Question about Dell UltraSharp 1800FP 18.1" LCD Flat Panel Monitor
1800FP green LED is on, screen is black
My 1800FP has green LED on, but screen is totally black. The VGA signal is good. The power supply has 5V and 12V. Based on the comments, I bought an inverter over eBay, and replaced the old one. But the problem remains. What else could go wrong? Any comments are help and are appreciated.
Thanks,
jim60007@gmail.com
  • 558 Answers
Power pack has issues could be a chip on the power pack or some capacitors on the power pack. the power pack supplies power to the inverter.
Posted on Apr 05, 2009
I fixed my broken HP L1906! Couple new capacitors in power supply board and it could be powered up. Green led (for power) is on, monitor begin to circle 18 times - red, blue, green white horizontal...
SCREEN DAY.
BUT NO PHOTO POSTED, worth 1000 words each,
can be lots of things ,
bad power supply, something shorted. caps but in backwards.
+ to + and - to - works only. or the short. every time.
there is no schematic,
leaving what?, guessing ? and buying used parts on ebay
expensive to do that.
i presume the OSD button is dead ,right?
the power button tells you its a hard failure, it did.
The L19xxxx has CCFL back lamps, most did.
so seems they work ok , to see color takes that working.
but power is first ,that mean not just 5v.
Jul 31, 2017 | HP L1906 19" LCD Monitor
My computer just died the morning. I removed the
red- +5v
yellow- +12v
orange - +3.3
black- 0v
blue- -12v
white - -5v
green - ps-on(+5v)
gray- power good(+5v)
purple- stand by (+5v)
disconnect smps from motherboard give the power to smps and short green and black wires and measure the above voltages
Mar 19, 2010 | Antec SmartPower 2 SP400 400-Watt Power...
Trying to find wich two or more wires from wiring harness turn on power supply for a compaq presario 7594
In ATX PC power supplies, here is the wiring scheme:
Green: PS-ON (+5V)
Gray: PWR OK (+5V)
Purple: +5VSB
Blue: -12V
White: -5V
Orange: +3.3V
Red: +5V
Yellow: +12V
Black: Ground (AKA Common)
Use a paper clip to connect the GREEN wire and a BLACK wire. There should be a black one right next to the green. This is how I test PSUs before and after I repair them. Now it should be running, assuming there are no internal problems.
You can also connect the GRAY to ground with an LED. Not necessary, but I like to do it ;)
Nov 24, 2009 | Computers & Internet
VGA connector wiring detail
Pink - red input - pin 1 green - green input - pin 2 blue - blue input - pin 3 ground shield wire - pin 6,7,8 and 10 black - ddc 5v - pin 9 violet - screen raster - pin 11 white - data or sda - pin 12 orange - clock or scl - pin 15 yellow - vertical signal - pin 14 clear - horizontal signal - pin 13
Sep 11, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
With VGA input the screen randomly flashes on and off
power control chip of the VGA input screen is not controling the input settings
Jun 29, 2009 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Led flashing no picture
disconnect the signal cable from the computer. if it shows color bars, it means your monitor is ok and your video card is faulty. if it still does the same thing. you need to reseat the video card if its not integrated.
hope this helps.
Apr 09, 2009 | Dell 1800FP Monitor
Pin Name Color Description
Yes this is a good list of the voltages to be expected from a newer power supply on just the main header
Apr 01, 2009 | HP Compaq dc7100 PC Desktop
Dell 1800FP, no signal found (analog). Green LED on, get message
check if your signal cable is properly connected to your system unit and make sure that non of the pins of your signal cable is broken.if any of the pins are broken,try and change the whole signal cable and re-connect it again
after following the above instruction,reboot your computer
thank you for contacting as with your problems,you are always welcomed
Jan 26, 2009 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Dell moniter
The power supply has most likely gone out. Check for 12v and 5v output and also the solder arround d903 and d907. The site www.lcdrepair.us sells the part as well as a repair kit and has instructions.
May 24, 2008 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Dell UltraSharp 1800FP, green power light, black screen....
Its probably the inverter that lights up the screen that went bad.I have replaced inverter before with much sucess. If you feel comfortable opening the unit up I found one on ebay. Here is the link.
http://cgi.ebay.com/1800FP-LM181E06-FPD1830-18-LCD-Inverter-KUBNKM045A_W0QQitemZ300179625342QQihZ020QQcategoryZ74936QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Dec 09, 2007 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Dell UltraSharp 1800FP 18.1" LCD Flat Panel Monitor Logo
385 people viewed this question
Alun Cox
