Question about Canon PowerShot SD500 / IXUS 700 Digital Camera
Lens Opening Failure, Canon SD 950 IS
The SD 950, and a slew of like Canon models, is encountering sudden barrel lens opening failure. A message in the screen appears after the lens fails to open, stating: Lens Failure, Restart. However it continuously fails, and the afore message reappears.
The solution is pointing up the problem as not being isolated, but gross design failure, warranting recall.
    President:
  • 1,223 Answers
Its a lens assembly problem, it might be damaged from impact or may be something like dust is making diffficult for it to work u have to take it ti service
Posted on Feb 20, 2009
My Canon PowerShot SD 1000 has this problem: when i turn on the camera, the display is black and i can`t see any image through.Same problem on the video mode. it doesn`t appear any error mesage. i tried to...
A stuck shutter is another common failure mode for digital cameras (including my wife's SD1000, which I have to fix every once in a while with the following easy technique).. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help. By the way, for your camera model, I've found it best to just alternate back and forth between opening the battery door while taking a picture, and gently flicking the lens barrel with the tip of my finger. Usually, it only requires a few tries for my wife's camera, then it's good for another couple months.
Jun 02, 2011 | Canon PowerShot SD1000 Digital Camera
I have a Canon PowerShot SD1000 and it turns on, but the screen is blank. It will upload any photos taken (although you can't see what pics you take), but even then you have to click the button on the...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
By the way, my wife happens to own a SD1000. Great little camera, but it's prone to stuck shutter every once and a while. Easily fixed each time though by simply opening the battery door while on, and gently flicking the lens barrel a few times. Again, see the link.
May 31, 2011 | Canon PowerShot SD1000 Digital Camera
I was taking photos when suddenly my Canon PowerShot SD 1300 IS IXUS 105 read "Lens error. Will shut down automatically. Restart camera." Then the screen went blank. The lens will not retract....
There is something wrong with your lens barrel. It can be anything from some sand/dirt that got inside in which you try using some canned air to blow out the particles while continually turning it on and off. Usually what it is from is the camera being dropped, even if it is in a case or inside a bad. The jostle or direct impact of the fall will break some small gears or tweak the lens off of alignment. If it was from an impact then you lens barrel needs to be replaced and in that case the repair cost are usually as much as getting a new camera. You can send it into Canon and get it repair for a flat rate. Sorry about your camera.
May 25, 2011 | Canon PowerShot SD1300 IS IXUS 105...
Lens cap off but pictures all black. Tested another SD card same thing happens. Black on review on camera and black when put SD card in computer. Camera a few years old and never had a problem before....
Is this a Canon ? If it is, you need to call Canon. You might have a CCD sensor failure.
Take a look at http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
If it is not a canon (You do not mention the brand) you are still best to contact the vendor. CCD failures can happen accross the board.
If the lens is a removable SLR type, take of the lens and take a photo. Does the mirror flip up at all and expose the CCD ?
Thanks
Feb 09, 2010 | Pentax *ist DL Digital Camera
Lens error When the camera is switched on the lens does not open out and the lens cover does not open. The camera then displays a "lens error" message and suggests that the camera be restarted ten...
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Aug 09, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
When i press the power button i get an error message
Jul 08, 2009 | Canon PowerShot A530 Digital Camera
Error on lens restart camera
try these:-
  • connect it to pc and on it
  • vaccum the barrel of lens
  • changing mem. card and batt. for 2min.
  • shake it.
  • on and off in different positions
  • hit the part near lens softly with palm (trust me this made mine work)
Dec 20, 2008 | Kodak EasyShare C875 Digital Camera
Lens error, restart camera message
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Nov 15, 2008 | Canon PowerShot S3 IS Digital Camera
Canon PowerShot SD500 / IXUS 700 Digital Camera Logo
154 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
