Question about Dewalt 18 Volt Compact Drill Kit
The chuck what size screw is it?
  • 2,176 Answers
Usually 1/4-28 LH thread. If you give me the model number I will come up with a part number for this screw.
Posted on Feb 21, 2009
My chuck on my dewalt 18 volt comes undone in reverse its fine going forward what would be the problem
If you look at the end of the shaft on the drill after it unscrews, there will be a hole with threads inside--if not the screw may have broken off---your missing screw that holds the chuck on--it's a left handed threaded screw---it's head may be slotted--philips---torx---or allen---this is available at your Dewalt dealer or tool repair---all that needed is the size/model number of unit---screw the chuck back on tightly then open chuck jaws all the way then put the holding screw in---tighten it down---REMEMBER IT'S LEFT HANDED----GL
May 05, 2017 | Dewalt Drills
Top chuck just clicks but won't change bit size?
It sounds as though you will have to replace the chuck. Remove the screw (l/h tread) from inside the chuck first before removing it.
Feb 02, 2013 | Drills
What keyless chucks will work on my makita hammer drill will a dewalt xrp chuck work on a makita
as long as the chuck is used for a hammer drill and the thread size is exact yes it will. I believe the thread is 1/2-20 and also make sure the chuck has a hole in the center for the reversing screw to keep it from loosening up. Let me know if you need more assistance. The thread size is usually stamped on the side of the chuck. Makita sometimes used a metric thread.
Dec 31, 2011 | Makita Drills
How can I replace the keyless chuck on my Dewalt DWD215G?
Open the chuck wide open. In the center is a retaining screw, they usually have left hand threads. Remove the screw. Take an allen wrench1/4" to 3/8" in size and fasten the short side tightly in the chuck. The chucks are usually right hand thread, so take a small hammer and strike the allen wrench to turn the chuck to the left to loosen it. Once you have the chuck off, verify the thread size of the drill motor shaft, then go to McMaster-Carr and choose the one you need.
Apr 16, 2011 | Dewalt DWD215G 12Inch 10AMP Heavy Duty Mid...
We need to replace the chuck on our Bosch corded drill 1005VSR. We need detailed instructions on how to remove the chuck . Also, how can we order a new chuck?
Open the chuck wide open. In the center is a retaining screw, they usually have left hand threads. Remove the screw. Take an allen wrench 1/4" to 3/8" in size and fasten the short side tightly in the chuck. The chucks are usually right hand thread, so take a small hammer and strike the allen wrench to turn the chuck to the left to loosen it. Once you have the chuck off, verify the thread size of the drill motor shaft, then go to McMaster-Carr and choose the one you need.
Apr 15, 2011 | Bosch Drills
How do you remove the chuck from a dewalt 12 volt dw953 drill
Apr 12, 2011 | Garden
How i remove a dewalt drill chuck Model dc988
put the drill in speed setting 1 before you continue~!
Step 1. This step loosens the screw inside the chuck. Open the chuck all the way — if you see a screw inside, it’ll need to come out before you can remove the chuck. If there’s no screw inside, you can skip steps one and two.
Step 2. If there’s a screw inside the chuck, typically the threading will be left-handed, so turn it clockwise to remove it. Be careful, and use the right size screwdriver — you don’t want to strip the screw.
step-2.gif Step 3. Insert the largest hex key that you have into the chuck, short-side-in, and tighten the chuck. Tap the hex key sharply in a counterclockwise direction to loosen the chuck. Now you can remove it by hand.
step-3.gif This won’t work for every consumer drill ever made, but pretty close. Most drills will match one of two common chuck-threading standards: 3/8′-24 threaded mount for 3/8′-capacity drill chucks, and 1/2′-20 threaded mount for 1/2′-capacity drill chucks — but on some drills just the opposite may occur. To be safe, always check the thread count before you buy a replacement drill chuck.
Oct 07, 2009 | Dewalt DC988VA XRP 3 - speed 1/2" 18v...
Need to change a keyless chuck
open jaws for large size bit.look in bottom and there will be a screw slot or phillips head screw or possibly an allen head screw.remove this,by possibly turning clockwise. and then chuck up a large allen wrench. try removing the chuck by tapping wrench with hammer. this may be threaded on counterclockwise.have to try both ways.
Aug 28, 2009 | Craftsman 19.2v 3/8"drill/driver W/ Work...
How to remove the chuck
You will need 2 spanners ( the size vary's from differant models) and A screwdriver (generally phillips/star). Remove the screw that is inside the mouth of the chuck (it screws throough the back of the chuck and into the chuck shaft). Then get your 2 spanners - One goes on to the chuck and the other goes onto the shaft that the chuck attaches to. Turn the chuck anti Clockwise. This may be vary hard to do as somtime they rust and cease and you may need to brace the second spanner in a bench/table vise and use a hammer to gently tap away at the 1st spanner (the one holding the chuck). I find that spraying a litlle penatrating oil on the screw and the shaft an hour before attemting helps about 80% of the time.
hope this helps
Jun 25, 2009 | Makita DA4000LR Electric Angle Drills
Keyless chuck removal
Yes you can use any kind if chuck as long as the thread that attachs it is the same size, look on line lots of tool stores sell them cheap.
Sep 22, 2008 | Makita HP1621FK 5/8" Hammer Drill Kit with...
Dewalt 18 Volt Compact Drill Kit Logo
48 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
