Question about Kenmore Dishwashers
Dishwasher not filling
Kenmore dishwasher model 665-16769000 not filling. During fill cycle the fill solenoid gets voltage but it's only 5 volts. Is it supposed to be 120 volts? Thanks. Hate to replace the fill solenoid and it's not the problem.
  • 117 Answers
Yes you should have 120v to the valve so the problem is elsewhere. Possibly the control isn't sending the proper voltage but you will need a tech to verify as this board is about $130
http://tclaundryrepair.com/
Posted on Feb 20, 2009
Indesit de3542 starts to go but stops after about 30 seconds
That is a discharging problem. What you can try initially is turn it off and unplug the power cable for about 2-3 hours to release any static charges. Then plug it back in. If that doesn't work, there's an internal electronics component that needs to be check. Discharging is a capacitor problem. There might a burned or bulged capacitor that needs to be replaced.
Oct 04, 2008 | Dishwashers
Water fill solenoid receives only 10 volts on normal cycle-not enough juice to open solenoid. Dishwasher does not fill. Dishwasher works fine on short cycle because on that setting the control panel...
It's most likely the timer set the timer to when it is gonna fill to a normal wash hook up a volt meter when it is in its fill stage make sure it is putting out 120 volts
Mar 18, 2013 | GE Nautilus 24" Built-in Dishwasher
Why doesnt my washer put out cold water
either the hose screen inside the fill hose is plugged with lime/rust/etc. or the water solenoid is defective or not getting power from the controls,on some fill valves there is a thermistor that senses water temps as it fills and this part could also be defective,you can test this valve with a cheater cord to see if it opens,or unplug the machine and use an ohmmeter to test the solenoids coil for continuity,if good plug it in and check for voltage(normally 120 volts A.C.)on the solenoids terminals during the fill cycle
Nov 19, 2012 | Amana Washing Machines
Kenmore 17621 model--wife says it's making all the right noises,but no water entering.removed bottom panel-no filter visible.obstruction in water supply line is my guess.
Open the door and look for the water level float in the bottom of the dishwasher.
Make sure there is nothing stuck under the float holding it in the up position.
Wiggle the float up and down to make sure it can move freely and then run the dishwasher again to see if it fills with water.
If the float is not stuck up then chances are you will need to replace the water inlet valve.
If you know how to use a volt meter you could check to see if voltage is at the valve during the fill cycle. If there is voltage to the valve but you are not getting any water then you know the water inlet valve is bad for sure.
I find that 90% of the time I need to replace the water valve on dishwasher that no longer fill with water and the other 10% of the time I find the water float is stuck.
Aug 07, 2011 | Kenmore Dishwashers
Dishwasher water will not circulate
The pump or motor is not working check if the motor is getting voltage about 115 volt during the wash cycle
Aug 04, 2009 | Dishwashers
GE Dishwasher won't fill (Tested valve and switches)
check thermostat it maybe overheat and gives a false signal that water is warm,it is on bottom.
Feb 17, 2009 | Kenmore Elite 45986 Front Load Washer
No water in unit
My dishwasher will not fill with water: This is often the fill valve. You can test the fill valve coil for continuity with a ohm meter, no needle movement = bad fill valve. You can also test the fill valve for 120 volts at the fill valve with a volt meter, power there and no fill = bad fill valve. No 120 volts there, you will have to trace power back to find the trouble maker. Test things like the float and float switch, wires and timer. Fill valves are very bad for working once or twice and then quitting, if your dishwasher fills the first and second fill cycles and then no more water through the rest of the cycle, replace the fill valve. You will need to remove the access panels to get at the fill valve. Dishwasher fill valves also have a screen built into the valve entrance, this can also get all clogged up and need to be cleaned.
Dec 14, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore dishwasher 58715142400 fills but doesn't wash
Motor has gone out..just like mine...Make sure u have voltage going to the motor, (disconnect the plug from the motor) and use an electric meter to make sure you have voltage going to the motor. If so the motor has either gone out or has been blocked by something! If no noise except clicking then motor has gone out. Looking at about $150 for motor.
Jan 26, 2008 | Kenmore 24 in. 15142 Built-in Dishwasher
Dishwashers Logo
230 people viewed this question
Top Kenmore Dishwashers Experts
D. E. Hev
Fred Sops
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
