 2.5" SATA hard drive or 2.5" SSD will work within the unit.
Hope this helps!
Aug 19, 2014 | Apple MacBook 13"White /2.0Ghz Intel Core2...
White macbook charging problem
Make sure that your power cord and magsafe port are both clean. Reset the NVRAM (http://support.apple.com/kb/HT1379). If you have another cord, try that. Also try removing the battery and checking the connection between the battery and the connector. If all else fails, your battery is probably going bad.
Nov 12, 2012 | Apple MacBook 13"White /2.0Ghz Intel Core2...
When I turn my MacBook air on a blank White screen
Leave the Macbook air turned on until the battery goes dead. Then Connect to power and start it up. That should solve the problem. You problem was caused by not letting an update install in full.
Dec 16, 2009 | Apple MacBook Air
Black macbook 13 will not boot.
you have logic board problem, check out if the fan, processor , harddisk working if not then it is logic board.
go to apple care and get the assistent.
plz rate this article. if you satisfy..
Jul 10, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
No power
Try this: - Turn machine off; remove power cord; remove battery. - Without battery or power cord, press the power button and hold it down for at least 10 seconds. This discharges power 'residue' in the machine [and, I suspect gremlins]. - Reassemble power cord and battery. - Restart.
Mar 19, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Completely white/gray screen
First try this: shut it down, disconnect the power cord, pull out the battery, then hold the power button for a full 10 seconds. Reinstall the battery, reattach the power cord, turn it back on.
Still doing it? Put the reboot disk that your Mac came with, or the disk to the version of Mac OS X that you're running.
To start from disk hold "C" as your Mac is first turning on from a complete shutdown.
Dan Crowley, iKnowApple.com 919.280.3101
Nov 08, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Battery?
Could be a disc error. Make sure your battery is in the correct way as it can go in 2 different ways. Line the slots on the battery to the prongs on the laptop. Before I go on, it may be you battery is dead for some reason?
Go to applications folder, find disc utility and hit "repair disc" it will come up with ANY problems your computer is having. You will then have the option to "fix errors"
Try that.
Jun 21, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Not powering up
sound like the power connection may have broken therefore not allowing the unit to switch on or charge.Do any lights flicker when you plug it in?
Replacement part should do it
May 09, 2008 | IBM ThinkPad T20 2647 Notebook
Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook Logo
103 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
