Question about HP Deskjet F340 All-In-One Printer
Printer will not print to paper, I put in new cartridges, etc
Hello I have a hp deskjet f340 and I will not print. I have replaced the cartridges, cleaned the heads, and aligned it nothing works. It goes through the motions and sounds like it is printing but nothing comes out, just a blank page
  • 59 Answers
Just put in RMA
Posted on Apr 04, 2009
How do i clean ink heads on hp deskjet f340 all-in-one
Things to clean:1. Little warm water & bowl2. tissue paper3. Ear budsDip cartridge nozzle part in water, wait 10 seconds, take out & swab nozzles with ear buds, clean with tissue paper as shown in fig.. check for the print quality.. repeat two or three times if required.. if no recovery better to replace the cartridge.. 4_29_2012_9_45_00_am.jpg4_29_2012_9_45_32_am.jpg4_29_2012_9_46_04_am.jpg
Apr 28, 2012 | HP Deskjet F340 All-In-One Printer
How to change ink in HP Deskjet F480 printer???
  • Check the ink levels by opening the HP Solution Center. Click on "Settings." Click on "Toolbox." Click on "Services." Click on "Service this device." Click on "Estimated Ink Levels." A graphic will appear showing the estimated ink level in each cartridge.
  • 2 Verify that the unit is on. Open the print cartridge door allowing the print carriage to move to the far right side of the unit. Once the print carriage has stopped, lightly press down on a print cartridge to release it. Pull the print cartridge toward you out of its slot. To replace the tri-color print cartridge, remove the print cartridge from the slot on the left. To replace the black or photo print cartridge, remove the print cartridge from the slot on the right. Place the cartridge in a plastic bag as it may still contain some residual ink and may leak.
  • 3 Remove the new print cartridge from its packaging. Remove the plastic tape by using the pull tab, being careful to not touch the copper-colored contacts or the ink nozzles under tape.
  • 4 Slide the new print cartridge forward into the empty slot. Gently push the upper part of the print cartridge until it clicks into place. The tri-color print cartridge fits into the left slot. The black or photo print cartridge fits into the right slot.
  • 5 Close the print cartridge door. If the print cartridge alignment sheet prints, load it on the left front corner of the scanner glass with the top of the page to the left. Verify that there is plain paper loaded in the input tray, and then press the "Scan" button to align the printer.
  • Read more: How to Replace an Ink Cartridge in an HP Deskjet F340 ' eHow.com http://www.ehow.com/how_2303716_replace-ink-cartridge-hp-deskjet.html#ixzz16MAooFTf
    Nov 26, 2010 | HP DeskJet F380 All-In-One Printer
    Can you use the HP 27 Ink Cartridge with the HP Deskjet F340?
    No you cannot use Cartridge 27 with Hp Deskjet F340 printer. The printer only supports, 21 (black), 22 (color) and 58 (photo). I hope this clears your doubt.
    If you need further help, let me know.
    Good luck.
    Thanks for using FixYa.
    Sep 04, 2010 | HP Deskjet F340 All-In-One Printer
    I am unable to locate ink cartridges in HP Deskjet F340; where the heck are they? I have replacements to install. I know this sounds really stupid!
    Go to this help page for instructions:
    F300 Series Ink Replacement
    You may also be interested to have the main support page for your printer:
    F340 Support
    Add it to your favorites. It may come in handy.
    Thanks for using Fixya. Please take a moment to rate this solution.
    Feb 06, 2010 | HP Deskjet F340 All-In-One Printer
    My hp deskjet f4140 keeps showing a paper jam and won't print the page I need, there isn't a paper jam.
    There is probably a problem with the position of the cartridge carriage. Try reinstalling the cartridge and make sure that the carriage is in the center of the cartridge access area and the center of the cartridge assembly bar. If it is not try moving the cartridge assembly in either direction and restore the printer for printing. Note any sounds as the cartridge attempts to go to its home position. Any grinding noise may indicate that the position of the cartridge needs to be adjusted. Be patient and adjust the cartridge position again until no grinding sounds are heard. It may help to unplug the printer for 30 seconds between adjustments. Good Luck!
    Nov 05, 2009 | HP Deskjet F340 All-In-One Printer
    Hp Deskjet 845C - Yellow Colour not Printing
    I found this post to work for me when yellow was not printing on my HP PSC750 after using 2 cartridges: "Well if you want to damage your printer use alcohol. But if you want to make it work then pull the cartridge from the printer and run hot water on a couple of paper towels leaving alot of hot water in the towels. Put some thing under them to keep them from staining your counter top and then set the cartridge down onto the hotwater towel and let the hot water melt away the dry ink and in minutes you may be printing again if this is what it is. Be sure and use a dry paper towel to wipe off the ecess wet before you reinstall the cartridge."
    Jan 31, 2008 | HP DeskJet 845c Printer
    Problem printing photos
    When printing a photo make sure that your quality is set on best and not normal.
    Also check the ink level on your colour and black cartridges and make sure it is sufficient.
    Last but not least if you are using remanufactured or refilled cartridges this is a common problem. The cartridges are not made for the printer or they have been refilled and they now have blocked printheads and the ink is doing interesting things. If you buy a real hp cartridge and it should clear the issue up.
    Dec 16, 2007 | HP Deskjet F340 All-In-One Printer
    Deskjet f340
    You have a paper jam. get a torch and thoroughly check doen behind unit where paper goes after removing all paper. Oopen cover, let carriage move, once settled, check everywhere her too, all around, rollers, near carriage, teeth, sides, etc, and remember it can be the tiniest slip easily missed. Good luck.
    Mar 06, 2007 | HP Deskjet F340 All-In-One Printer
    271 people viewed this question
    Ben Johnson
