Question about Frigidaire PLMV168 Microwave Oven
Can I replace Keypad cover for Frigidaire microwave plmv168cc1.
We did not use proper cleaning method of the keypad cover on the Frigidaire microwave plmv168cc1. Thus, the keypad cover is blemished or blurred - almost like it was rubbed with an abrasive. Can it be replaced?
  • 5,911 Answers
Yes, the display can be replaced. You can order the part on line at searspartsdirect.com. Just type in your model number as listed in your question and look under the "Control Panel" heading for item number 14. The part number is 5304429419. I hope this helps you.
Posted on Feb 20, 2009
    President:
  • 267 Answers
YES go on the sears.com web site put in your mod# and you will see the parts that are still made for your unit . i did not look up your unit but if its made its on sears parts ... good luck
My ge jvm1540 over the range microwave is displaying service needed keypad shortage what does this mean
see this steps and follow and fix it. God bless you
If you have a stuck key or non-responsive key, most of the time you will have to replace the keypad for this microwave oven repair. If your keypad is connected to your control board by a flat ribbon wire, try disconnecting it and clean the silver contacts with an ordinary pencil eraser. After cleaning, plug it back in and try it. If it doesn't fix it, replace the keypad unit. Some units actually have keypad tests to confirm your diagnosis of a bad key.
If your keypad and control is the same unit, replace that unit. Another note, unlike stove/oven keypads and controls, most microwaves do not have error codes or tests to distinguish whether it is truely the keypad or control. Most of the time, it is the keypad that needs replacing, but a small percentage of the time it can b
Nov 15, 2012 | Microwave Ovens
Tappan 5030 microwave oven fuse is ok but no lights on keypad come on
see the causes and fix it. God bless you
Touchpad dead If you have a stuck key or non-responsive key, most of the time you will have to replace the keypad for this microwave oven repair. If your keypad is connected to your control board by a flat ribbon wire, try disconnecting it and clean the silver contacts with an ordinary pencil eraser. After cleaning, plug it back in and try it. If it doesn't fix it, replace the keypad unit. Some units actually have keypad tests to confirm your diagnosis of a bad key.If your keypad and control is the same unit, replace that unit. Another note, unlike stove/oven keypads and controls, most microwaves do not have error codes or tests to distinguish whether it is truely the keypad or control. Most of the time, it is the keypad that needs replacing, but a small percentage of the time it can be the control. Check the tech sheet if they can point you to the right part.
Oct 10, 2012 | Tappan TMS062E1 Microwave Oven
Ge microwave oven key pad short circuited JVM 1540
see the next steps. God bless you
Oct 03, 2012 | GE JVM1850 1000 Watts Microwave Oven
Keypad don't light up
see this causes and fix it. God bless you
Lights come on, but can not program unit, Touchpad dead If you have a stuck key or non-responsive key, most of the time you will have to replace the keypad for this microwave oven repair. If your keypad is connected to your control board by a flat ribbon wire, try disconnecting it and clean the silver contacts with an ordinary pencil eraser. After cleaning, plug it back in and try it. If it doesn't fix it, replace the keypad unit. Some units actually have keypad tests to confirm your diagnosis of a bad key.
Sep 25, 2012 | Maytag MMV4205 Microwave Oven
Fridgidaire microwave turns on by itself
There two causes, one defective door switch, or the keypad control board is not working properly and must be replaced.
May 21, 2012 | Frigidaire Over-the-Range Microwave
How to replace the front buttons?
Most microwaves use a membrane type keypad that is glued to the front panel..they can be expensive though, but aren't too hard to replace...it involves removing the cover...unplugging the keypad ribbon cable...removing the old keypad...and reinstalling the new keypad
Jan 15, 2011 | Sharp R-1500 Microwave Oven
Kenmore microwave - unresponsive keypad
Repaired the unresponsive keypad on my older Kenmore (model 721.68100): Unplug. Remove integral cover for top and sides which is held in place by 5 metal screws. The cover then slides toward the rear. Unplug two connectors to back of keypad and clean them (I used contact spray cleaner). Some of the components retain a charge even when unplugged.
Dec 17, 2009 | Kenmore Microwave Ovens
Can I replace keypad for my PLMV168KC3 Frigidaire Microwave?
Is it a membrane type touchpad?
These are usually held in place with an adhesive. You can pull the old one off and stick the new one on. The complication usually involves the connection between the touchpad and the body of the microwave. This connection may or may not be easily accessible.
Oct 09, 2009 | Frigidaire 1.6 Cu. Ft. Over-the-Range...
Frigidaire PLMV168 Microwave Oven Logo
469 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
