Question about Baumatic 23 in. BDW10 Built-in Dishwasher
At end of the cycle E4 error message appears
End of the cycle the diswasher beeps continiously and an 'E4' error message appears.
I have checked to make sure the inlet tap is opened fully but the problem continues to occur. Water pressure throughout rest of the house is fine.
E4 is also related to 'the lite counter valve not working'. If this is the case, is there a way I can address this problem or does it need a technician to be called out?
SOURCE: E4 error message
take off two black covers on bottom front of machine and mop up or soak up any water you feel or see at very bottom of machine by a polystyrene float this will fix it
Posted on Apr 05, 2008
SOURCE: Error mesage E4
E4 commonly means an overflow detected in the bottom over flow tray - try removing the kick board from the front of the machine - you should see 2 plastic black panels about 4 inches wide each, using a flat edged screwdriver pop the panels off and you will see the mechanics of the machine - the base is classed as the over flow tray - when water fills this tray a polystyrene float is pushed up and an E4 error code is detected - tilt the dishwasher back and allow the machine to dry out before trying it again - this should work unless the water seal around the filter basket is broken - in this case an engineer should be called to replace this part. Hope this Helps.
Thanks
Donna
Posted on Jul 28, 2008
jonsen
  • 62 Answers
SOURCE: parmco dishwasher E4 fault, beeps at end of cycle,
go to www.searshomeservices.com they can fix it
Posted on May 23, 2010
BElectric
  • 1140 Answers
SOURCE: I have a Delonghi dishwasher,
The E4 error message could be because the water pressure is too low rather than too high. Can you let me know the exact model number of your dishwasher and I should be able to tell you more.
Regards,
BElectric
Posted on Dec 06, 2010
emissionwiz
  • 78258 Answers
SOURCE: my inlet valve appears to be closed, error E1, checked water supply is fine, machine start cycle then stops when no water gets in ?
Tap on the water inlet valve at the rear of the machine with a hammer handle and see if it may be stuck closed, this does happen on occasion.
Posted on Jan 24, 2012
Samsung front load washing machine model wf42h5000a. During rinse cycle machine stops and displays error code e4 and Cannot be reset.explain error code. What are possible solutions ?
hi Judi.
this is what i found.
If your Samsung washing machine is displaying a E4/error code on the control panel after completing the spin cycle and the clothes are still wet, we've got the solution for you. This fault is most commonly caused by an unbalanced washing machine load.
Samsung Washing Machine E4/UE Error Code ' eSpares
https://www.espares.co.uk/advice/symptom/samsung-washing-machine-e4ue-error-code
What does 4e mean on my Samsung washing machine?This is essentially a fill timeout error which will normally mean that either the water isn't on or that an inlet valve has failed or pressure switch problem check pipes as well. Water fill time out: The washing machine has failed to fill with water in a reasonable time.24 Nov 2015Samsung washing machine error code 4E and E1 Fault Not filling in ...https://www.youtube.com/watch?v=cFlnxeB0P0gSearch for: What does 4e mean on my Samsung washing machine?
or try this link.
Samsung front load washing machine error code e4 Google Search
Nov 27, 2017 | Samsung Washing Machines
Tip
LG Washing machine IE error code Solutions
An IE error code will appear if the washer has not filled with water in approximately 8 minutes.
Are the water valves opened completely?
If an IE error code appears on the washer, check to make sure both hot and cold-water taps are open completely. After both valves have been opened, unplug the washer for 10 seconds and retry the wash cycle.
Are the inlet hose filters clogged?
There are filters on the inlet hose connections of the washing machine. They are intended to filter away mineral deposits from hard water and other debris from getting into the unit. If clogged, water will not flow through these filters into the washer. Turn off both the hot and cold water taps, disconnect the inlet hoses from the back of the washing machine, and clean the inlet filters gently but thoroughly.
Are the inlet hoses attached properly?
If the inlet hoses are not attached to the machine correctly, it will prevent proper water flow to the washer. Turn off the hot and cold water supply then disconnect and reconnect the inlet hoses. Ensure that they are threaded properly. After the hoses have been reconnected, open the water taps completely, check for leaks, and unplug the washer for 10 seconds and retry the wash cycle.
