Question about NetGear FS605 - 5-Port 10/100 Network Switch (Recertified) (FS605NAR)
I bought a netgear FS605 swtich and it doesn't work on the ps3.
I only have a switch, no router. i bought a netgear FS605 switch that i connected to my modem, PC, and ps3. my PC could access the internet but my ps3 cannot. The switch has plug-and-play capabilities. my playstation 3 could not auto detect the connect. i manually put in my IP and DNS. it detects my IP succesfully but once it is checking for internet connection it fails and it says DNS error. i already put in the values in the manual setup with the numbers i get in the command prompt: ipconfig /all. I type all of the values exactly as it says on my computer but still no luck.
Please help me out with this problem i would great appreciate it.
  • 2 more comments
  • morris_glr Feb 20, 2009
    i just looked up my internet settings in my pc and i manually put in the ip address numbers, subnet mask, primary dns, and secondary dns. the same values on my pc. are you sure i NEED to by a router and there is no way around this problem?
  • morris_glr Feb 21, 2009
    my modem is an Arris TM502G
  • Jatin Wig May 11, 2010
    What is the model number on your modem?
    a router may not be necessary some modems have built in router functionality.
  • George Bill
    George Bill May 11, 2010
    You need a router not a switch
  • 31 Answers
Yes you must by a router my friend.
The problem is your ISP will not give out extra Ip addresses for additional clients. The router will have a dhcp server built in and that will fix the problems at hand.
Posted on Apr 09, 2009
My Netgear FS605 stopped working. All lights flashing about 1x/sec. No change in cabling or configuration in past year. Upstream Linksys N wireless router working fine. Tried disconnectring ethernet...
Are you able to ping between systems connected to the same Netgear FS605 switch and in same VLAN.
I suspect either switch port or Uplink cable issue.
Please try changing a new cable and if no improvement then please try with a different switch port.
Jan 08, 2011 | NetGear FS605 (FS605SE) Networking Switch
Problem connecting to internet while pc and ps3 are hooked simultaneously
I think the broadband connection you are using is not enabled for NAT ( Network Address Translation).
This is required to give internet access to more than one system through a single internet connection.
If NAT is not enabled or supported by your broadband router then you cant access internet through more than one system simultaneously.
Jan 07, 2011 | NetGear FS605 (FS605SE) Networking Switch
Ps3 problem on NetGear NETGEAR WNDR3300 - RangeMax Dual Band Wireless-N Router everytime we go through the easy set up it the test fails. we spent 3 hours last night trying to manually add the ip address...
if you are going wireless have you typed in the encryption to gain access to the router. in the setup of the ps3 does is ask for passphrase or encryption........ plus it seems it would want to search for available wireless connectivity.......but you may be going hardline with ethernet straight in to the ps3 then it should be almost an automatic type connection set up should be easy.....but the thing i have experienced is that not all modems are compatible with game stations...........there maybe a list of compatible modems for your system..... give me more info on how you are trying to acquire.....so i can further assist
Dec 28, 2009 | NetGear WNDR3300 - RangeMax Dual Band...
Router failed numerous times so i bought a netgear fs605 5 port switch to hard wire in a ps3 and my dell lap top. can only run one or the other. not both at the same time. what is wrong?
The FS605 is a switch, not a router. You can only run one device at at time because you only have one ip address. You need a router between the internet and your switch if you want to use more than one device at a time.
Dec 08, 2008 | NetGear GS605 5x1000 Mbps Networking...
Laptop with broadband internet and router. how to connect PS3?
This is what you have to do:
First, disconnected the router form the PS3.
Connect the router to the incoming cable and setup from the laptop using the setup wizard.
Once you have connected to the IPS then disconnect the router, connected the PS3, then the router.
You should be able to connect to the Internet.
If you have any question related to this router, please consult your router hand book, or repost your question or e-mail me at frcs68@hotmail.com,
since this router has several feature, need to configure in order to secured the net work.
Nov 10, 2008 | Sony Playstation 3 (PS3) Console
Connection issue
put the blue cable connection with the router and cable modem first.configure wireless setup.put the desktop rj45 connection to a free router rj45port.As u are getting internet on wireless check the desktop ip configuration.obtain auto ip configuration should be clicked.
Jun 28, 2008 | NetGear FS605 - 5-Port 10/100 Network...
Wont connect and software cd
To connect a router or a dsl modem to a switch you either have to use port 4 or use a utp crossover cable. As you can see on the Netgear FS605 the modem/router has to be connected to port 4.
The correct way to connect these devices is:
Modem > Router > Switch > Computers
Jan 14, 2008 | NetGear FS605 (FS605SE) Networking Switch
Wont Switch on
Test power in its adapter up to the plug in end of the switch adapter. The power adapters are usually the culprit. If there's power in the wall plug, that leaves you with the switch itself. It's either bad inside or should come on.
Nov 17, 2007 | NetGear FS605 (FS605SE) Networking Switch
Only 1 computer getting internet with FS605
Sorry to say, you have the wrong part. Whoever told you you could hook it up to both your PCs and your cable modem didn't know what they were talking about.
Your FS605 is just a switch; hooked up directly to a cable modem, you will only see one IP address as that's all the cable modem will allocate.
What you need is a router, to allocate multiple local IP addresses and share the connection up to the cable modem.
Linksys BEFSR41 routers are ridiculously cheap these days and highly reliable, or if you like Netgear, you'll need the RP614.
Nov 07, 2007 | NetGear FS605 (FS605SE) Networking Switch
NetGear FS605 - 5-Port 10/100 Network Switch (Recertified) (FS605NAR) Logo
1,072 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
