Question about Kenmore 24 in. 16032 Built-in Dishwasher
How much voltage should go to the fill solenoid?
Kenmore dishwasher model 665-16769000. How much voltage should go to the fill solenoid?
  • jamesb1020 Feb 20, 2009
    Thanks. Was getting 5 volts at the fill solenoid during fill cycle and threw me off. Moved the overflow float up and down a few times and all fixed and getting 120v now to fill solenoid (water inlet valve). Somehow 5 volts were getting through and I thought that's what it was supposed to get and almost bought a new fill valve. Wiring diagram was a help.
    Problem Solver:
  • 20 Answers
Most times it120v look at the wiring diagrams
Posted on Feb 20, 2009
2 Suggested Answers
  • 117 Answers
SOURCE: dishwasher not filling
Yes you should have 120v to the valve so the problem is elsewhere. Possibly the control isn't sending the proper voltage but you will need a tech to verify as this board is about $130
http://tclaundryrepair.com/
My Kenmore dishwasher Model @ 587-1511590 goes on but no water is comming out ?
Do you hear a 'click' when it is supposed to start filling the machine--if not, then the water inlet solenoid has likely failed. Make sure the water is turned on under the sink and there are no kinks in the supply hose. Hope this helps!
Sep 22, 2010 | Kenmore 15529 Built-in Dishwasher
Recently ran well low - no dishwasher not filling
Yes there is a screen in the water valve of the dishwasher. you'll have to shut off to the water line coming in to the dishwasher and disconnect the water line. then take off the water valve to get to the screen. you could have a stopped up screen or a bad solenoid switch on the valve.if you know how to use an ohm meter you can check the solenoid for continuity.
it is better to just replace the valve than to try to take the water valve apart and clean it.
you will want to check the float switch first before you do any of the above.
Jun 07, 2010 | Kenmore 13869 / 13864 / 13862 Dishwasher
My Kenmore dishwasher is not getting water! I
John? did you pay your water bill this month? LOL
check your temp controll switch that feeds to water solenoids to make sure there is a voltage/ signal going to them also your load limit switch under the tub ? if it is stuck open it wont fill the tub! that could be a good possiblity
Jan 14, 2010 | Dishwashers
Fills with water when not in use
this is meant to happen
May 17, 2009 | Dishwashers
Dishwasher not filling
Feb 20, 2009 | Kenmore Dishwashers
Hotwater runs continuously
It sounds like a little piece of trash (precipitated solids in the water line) have gotten in the water valve, or, the fill switch has failed.
If you know how to use a voltmeter, then see if there is voltage always applied to the water solenoid. If not, the water solenoid valve is bad. If it does have voltage all the time (when it's not supposed to be filling) then it's the fill switch.
Feb 01, 2009 | Hotpoint 24 in. HDA3400G Built-in...
Kenmore dishwasher 58715142400 fills but doesn't wash
Motor has gone out..just like mine...Make sure u have voltage going to the motor, (disconnect the plug from the motor) and use an electric meter to make sure you have voltage going to the motor. If so the motor has either gone out or has been blocked by something! If no noise except clicking then motor has gone out. Looking at about $150 for motor.
Jan 26, 2008 | Kenmore 24 in. 15142 Built-in Dishwasher
Kenmore built in dishwasher model # 665.16831792
timer is ordering draining. or solenoid is on and it drains non stop.
Oct 31, 2007 | Kenmore 24 in. 16032 Built-in Dishwasher
Kenmore 24 in. 16032 Built-in Dishwasher Logo
256 people viewed this question
Top Kenmore Dishwashers Experts
D. E. Hev
Fred Sops
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