NOTE: The inlet filters are inside the hose connections on the back of the washer. Because of their small size, take care when removing and cleaning the inlet filters so that they do not break.
on Jun 02, 2011 | Washing Machines
What is the error of 1E
An IE error code signifies that the washing machine is filling with water slowly or not at all. This can occur when water supply taps are not fully open or the water pressure to the tap or house is too low. Other possible causes are kinked, pinched or bent water line hoses, or clogged water inlet filters.
TIP Make sure the water taps are fully open.
Make sure the hoses are not kinked or pinched. (Use caution when moving the washer.)
Clean the inlet filters.
Check another faucet in the house to make sure your household water pressure is adequate
Sep 19, 2015 | Washing Machines
Modle AWO 9561 In the second cycle the machine shows F&H error in the display, machine will not carry on. Even when switching off, same error appears.
Whirlpool's 'FH' stands for 'no water inlet'. Presumably the second cycle is rinsing (?) and that requires cold water as opposed to hot for the first (wash) cycle.
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Aug 17, 2011 | Whirlpool Washing Machines
THE SCREEN SHOWS IE
Hello there and thank you for choosing fixya
An IE error code will appear if the washer has not filled with water in approximately 8 minutes. If an IE error code appears on the washer, check to make sure both hot and cold-water taps are open completely. After both valves have been opened, unplug the washer for 10 seconds and retry the wash cycle.
And finely if all of this does not work then the inlet valve on the machine needs to be replaced ok?
Hope this all helps
Aug 05, 2011 | LG WM1814CW Front Load Washer
I get a message le or ue error and machine stops
Where in the cycle is the machine stopping?
A 1E error would be a fill problem. Either the water supply is inadequate (low pressure coming in due to a problem with your water supply), the water supply taps aren't fully open (make sure to open the valves fully), the inlet hose is bent (straighten the hose) or the inlet filter is clogged (clean the filter).
An UE error happens during the spin cycle. Either the load is too small or the load is uneven. Add some items that can tolerate the spin cycle speed or redistribute the load.
A LE error indicates that the motor has overloaded. Wait 30 minutes and then try to restart the machine. If the error persists, the unit needs service.
The manual for the WM-2277H* is available from LG as a DjVu file here: http://www.lg.com/us/support/product/support-product-profile.jsp?customerModelCode=WM2277HB&matchedModelCode=NOT_MATCHED&searchEngineModelCode=WM2277HB&initialTab=documents&targetPage=support-product-profile# .
I hope this helps.
May 30, 2011 | LG WM-2277HW Front Load Washer
LG Washing Machine stops spinning in mid cycle
IE:
• Water supply is not adequate in
area.
• Water supply taps are not
completely open.
• Water inlet hose is bent.
• The filter of the inlet hose clogged.
Solution:
Check another tap in the house.
Fully open tap.
Straighten hose.
Check the filter of the inlet hose.
UE:
• Load is too small.
• Load is out of balance.
• The appliance has an imbalance
detection and correction system. If
individual heavy articles are loaded
(bath mat, bath robe, etc.) and the
imbalance is too great, after several
attempts to restart the spin cycle the
machine will stop and the error code
will be displayed.
Solution:
Add 1 or 2 similar items to help
balance the load.
Rearrange load to allow proper
spinning.
UE:
Apr 27, 2009 | LG WM2487H Front Load Washer
E4 error message
Dec 27, 2007 | Baumatic 23 in. BDW13 Built-in Dishwasher
E02 message
Error relates to water taking to long to get into machine. Check tap is open fully, water pressure is ok, hoses are not kinked. also check the small filters either end of the inlet hoses (inlet valves as well) as quite often they can clog up especialy on a new install. Regards
Jul 22, 2007 | Bosch WFMC 3200 Front Load Washer
"tap water closed?" message
Plug off the wall. Check the inlet tubes into your machine (after shutting off wall valve) for any blockage or clogging, both ends of the pipes. Refix carefully with correct threading. Turn on before next wash fully; and after wash turn off valve. It could also be that your wall valve is not on fully when you begin your wash.
And dont forget to rate me pl.
Jul 03, 2006 | Bosch Axxis+ WFR 2460 Front Load Washer
Baumatic 23 in. BDW10 Built-in Dishwasher Logo
51 people viewed this question
Top Baumatic Dishwashers Experts
Oloyede Monsuru
Kolbrun...
rich2481
Are you a Baumatic Dishwasher Expert? Answer questions, earn points and help others
