Question about Whirlpool LER4634J Electric Dryer
Dryer running but not heating
I replaced the heating element but no change. Where is the thermal fuse or thermostat, these are the only other things that I can think of to check. Where are they located and are there any other suggestions.
Thanks
Chris
  • willgail Feb 21, 2009
    Am I reading the voltage correctly? I have a 4 prong and tested the East/West and got 244V at the wall. going to the East/South holes only showed ~120
  • 5,911 Answers
The thermal cut-out (TCO) and Hi-Limit Thermostat are the two additional items you need to check for a no heat problem. The Hi-Limit thermostat is small round component located near the terminal leads of the heating element on the heater box. The TCO will be located at the opposite end of the heater box and is similar in shape and size. Both components should read a short (0 ohms) if good. There is a drawing you can refer to at searspartsdirect.com. Just type in your model number and look under the "Bulkhead" heading for item number 6. These components are often sold as a set and should be replaced at the same time. Do not get the TCO confused with the Thermal Fuse (item 19). If the Thermal Fuse were bad, the dryer would not run at all. If you have questions, please let me know. I hope this helps you.
PS Before you jump headlong into this repair job, did you verify the voltage at the wall receptacle? You should read 220-240VAC across the two hot terminals. If you are only reading 110-120VAC, this will give you the same symptoms as the dryer drive motor only uses 120VAC to run, while the heating circuits require the full 220. You need to check the voltage at the receptacle and at the terminal block in the back of the dryer to verify the power cord is good.
Posted on Feb 20, 2009
Dryer spns but there is no heat
probally the heeting element
Mar 10, 2015 | Samsung Dryers
My dryer does not heat. Fuse, thermostats, heat element all have continuity, power chord is good, 240v at plugin... stumped. It is a model # LER4634BQ1 Whirlpool SN# ME4471484
dryer_heating-element.jpg Heating Element
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
dryer_thermal-fuse.jpg Thermal Fuse
Another possible cause for a dryer not heating up could be attributed to a faulty thermal fuse. Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you will have to replace it. Open up your dryer's cabinet and locate its thermal fuse so that you can test it.
dryer_thermostat.jpg Thermostat
If any of your dryer's thermostats have become defective, they could be the reason that your dryer is not heating. Open up your dryer's cabinet and test each of your dryer's thermostats. If any are faulty, replace them.
dryer_timer.jpg Timer motor
A defective timer motor could also cause your dryer to not heat up. Test your dryer's timer motor. If it is no longer functioning as it should, replace either the entire motor assembly, or just its motor.
Feb 06, 2010 | Whirlpool LER4634J Electric Dryer
My dryer will run, but will not heat.
Hello there
If your dryer won't heat up, it's possible that it is not being supplied with the proper voltage. Here are three ways to make sure power is getting to your dryer: First, make sure your dryer is plugged in. Next, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Finally, check to make sure no fuses in your fuse panel are blown. Any of these could explain why power is not getting to your dryer.
Heating Element
Thermal Fuse
Thermostat
Timer motor
Jan 25, 2010 | Speed Queen AES28AWF Electric Dryer
Dryer will not heat up when running. Was told to check the thermo fuse, ignitor and/or coil. Is that right? How do I check those things.
hello there
Please follow this procedure I have provided below and it will tell you how to test each one ok
Hope this is very helpful
Investigate these five areas if your dryer is not heating up:
Proper Voltage
Jan 24, 2010 | Kenmore Dryers
Will run but won't heat
HELLO THERE
There are 5 things that can make a dryer not heat please review the following items that i have provided for you
investigate these five areas if your dryer is not heating up:
Proper Voltage
Jan 18, 2010 | Whirlpool LER4634J Electric Dryer
Dryer not heating. Toubling fine.
hello there there are 5 different things that can majke your dryer not heat up please review these 5 things that i have provided
Proper Voltage
If your dryer won't heat up, it's possible that it is not beingsupplied with the proper voltage. Here are three ways to make surepower is getting to your dryer: First, make sure your dryer is pluggedin. Next, check the circuit breaker panel to make sure all the circuitbreakers are in the correct positions. Finally, check to make sure nofuses in your fuse panel are blown. Any of these could explain whypower is not getting to your dryer.
It is possible that your dryer isn't heating because its heatingelement is defective. Heating elements are irrepairable. If yours hasceased to function properly, you will have to replace it. Open yourdryer's cabinet and locate the heating element so that you can test it.
Another possible cause for a dryer not heating up could be attributedto a faulty thermal fuse. Once a dryer's thermal fuse has blown, it isno longer of any use. If your dryer's fuse is blown, you will have toreplace it. Open up your dryer's cabinet and locate its thermal fuse sothat you can test it.
If any of your dryer's thermostats have become defective, they could bethe reason that your dryer is not heating. Open up your dryer's cabinetand test each of your dryer's thermostats. If any are faulty, replacethem.
A defective timer motor could also cause your dryer to not heat up.Test your dryer's timer motor. If it is no longer functioning as itshould, replace either the entire motor assembly, or just its motor.
Jan 18, 2010 | GE Dryers
Whirlpool dryer will not heat
Hello there:
There are 5 things that would not make the dryer heat up i will post you them here ok
Jan 17, 2010 | Dryers
For Dryer Model LER7646EQ1, dryer runs but no heat, It could be the heating element, the thermal fuse or other. Also the dryer has been running hot.I do not know how to remove the front panel
This sounds like a faulty thermal fuse or heating element. The fact that you said the dryer has been running hot could indicate that the heating element was making contact with the heater box or the high limit thermostat is faulty. Both the thermal fuse and heating element can be tested using a multimeter or ohmmeter and checking for continuity. A lack of continuity means a faulty component. When necessary to replace a thermal fuse it is best to change the high limit thermostat as well. They will sometimes come as a set from a parts supplier. Really sorry for your trouble and I hope this helped. Best wishes.
Sep 23, 2009 | Whirlpool LER7646E Dryer
No heat in dryer model # 96591420
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jul 31, 2009 | Kenmore Dryers
Dryer runs but will not heat. Replaced fuse and
your cycling thermostat needs changed too. the thermal fuse is your last safety measure that goes, which means your cycling thermostat is not shutting down the heat element once it detects the right temp hot air in the blower housing so it let the heat element glow until either the high-limit sensor shuts the heat down or the thermal fuse blows. Change the cycling thermostat and good luck
Mar 06, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool LER4634J Electric Dryer Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
