Question about Everex StepNote NC1500 Notebook
Cut battery off
My ibm think pad lap top said that my battery is low, but it is pluged in to the outlet. how do i switch it from battery.
  • 3 Answers
If it is plugged in, and still running from the battery, you likely have a bad adapter or power jack. If you have a multimeter, set it in a range that would display 16v dc voltage, then stick the red inside the plug from the adapter, and touch the black to the outside of the plug, and see if the voltage registers (most IBM laptops use 16 volt adapters).
Posted on Feb 20, 2009
Instruction manual for IBM Type 2365 laptop cpm[uter
http://download.lenovo.com/ibmdl/pub/pc/pccbbs/mobiles/a8865650.pdf
Jun 12, 2012 | IBM ThinkPad 380ED
Does the battery have to work for the lap top to work when pluged in on the Presario R3000?
Check your AC adapter if still work. Battery don't have to work when is on AC.
Dec 26, 2011 | Compaq Computers & Internet
My wireless mouse reciever is plugged in and every thing done as per instructions but will not work my lap top is an ibm think pad
make sure the battery is good ((has full charge))also you might test the usb device for the mouse is inserted correctly into the usb port (if applicable)
Windows 7
make sure you turn the mouse on depending on type/brand of mouse it will vary it could be a button or switch on top or bottom
hope this helps you
Jul 25, 2011 | Computers & Internet
My IBM T30 Think pad lap-top is stuck in power save mode.The battery is still charging fine,but the whole screen is black with no image when i turn it on.However when i switch it on,all the leds light up...
Try to power drain the motherboard.
please follow this steps:
take out the battery
unplug the power adapter
press and hold power button for 30 secs
put everything back in
power on the computer
if issue is not resolved. There could be a possibility that this is LCD problem.
May 21, 2010 | IBM ThinkPad T30 2366 Notebook
I can not detach my IBM Think pad 2662 lap top from the driver
I had the same issue. Here's what I did. Not sure if it will work for you. But give it a try.
1) turn on the machine and press "F2" to go into set up.
2) Press alt-p seven times to go to the last page.
3)Press the down arrow to highlight HDD password. Set a password as instructed and reboot the machine.
4) You can remove this password later once your machine starts fine.
Even if you didn't get try this too.
1. Make bootable CD which contains Norton Ghost or other disk image software
2. Boot your system using bootable CD with Norton Ghost software, u can use Hiren's CD ISO image. If u don't know about hiren just google it.
2. Once you boot up , open Norton Ghost click LOCAL-> PARTITION->FROM IMAGE
3. Now "look in" for "[DellRestore]FAT drive" and select this drive (this is recovery partition)
4. Now go to "IMG" folder and select FI.GHO file
5. Click Open and there you go... Process started
Jan 28, 2010 | IBM ThinkPad X20 2662 Notebook
Where to purchase ?????
try this ebay auction number it is a power cord for think pad for may different models this might just work for you. good luck!
ebay auction Item number: 270343560573
Mar 29, 2009 | IBM ThinkPad Replacement Part
Sound and network cards are not working
I need sond card for sony vaio VGN-FS215S
Feb 21, 2009 | IBM (01K2154) Sound Card
IBM Think Pad
u need to restore your system
Aug 05, 2008 | IBM ThinkPad A21m 2628 Notebook
Everex StepNote NC1500 Notebook Logo
187 people viewed this question
Top Everex Computers & Internet Experts
Jerry Umali
Martin Murray
Are you an Everex Computer and Internet Expert? Answer questions, earn points and help others
