Question about GE Ovens
I have a ge double oven Model zek757. A double
I have a ge double oven Model zek757. A double convection oven. The lower oven keeps going into the lock cycle and then goes back to unlock. The upper one works fine. What part need replacing?
catriver
  • 878 Answers
SOURCE: Electric Oven doen't heat
cdkd, there should be a TC0, on the back of the oven. Thermal cut out. You want to check to see if it is open. You will have to pull the oven out enough that you can remove the back panel cover and check it. The lower and upper oven should have one. It's a very cheap part to replace. If this TCO fails, no heat. Check this first before buying a new board. Catriver..post back.
Posted on Dec 27, 2006
SOURCE: Dacor Double Oven
HI - I just had the same problem - repairman came and reset the breaker in the oven which "tripped" (even tho I havent used the lower oven in months).  Read posts here on other Dacor ovens which explain how to get to the reset switch to avoid having $150 in repair costs - I have not tried that myself tho but good luck!
Posted on Nov 20, 2008
localwonder
  • 6784 Answers
SOURCE: f9 error code while using the convection baking function
This is a lock switch error code. Check wiring to door lock switch (the wire harness may be connected wrong). Check for stuck lock switch. If the switch cannot be re adjusted, it must be replaced.
Posted on Jul 30, 2009
  • 3 Answers
SOURCE: Dacor double oven, lower oven works fine, upper
I had the same problem after auto-cleaning my oven just before Thanksgiving. The cause was overheating...and the tripping of a heat sensor switch.
The switch (reset button) is located about 3 inches behind the door locking mechanism.
Removing the front panel (4 screws) that the door lock sticks through exposes the switch. Just push the little red button & your are back in business!!
Posted on Nov 27, 2009
taran_2005
  • 10515 Answers
SOURCE: I have a Bosch HBN 455 double oven with the
Do you see any Error Message on the Display?
If not, then it should not be a Concern. More often this could be Thermal Fuse on the Back of the Unit ( On Most Models ) will stop the Broil and Bake from Turning ON. You would just start a bake cycle and the temperature will sit at 100 and something degrees and never raise.appliance.
Let me know, once you check the same.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Dec 28, 2009
I have GE model#JKP45WOP2WG double oven wall unit. Lower oven isn't heating up properly. Bottom of lower oven doesn't seem as hot as the top of the oven... replaced oven sensor, not
Most double wall ovens are technically two separate oven boxes. The lower oven box has its bake, boil elements, high limit thermostat and ofcourse its own oven sensor. If the lower oven box boil is working good and less heat on bake feature may suggest that the bake element is burned out and only getting preheated with boil element. Just a suggestion here
Dec 05, 2014 | GE Ovens
Clean between the glass on double wall oven
Unscrew the handle and screws at the bottom. Carefully separate the outer panel from the frame
Apr 09, 2014 | Frigidaire FPET2785KF Professional Series...
I have a GE microwave/convection oven that the lower oven wont heat, fan comes on top microwave works but the oven wont heat
First reset your breaker, then check your wiring in the back of the oven. You may have just a wire loose.
Feb 24, 2013 | GE Profile JT965 Electric Double Oven
GE oven shuts off after 40 - 60 minutes and won't turn on again for some time
What is the exact brand and model number of the oven.Is it single door or double door oven.Is only electric or combo eclectic and convection oven.Please give more details.Is is showing any error message on display or did this problem started after you did self cleaning cycle on oven.How old is the oven or is it under warranty.---------please keep updated with the details.Thanks.Helpmech.
Mar 10, 2011 | Ovens
Elements in convection oven won't heat
DO you have a model number for that. I'm almost sure it's a thermal fuse in the back of the oven. Usually they go out during or after cleaning but that would shut down both elements. If you have the model (usually by the inside door look all over and up in the cavity) Then if you go to this link
http://www.searspartsdirect.com/partsdirect/index.action?intcmp=xsite_Sears
It will show you a breakdown of the oven and where it is. If you give me the model I'll show you what I'm talking about. Good luck.
P.S. if it the fuse it's a cheap fix, little hard to get in back of the oven but cheap!
Mar 04, 2009 | GE Ovens
Ge monogram single convection wall oven
There is usually a micro switch that is activated when the lock lever is in place - very likely this switch is still activated or has failed closed (defective) .
Aug 26, 2008 | GE Monogram ZET3058SHSS Stainless Steel...
Never used Convection JTP 5650DI55
Did you try going to the GE website? If not, try it:
http://www.geappliances.com/
When you pull up the website, you can click on the blue down arrow located in the box at the top of the web page, next to the work SEARCH and click on "USE & CARE MANUALS. Put your model number into the next box to the right and hit GO.
If you are having trouble after entering what you believe is the proper model/serial number, you can look at the FAQ (frequently asked questions) section to determine whether you have actually entered the proper number.
Aug 05, 2008 | GE Profile JTP56 Electric Double Oven
Ovens Logo
90 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
