I have a 2 year old Hitachi 55hds69 plasma tv. It shut itself off and will not restart. The blue power light does not come on, only the red standby light. The tv does try to start, makes a clicking sound for a few seconds, the red light goes out at this time, then nothing.
  • 5 more comments
  • ssl_ken Feb 20, 2009
    2 year old Hitachi plasma tv, model 55hds69 shut itself off and will not turn on. No blue power light, only red standby light. Tv will try to turn on but only clicks for a few seconds then nothing, no red stanby light when trying to turn on. Have had opinions from logic board to power supply to fuse on power supply. Can anyone second an opinion?
    Thanks.
    Any other solutions to 55hds69 Hitachi plasma not turning on, no blue power light, only red standby, clicking sound when tv tries to turn on.No warranty
    Is a repairman needed for changing out the power supply?
    Tried the diagnostic suggestion, no luck, nothing.
    Wiil contact Hitachi again, when I first contacted them and they had no idea or suggestions.
    Still looking for additional info.
    Thanks for the great advice, all makes good sense, great link to parts supplier, parts priced 20% of what I was quoted locally.
  • 564 Answers
  •    Take the Televison to a repair shop and replace the power unit.
Hope this Helps, Please Rate My Response! Thanks!
PREM
Posted on Feb 20, 2009
  • 744 Answers
Hiii.....
If the power supply is supplying the main board with the correct amount of volts, your controller board or your on off switch panel is malfunctioning and needs to be replaced. If its the whole board your looking at a few hundred unless you can find the same tv with a broken screen and just swap parts.The on/off switch board is cheaper but you have to remove alot of interior parts to access and becomes a hastle.
thank u rate me!!!
    Genius:
  • 1,550 Answers
You need to check the fuse initially if it is good .
Then next part is power supply board. There can be various reasons for shutoff. Bad soldering can cause this problem.
Power supply board replacement can be done by you if you have any previous experience in handling electronic items . Else leave it to
technican to do the replacement job.
New power supply board will solve your problem .
You can find parts from the link below
Parts for hitachi tv
Hope this helps .
  • 4,472 Answers
A repair man is not needed but unless you are fully confident in your ability it is not really wise to want to cause further damage. I would still recommend locating the nearest service center and inquiring about an estimate. You can do that at this link.
http://www.hitachi-homeelectronics.us/Apps/ServiceLocator/ServiceCenterSearchForm
If you need further assistance let me know. Also please take a moment to accept and rate my solution accordingly.
Thank you,
Lee
    President:
  • 2,110 Answers
Your power supply board ned to be replaced..it will cost..contact hitatchi service center....
    Brigadier General:
  • 8,619 Answers
Hi!
It is in self diagnostic mode. It has sensed a high voltage power failure and due to that it has entrred the diagnostic mode.
And to see what code it is,you have to active this function. First turn it off (master power on in stand-by) then on the plasma you push and hold the (sub) power button and the down arrow at the same time and hold them for 5 seconds after it comes on. this will activate a series of red LED flashing a code. The code will blink 1/2 second on, 1/2 second off till the total count is done then it will stop for 2 seconds and repeat. Any other function button will stop the diagostics. One blink maybe the Logic board, two blinks the X-Sus board, three blinks maybe the Y-Sus or the Scan driver module (SDM), four blinks maybe the X-Sus, Y-Sus, SDM or the Power Supply (PSU), five blinks maybe the ABUS, the Address driver module (ADM), or the PSU, six blinks maybe cause by the ADM temperature, and eight blinks maybe "all the above-mentioned boards.
lease revert for any clarifications.
If you have found this information useful a FixYa rating would be apprecieated.
Thanks Rylee
  • 142 Answers
The power supply is bad. Not the power cord, the supply inside of the TV itself. It is an electrical board.
  • Tommy Walker Feb 20, 2009
    If the set is not under warranty and you are confident, you can order the part and install it yourself. Otherwise you will need to call a repairman.
    My advice, unplug the TV and do it yourself. If you feel that you cannot do it after having the part there, you still saved money by troubleshooting it yourself and you have the part already. Call a sericeman out and have him install the part.
    That is the truth!
  • 679 Answers
You may still have some warantee left, check prior to messing with it.
    Genius:
  • 1,269 Answers
If its making a clicking sound and does not come on, it definitely the main fuse from the power supply. It is either burned due to power surge causing it to be opened. You need to replace that.
Hitachi 55in plasma TV, model 55HDS69. It will not power up from either the remote or the on/off switch on the side. The TV was used a lot, for more than 5 years. It shut off while running. The red...
Hi sir Jim!!!!
kindly check the 5 LED if there is lit lights to diagnose where the fault came from..You said the 5 led turn off for 1 -2 seconds it means no error but still won't turn on I think there sometime wrong on logic circuitry..
Try to read the voltages on highlighted words on picture of block diagram above such as vs,va,vcc,stby+5v,stby+3.3v,+5.5,+10.5 and +12v...
After that let me know the results to diagnose where the fault from..
Hope it helps...
chester..
Jan 19, 2012 | Hitachi 55HDS69 55 in. Plasma Television
Hitachi 55" plasma TV. 5 years plus old, used a
Please let me know whats the model number of the tv so that I can tell you what the PCB LED diagnostics are pointing to. It sounds like a power supply or Main board issue so I would like to confirm which one of them it is.
Dec 22, 2011 | Hitachi 55HDS69 55 in. Plasma Television
Hitachi Plasma TV 55HDT79 that is turning on and off and back on
Go Setup in the menu. At the bottom you will see Reset The Software when power is turned off. Switch this to No.
Apr 21, 2010 | Hitachi 55HDS69 55 in. Plasma Television
Hitachi 55" Plasma HDTV, 1 yr old, suddenly lost picture and sound, but power light still on.
It sounds like a shutdown circuit is being activated. This is normal in cases where the power supply id drawing excessive current. I would suggest that you get this looked at by a qualified professional. This is because this problem may be in the power supply and the voltages can get dangerous in this section of the TV set.
In any event if this is a power supply problem chances are the technician will just have to replace the power supply. Which should cost from 150-250 dollars.
I hope this helps
Shuttle83
Jul 14, 2008 | Hitachi 55HDS69 55 in. Plasma Television
Hitachi 42" Plasma HDTV
This happened to me with my first Hitachi 55" plasma. It ended up being the panel itself, which was very expensive to fix. Thankfully mine was under warranty and I was able to get a replacement TV.
Jun 16, 2008 | Hitachi 55HDS69 55 in. Plasma Television
No pix
Have audio? I turned off my speakers so I couldn't tell. Blue light? Does it blink twice then stay solid? They went through the 2 large panels and power supply and couldn't get it to work. Solution was plasma panel was shot. $3000 bill.
I'm waiting to hear from others if it was one of the smaller boards around the edges as I have a giant piece of metal in my basement that I get to dispose of. My sony 52" should be here tomorrow.
May 30, 2008 | Hitachi 55HDS69 55 in. Plasma Television
Plasma tv
The pilot light is in blue or red??
Is blinking after turn off??
May 14, 2008 | Hitachi 55HDS69 55 in. Plasma Television
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
