Question about IFB Washing Machines
Motor triac error - IFB Washing Machines
Hi there, my Smeg WDF12C7-1 washing machine shows up error 11. Please help. Much appreciate.
Smeg washer error code E11 means motor triac short error. The motor control triac is a small component mounted on the controller and is used to switch your motor on and off. Check the mains supply, the main control module and the main drive motor. It is also possible that the part is failing under load and needs replacing.
May 02, 2018 | Smeg Washing Machines
Wfmc3200 run diagnostic and see e20 c01 and d10 c01 codes. Bad motor or something in the drum support?
E20 error code: Short or break causing incorrect resistance in winding of the circulation pump or the motor.
D10 error code: Cause: Wiring/electrical fault related to motor triac.
Action: Check wiring on/to PCB and motor. Check the triac (on the PCB).
C01 error code: Cause: Motor tacho fault.
Action: Check motor and motor tacho wiring for problems.
Apr 19, 2015 | Bosch Washing Machines
Aeg lavatherm 57830 error code E50, what does it meann
E51 - Motor power triac short-circuited.
E52 - Intervention of motor overheating safety cut-out.
E53 - Motor triac "sensing" circuit faulty.
E54 - Motor inoperational.
Dado
Apr 23, 2014 | AEG T57800 Electric Dryer
Ewf 1229
this is a problem with a triac short by problem in a motor. The triac is electronic switch that goes in electronic control board. However you must test the motor .
God bless you
Jul 13, 2013 | Washing Machines
Zanussi zdc67550w error code 51 - whats it mean?
There are usually only two error codes beginning with E5 which are E51 and E52, which are "motor power triac short circuited" and "no signal from the motor tachometric generator" respectively.
So if you have E50 displayed on a Zanussi or John Lewis washing machine it looks like a problem with the motor. However, the E51 "motor power triac short circuited" could be a fault on one of the PC boards as triacs are usually on printed circuit boards.
This could have blown due to a short circuit somewhere else (like the motor for example). I would advise that an engineer is required if you can't see anything obvious with the motor.
Hope this helps (remember to rating this free answer and leave a testimonial comment).
Oct 13, 2011 | Washing Machines
Zanussi zdc675550w error code 51
It says error code f-01. what does it mean
Triac motor faulty or faulty motor. I had the same thing, technician said it is triac motor (150 pound) turn out to be the motor it self (about half the price)
Feb 07, 2011 | Hotpoint Aquarius WD640 Front Load...
Error message E50 shows when the machine is switch on.
Zanussi washing machines can sometimes display error code E50. As John Lewis washing machines are currently also made by Zanussi some John Lewis washing machines can also display error E50.
Unfortunately this is not a "proper" error code and is not listed in error code lists. It's part of the motor fault error code group and is apparently displayed to customers but when an engineer enters a special diagnostic display the "proper" error code will be displayed giving more information.
However, there are usually only two error codes beginning with E5 which are E51 and E52, which are "motor power triac short circuited" and "no signal from the motor tachometric generator" respectively.
So if you have E50 displayed on a Zanussi or John Lewis washing machine it looks like a problem with the motor. However, the E51 "motor power triac short circuited" could be a fault on one of the PC boards as triacs are usually on printed circuit boards. This could have blown due to a short circuit somewhere else (like the motor for example) - I would advise that an engineer is required if you can't see anything obvious with the motor.
Jan 09, 2011 | Zanussi ZWF1430W Front Load Washer
System error E000
E000 Fuser thermistor, heater thermal fuse E001 Fuser thermistor, or triac E002 Fuser thermistor, thermal fuse or triac E003 Fuser thermistor, heater, thermal fuse or triac E004 Triac or fuser won't shut off E007 Fuser film is off center or not driving properly. Might be able to reset in service mode 4-407 E010 Main motor drive problem E030 Counter E041 Paper deck motor, clutch or sensor E064 Composite power supply or main motor board E202 Scan problem. Motor sensor E210 Lens drive problem E220 Exposure lamp E240 Main board or composite power supply E260 Main board, power supply cooling fan or composite power supply E261 Composite power supply or fluctuating power E400 ADF communication to machine E401 ADF pickup motor or sensor E402 ADF belt motor drive E403 ADF feed motor or slip sensor E404 ADF exit motor E411 ADF document detect, or registration sensor or edge sensor E500 Sorter communication problem E510 Sorter drive problem E530 Stapler guide b
Jan 06, 2010 | Canon Office Equipment & Supplies
Washing Machines Logo
530 people viewed this question
Top IFB Washing Machines Experts
Eric Sutherland
Ken Strite
Ken Strite
Raj Patel
Are you an IFB Washing Machine Expert? Answer questions, earn points and help others
