Question about GE Spacemaker JVM1640SJ Microwave Oven
The microwave (GE Spacemaker XL 1800) will turn on but the fan makes a harsher sound and the light comes on and the timer counts down but the oven does not heat.
  • imabearsfan Feb 23, 2009
    The answer I was sent was to check the magnetron. I do not know how to check the magnetron and also to check the fan to make sure the fan is not stuck with grease. Is the fan behind the control panel?
    The tray is spinning and no there is no error code on the diplay.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
To my view, your initial hurdle would be to move the microwave out of the cabinetry if it is built-in. If able to, then diagnosis would involve:
  • removing the top/side cover to expose the inside;
  • there would be 2 areas of the fan where the sound could originate; blades if 1 is broken or if they are hitting something. Either that or the bearings of the motor have lost their lubrication;
  • there would be a fuse, clearly expose inside that could cause the microwave not to heat.
Both are easy and therefore user serviceable. If the problem is not corrected, then may I suggest that perhaps your best bet is to seek the services of a qualified professional. The rationale being, further diagnosis & repairs require familiarity with high voltages, electronic circuitry and components, use of a DVM and a soldering iron.
Should you still pursue DIY (do-it-yourself), might you email MicrowaveSvc, who is also a member of this site who owns & runs a microwave parts and service here.
MicrowaveDisplaycom
(765) 378-4640
11 N Washington St, Anderson, IN
Website: http://www.microwavedisplay.com
Email: prototech@usa.net
Good luck and thank you for using FixYa.
Posted on Feb 23, 2009
  • GE Master
  • 32,281 Answers
The fan and the turntable tray are controlled by electric motors and these most likely where the noise is coming from.
To check the magnetron, (this device generates the microwave energy that cook and heats the food) place a half a cup of water in the microwave oven, select a couple of minutes and turn it on. If the water heats up and or boils then the magnetron is OK.
If the water is still cold the the magnetron is faulty.
It isn't worth repairing even if you can buy a new magnetron, especially if it is several years old.
The fan and turntable helps the food heat/cook the food evenly.
    Scholar:
  • 165 Answers
Q - The microwave makes a loud "hum or buzz" noise but will not heat up the food?
A - 9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode. See components section.
for how to check magnetron click this link directly
http://www.applianceaid.com/image/component1.JPG
    Genius:
  • 2,920 Answers
You need to go ahead and buy another microwave,,,its not worth the money to fix tha one when you can buy a new one for under 60.00
  • Ronnie Houston Feb 23, 2009
    chances are the element that it uses to create heat went out. as i said it would be cheaper to buy a new one than to try to repair the old one. i saw some nice ones at walmart for 49.00 stainless steel...you might looki nto that
    Brigadier General:
  • 8,619 Answers
Hi!
Please check the door switch (interlock switches) are they locking?
Also look for any obstruction like a wire or a broken piece near the fan.
Please revert for further clarifications.
Thanks
Rylee
Posted on Feb 21, 2009
  • 2 more comments
  • Rylee Smith
    Rylee Smith Feb 21, 2009
    Please tell is the tray spinning?
    Is it flashing a fault/error code on the display?
  • Rylee Smith
    Rylee Smith Feb 23, 2009
    The fan is at the back of the unit, you can see that in the following exploded view---
  • Rylee Smith
    Please see this link for a bigger and better picture---
    GE XL 1800
  • Rylee Smith
    The noise you are hearing is due to the fan. The fan is used to cool the magnetron during cooking, and because this fan is not working the magnetron is overheating and the thermal protector is opening, killing power to the unit. All you need to fix this is a new fan blade. The fan blade is slipping on the motor shaft ( the noise you are hearing).
    If the blade is broken then you can buy a new one from---
    GE FAN BLADE
    Please ask for further clarifications.
    A Fixya rating would be appreciated if you find it useful.
    Thanks
    Rylee
  • GE Master
  • 19,396 Answers
Check that the fan is not stuck with grease and making noise.
GE Spacemaker XL - fan stopped working, light will come on and timer will count down.
either the magnatron fried , or the fuse fried... either way the microwve has to be taken down and opened up.
If you have the serial number , GE will send you a replacement magnatron (but will not service the unit for you).
contact GE and they will take care of you... the magnatrons are warranted for like 10 years....
Mar 23, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
GE spacemaker xl microwave oven will not heat
My guess is the magnetron is bad. It is rarely the transformer
Jan 04, 2013 | GE Profile Over the RanMicrowave....
Turn table does not work. How do you fix it? I have a GE Spacemaker XL 1800, Model # JVM1842BD. Thank You
i have a ge 1800 model and it cooks fine but after awhile it shuts down and in about a hour it comes back on and ask you to set the clock.....
Jun 03, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Ge profile spacemaker xl 1800. recently changed a
It sounds like the main transformer has failed. It would be cheaper to replace the whole microwave than repair this one. Sorry to be the bearer of bad news. Hope this helps. Good luck.
Mar 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Our GE Spacemaker XL 1800 microwave's controls are locked
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
Jan 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Ge Spacemaker XL 1800
SOME BUT NOT ALL OVENS HAVE RELAYS TO TURN THINGS ON AND OFF CHECK THE OVEN TO SEE IF YOU HAVE ANY
RELAYS AND SEE WHAT THEY DO.
Jan 06, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker XL 1800 - turntable issues
check capacitor and motor drive of turn table.
Jan 03, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
132 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
