Our Frigidaire stackable dryer is squeaking off and on when we are drying clothes. The problem gets worse and more constant toward the end of the cycle.
i have the same problem, but now it is a loud constant squeak.i have the same problem, but now it is a loud constant squeak.
AnonymousMar 24, 2009
My dryer is doing the same thing. It is a Frigidaire Model #FEX831CSO. The squeaking is getting louder and louder. HELP!!! My dryer is doing the same thing. It is a Frigidaire Model #FEX831CSO. The squeaking is getting louder and louder. HELP!!!
You can't post conmments that contain an email address.
A model number would greatly help, the dryer is most likely made by Frigidaire for Kenmore, your squeal is probably from a dried our drum support bearing at the rear center of the drum. If this is the case, an experienced repairman is advised to make this repair. Pleazer Appliance...
I understand that the dryer portion of your laundry center, model#FEX831FS2, takes too long to dry, even after making sure the vents are clear. First, I suggest checking the exhaust duct, making sure it is at least 4 inches in diameter and made of rigid or flexible metal. Secondly, make sure the duct has no more than two 90 degree bends and must not exceed length listed in the INSTALLATION INSTRUCTIONS. Lastly, make sure your dryer is connected to a 240 volt circuit. Drying time will be 20% longer than drying on a 240 volt circuit. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dryer status has changed successfully.
If you live in Pasadena, CA and you need a Dryer repair service our professional technicians will perfectly repair your dryer as fast as possible. All you need to do is to call at (626) 460-0903 or visit our website http://www.appliancerepairspasadena.com .
Belt needs to be replaced,have you ever had a car drive by and heard a squealing noise? dryer belts "glaze" and squeal due to wear just like the ones in your engine
this is a frigidaire made dryer with kenmores name on it. The drum bearing needs more grease. You really need to know what your doing before you take that job on yourself. Its easy for me...but I have been doing it for 20 years and thats the way I role
If the clothes catch on the drum edge the felt seal is worn out , and the squeak could be the bearing the drum rest on or the belt tentioner , it may need oiled , you can buy the felt seal replacement kits online and they are not hard to install.
Hope this helps.
Phil
