Question about Kicker ZR360 Car Audio Amplifier
No Power light or sound from kicker amp and speakers
I have a Kicker Impulse Amp that i have had in my car for 2 years. Recently i decided to transfer my exsisting 2 10" Kickers and Amp to a larger box customized to fit my trunk. I installed everything just as it was before but now i get no power light on the amp itself and no sound at all. When i move the fuse in certain ways on the amp the power light will flash and go off. I have tested the amp to make sure power is running to the amp and it is. i have also checked my ground and all other wireing and still no power light and no sound! HELP
  • calibaby0302 Feb 20, 2009
    Yes
  • Eric Routt May 11, 2010
    Are you getting power up to the fuse?
  • 55 Answers
OPEN UP THE AMP AND CHECK THE FUSE HOLDER THAT IT IS CONNECTED TO THE BOARD
IT MAY HAVE GOT BUMPED AND THE CONNECTION MAY HAVE BROKE IT MAY BE A HAIR LINE BREAK WITH THE COVER OFF AND THE POWER ON MOVE THE HOLDER MAY NEED TO BE RESOLDER THE CONNECTON THATS ALL IT IS GOOD LUCK
Posted on Feb 20, 2009
Can you bridge zx300.1 amp?
  • For years Kicker has always been my favorite amp. For this amp I advise against bridging two speakers to it. This amp is intended to rune one speaker at no more than 2 Ohms total. If you bridge 2 speakers to this amp, you may burn the amp up or for sure send the amp into protect mode.
Regards, Tony
May 11, 2011 | Kicker ZX300.1 Car Audio Amplifier
I have a Legacy Predator 2000 watt amp with 2 12'' Kicker speakers. It has been in my car for about a year now, and it recently just stopped working. I have the green light to the amp, im not sure about...
If you have checked your ground, live, remote and RCA's, The problem may lie with your kicker speakers.
There may be a loose wire connection on the speaker terminals (hense no sound).
Check the terminals at the speaker (+) and (-) then check the speaker wires to your amp inputs.
Usually if there is a fault with any wires linked to your amp, the amp goes into protect mode.
If your amp is not going into protect mode, try linking a different speaker to each terminal on your amp (left) then (right). If you get sound through a different speaker, more than likey your speaker wire to your kickers has came loose (due to vibrations) or there is a break in your speaker wire.
Hope this helps. If any more info is needed I'd be happy to help more. Please rate if helpful
Mar 18, 2011 | Car Audio & Video
Kicker impulse 254 amp red light on top?
1st check all of your wiring, make sure the remote wire is hooked up, check to see it the RCA's are hooked up. I know this sounds stupid, but i've done it a thousand times, check to see if you hooked up the speakers. If you checked all of those and still nothing, double check your ground. Make sure where you have it grounded, you have all the paint sanded away and its a good grounding point. The red light on the top of the amp, its not a protection light is it??
Apr 03, 2010 | Car Audio & Video
How to hook up 2 kicker 10" speakers & kicker amp to a 2002taurus
Good day ma'am, hi, hooking up an extra amp. on your radio is done by audio professionals, but if you can remove the radio out from your ford, you can install that extra amp. Just follow the diagram below.63bff30.gif You need to find line out of your radio to line in of your kicker amp. connect them using audio shielded cables. connect your speakers to the amp. I guess you this already.
Nov 23, 2009 | Kicker KX600.1 Car Audio Amplifier
My friend jus bought 2 10 inch kicker l5s and when we hooked them up to his boss 1100 wat amp and hooked everything up they are moving but are not producing any sound. boss amp i do not know any thinbg...
it must be reversed polarity in coil voices of speakers check + - wires from amplifiers fit on coil voices of speakers try to get each speaker to 8 ohms wiring in serial the two coil voices n'd put in paralel both speakers in bridge mode output from amplifier to get most stable power ,
Nov 04, 2009 | Kicker Solo-Baric L5 Car Subwoofer
Multible amp wiring
Its always a better idea to use a distribution block when splitting your power source to multiple amplifiers-but you asked if it would work not what a good idea is -so to answer you yes it will work -im not recommending it but sometimes ya gotta do what ya gotta do
May 22, 2009 | Kicker CVR12 Car Subwoofer
What amp need to use for Kicker (2) S12L7 12in Solo Baric
you should use an amp with approx half the power of the speakers max output (i.e 1000 watt speaker use no more than 600 watt amp)
May 12, 2009 | Kicker (2) S12L7 12in Solo-Baric L7 + (1)...
Kicker amp troubleshooting
Disconnect all speaker wires and signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down, the amp likely has blown output transistors.
Dec 01, 2007 | Car Audio & Video
Kicker ZR360 Car Audio Amplifier Logo
690 people viewed this question
Top Kicker Car Audio & Video Experts
Professor_V
Professor_V
Tygh Duval
Tygh Duval
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
