Question about E-Machines eMachines Desktop PC
Shaking image the image on my monitor seems to shake. I replaced the monitor but the image is still shaking. Thanks for your help.
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    Whats the resolution set at?
    Master:
  • 413 Answers
This problem is most commonly caused by a bad video cable. Sometimes though the monitor itself can have some bad components. The first thing to do in this situation is try the monitor on another computer first. With the same cables and all. If it does the same thing it is wise to buy another cable. IF you still have the same result return the monitor and cable if you can or buy a new one
Posted on Feb 20, 2009
    Scholar:
  • 67 Answers
Sorry its not with your monitor ..it must be loose graphics card or VGA cable ..please check all loose connections. you might have to replace your graphics or video card
    Problem Solver:
  • 5 Answers
Check your refresh rate it sounds too high, try going to 60 or 75 hertz. you can change it by right clicking on the desktop and got to properties settings and then advanced and then monitor
Icon of a shaking hand on LCD screen
The shaking hand icon has to do with the Image Stabilization control.
If it's continuously shaking, it's set in continuous mode, etc.
You can access control for the "I-S" via the menu...scroll down to IS settings. and you can adjust as desired.
Dec 10, 2009 | Canon Cameras
Image shakes
check frequency settings and make sure its set at 60 htz,that is if your not in Europe
Sep 30, 2009 | Samsung SyncMaster 551 15" CRT Monitor
At 40 mph the car starts to shake. It last to 5o
I have this same car with exactly the same problem. Begins shaking at 40mph and stops shaking as soon as you let off the gas, but then begins again as soon as you press on the gas and smooths out as you get over 50. And the shaking is not felt through the steering wheel. Solution: Replace the transmission mounts. There are two of them, one on each side mounted on the frame right next to the shock strut. There is also a front and rear engine mount, but I replaced the two as described and shaking is gone.
Jun 29, 2009 | 2000 Buick LeSabre
Vibration of camera
This is a problem with the lens gyro we can keep it from shaking it requires the camera to be taken apart and amodification done to the lens repair cost 65.00 in most cases.
May 14, 2009 | Sony Cyber-shot DSC-T70 Digital Camera
Screen Shaking/Vibrating
Yeah, Degaussing is basically resetting the magnetic field inside the monitor. go into the menu options, and search for that option. if this does not work, then your monitor is really old, and needs replacing.
Jan 26, 2008 | Batesias V172RTNRA 17 in. LCD Television
Monitor issue
Look to Caps on the inverter if its an LCD or flat pan. monitor.. Weve seen this be4..
Jan 13, 2008 | Norcent Technologies LM-762 17" Monitor
I think it's busted
you need to open the case and check the capacitors and if they seem doomed or color is leaking then replace the bad ones that should stabilize the power to the vertical ic chip
Nov 20, 2007 | Mag Innovision LT782S 17" Flat Panel LCD...
Monitor not working
if it is completely shaking then problem is in power supply filter ckt. 1 please check main filter capacitor. 2 check bridge rectifier diode for open. 3 loose connector in power supply. But if it is shaking on top then check for horizontal oscillator section. if you are not rech. person take the help of skilled tech. good luck.
Oct 03, 2007 | 3M MicroTouch 17" CRT Monitor
SHAKING IMAGE, STRETCHED IMAGE
Like I said last night cobra there is a vert shaper cap off the jungle/drive ic usually a smaller value and will check good but its bad. Or the b+ filter cap off the fly has caused sysmtoms like this as well. Good Luck
Apr 14, 2006 | Dell 828FI 15" CRT Monitor
E-Machines eMachines Desktop PC Logo
111 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
