Question about InFocus IN38 Projector
InFocus IN38 projector shuts off
I run a business which has 8 InFocus IN38 projectors; we run each one approx. 7-8 hours each day. We vacuum/blow them out weekly. They are hung from the ceiling. All are fairly new (500 hours or less). Within the last couple of months, four of them have started shutting off at random times, usually within 15 minutes of starting them up in the morning. We then unplug them for 2 minutes, and plug them back in, and this usually fixes things.
Is this an overheating problem? Any suggestions?
  • jasbo
    jasbo May 11, 2010
    are any of the led indicators blinking? and if so, which ones, what color, and how often?
Hello, I just wanted to drop a line to thank the AVS members who posted this thread and add my 2 cents. I too was victim to the sorry about your luck attitude of infocus when my projector suddenly stoped working. I did exactly as many of you have done and tore apart the unit (after my 3 different calls to IF). I found the 1A fuse blown after only 400 hours of total use. So no biggie. replaced it with a 1.5A fuse, and a fuse holder. Well, after about 3 hours... Dead again. So I read online that most failures are in the inverted position. (ceiling mount). I figure as many have heat must be the enemy. I removed the side infocus covers and carefully cut out the black plastic end panels. my temp gun reads 20 deg f less out put temp and the air flow is much stronger. Take 3...invite family and friends over, mid movie and zap. Nothing. So I replace the fuse with a 2.0A slow blow. This last a little longer. I get about 5 hours and zap again. So i figure i will just have to keep replacing the fuse on my 800 dollar paper weight. But the plot thickens... While upgrading my surround with a new hdmi switching receiver (onkyo 805) I discover I have a serious buzzing problem. The problem disappears when I unplug the hdmi to the projector. Having a background in pro audio I know that i have a ground loop issue. So i have 2 options. remove the sheild drain from the hdmi cable or remover the ground lug on the infocus. So I remove the ground lug terminal on the power wire of the projector and woohoo. no more buzz. And believe me I was very happy to have a low noise floor again. But I also solved the fuse popping issue as well by complete accident. As after I removed the ground lug I have never blow another fuse and now have close to 1200 hours on the projector. It also fixed some odd problems that I was having with coloration of the the lower right corner of the screen and a light flickering problem I was having. And FYI all my audio and video equipment runs through a monster power rack mount conditioner so I am fairly confident that the problems I was having weren't caused by "dirty power". during testing for the buzz I even removed the conditioner temporally to make sure it wasn't bad with no change. So I hope this helps someone out there in the same boat. Good luck! -Bill user_offline.gif
Posted on Mar 30, 2009
  • 2237 Answers
SOURCE: InFocus IN72 shuts off after 20 min.
internal error. if the lamp looks ok and it doesn't have many hours on it, it might be the power supply. the capacitors dry out and do not supply sufficient voltage. the in72s do have that problem.
Posted on Aug 27, 2009
  • 2237 Answers
SOURCE: InFocus LP120 Projector shuts off automatically
overheating or power supply problem.
Posted on Sep 03, 2009
  • 3866 Answers
SOURCE: Infocus X10 projector overheating.
okay most people think well its not hot up there but truely it is hot toward the cealing. If its overheating on the roof mount try to use a wall mount instead.. If they have it running for 5 days streight then is something your not oding right here and that might be the mount.
Posted on Nov 10, 2009
  • 167 Answers
SOURCE: Projector image is too large for screen
There are no other lenses for the LP600 :(
Posted on Dec 30, 2009
The bulb dont turn on
Projector Lamp Life and Brightness - Projector Reviews
Feb 26, 2015 - There are still a number of 2000 hours at full power projector still on the... brighter, like projector Y, but Y just doesn't have the picture quality.".
Resetting Lamp Hours on a Sharp Projector - Spiceworks
Jun 12, 2011 - However, once you change the lamp the projector still won't turn on ...If it still doesn't work then there is some other problem with the projector.
How to Repair InFocus Projector Power Issue (LP290 ...
? 1:56
May 7, 2012 - Uploaded by zibodiz
A common problem with older InFocus LCD Projectors causes them to turn off at ... How to Repair InFocus Projector PowerIssue (LP290/LP280) ... How to Install a Bare Projector Lamp into your Projector - Duration: 4:05. by ..
Dec 14, 2015 | Office Equipment & Supplies
Why does Infocus IN102 projector auto shutdown after a few minutes and indicator light blinks red.
Is it possible to repair the controller board some how? Replacement is not an option because I have approx 100 projectors of this model and X16 lying with me, requiring immediate repairs...
Jan 07, 2012 | InFocus IN102 DLP Projector
Randomly won't power on. No Orange LED
first off, i believe you mean IN2102ep. go into the menu and reset the settings to factory default. then go back in and check that the auto off and screensaver modes are set to never (or wherever you want them). if you still have a problem, you may have a power supply issue. if it'still under warranty, send it in to infocus. if it's out of warranty, you can send it in to an infocus service center. try av solutions in ny. they're really good.
Dec 05, 2009 | InFocus In2102 Projector
The device is an InFocus LP 290 with less than 100 hours on the bulb. I have used the projector several times over the course of two years without any problem, but never longer than 3 hours at a time. A...
there is an issue with the power supply edge connection with the main board. you'll need to have it sent to an infocus service center for repair. try av solutions in ny. they're pretty good.
Nov 24, 2009 | InFocus LP290 1100 Lumen XGA LCD Projector...
Aug 27, 2009 | InFocus IN72 Multimedia Projector
InFocus LP130 Projector has intermittent power off
go into the menu to find out the lamp hours. it could be the lamp, but if the projector shuts down and not just the lamp, there is either an overheating issue, or a power supply issue.
Mar 07, 2009 | InFocus LP130 Replacement Projector Lamp -...
This model projector is very sensitive to internal heat. I f by some reason the projector was abruptly powered down without the use of its normal procedure, in other words, unpluging cord from wall while on or power outage in premises, then the heat remains trapped and the sensors overheat and subsequently shuts down the unit. Now, although, once the sensors cool down it should reinstate operation some sensors become permanently damaged due to the extreme heat. In this case without having more facts, i believe it is the cause. I recommend a free check up to your nearest shop, most shops will offer free check ups.
Jun 07, 2008 | InFocus IN72 Multimedia Projector
InFocus IN38 Projector Logo
69 people viewed this question
Top InFocus Office Equipment & Supplies Experts
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
