Question about Frigidaire Refrigerators
No ice from ice maker
It appears that there is no water getting to the ice tray. My water filter is good and I'm getting water thru the water dispenser just fine. The ice mechanism rotates to expell the ice cubes and also the on/off bar is working. Its just that there's no ice cubes to expell. Is there a valve behind the ice maker? Is there a sensor to tell if it needs water? Could there be something clogged up ? It's been running fine for 8 years
Sounds like the inlet valve is defective. you should have a dual water inlet valve, one side for the dispencer and the other for the ice maker. I would check to be sure the inlet for the icemaker is not clogged, also check to be sure that ice has not clogged the water line near the ice maker, or the valve could be defective.
Posted on Feb 20, 2009
Kenmore side by side,no water going into the the Ice maker
"IF" the unit worked before the filter change you have to check a few things. First I want you to run a few cups of water from the in door water dispenser to make sure that all the air is out of the line and out of the filter. IF you encounter any sputtering in doing this it means that the air is coming out of the system. Keep it up until the sputtering stops then let it make ice until the cubes come out. Most of the time the air in the filter takes a few days to process thru the system and start filling the ice tray.
Second if the water comes thru ok without sputtering after five cups then check where the water goes into the back of the freezer compartment. disconnect the fitting and check for ice at that point. if ice get a pan of hot water and dip that end into it to melt the ice in the tube and then afterwards, reinstall it in the back of the fridge and make some ice. You can verify that it is not a valve problem by putting the tube end in a plastic container and letting the ice maker go thru a cycle or two. water should come out and be in the container in the amount of water it takes to fill the ice maker tray.
Third, is the check process of item two. Verify if water comes thru the tubing to fill the ice maker, If not, turn off the water valve supplying the fridge and check for grit in the line clogging the opening in the valve. if grit is present clean it as best you can. IF you have the proper tools and knowledge you can back flush the valve and remove the grit blocking the valve..
This should clear the line and verify proper working of the water control valve and filter. If at any point you have a failure in the checking process it should point you to the failure rather easily. If you suspect it is the valve verify from the label on it the operating voltage and IF, AND ONLY IF, you have a knowledge of electricity and test procedures test the valve with the proper voltage applied. IF you do not understand electricity, do not do it. you might injure yourself or worse.
Goodluck in your testing.
Feb 16, 2015 | Kenmore Refrigerators
Ice maker quit working but water dispenser still works,the reservoir to make cubes also empty.can you advise?
If the ice maker tray is empty you may have a water valve failure. usually this unit have a dual valve 1 for the dispenser the other one for the ice maker some time a side fail and the entire solenoid have to be replace. the ice maker can also be bad. an easy way for you to test if ice maker is good is by putting water manually inside the ice maker tray depending on how cold is your frig wait about 2 hrs or less if the ice maker cycles and drop ice then water solenoid is the problem if not then replace ice maker.
Dec 20, 2014 | KitchenAid Refrigerators
I have slimey, flaky sediment at the bottom of my glass of ice water. The water side is clear. I have a Whirlpool refrigerator with filter at bottom of freezer side. What can I do?
Your ice maker has a type of mold in it. Dump the ice turn off the water to the ice maker and let the ice maker clear the ice in it. Then get a spray bottle, put a little laundry liquid bleach and water in it and spray the tray where the ice cubes are made. . Let it sit for 10 or so minutes.then turn back on the water and let the ice maker go thru several cycles, dump that ice and then you're good to go.
Jan 06, 2014 | Whirlpool Refrigerators
The ice maker
see this causes and fix it. God bless you
Makes to much ice or won't shut off.
Check shutoff arm. This may be hung up on ice or food item.
Makes no ice.
Check shutoff arm. Check to make sure it is getting water, check water solenoid. Check water supply line it may be frozen or plugged up. Check freezer temperature to low of a temperature could cause the line to freeze up. Check for power at motor. You will need to remove the ice maker. Find the leads that go to the auger and connect a voltmeter. Press the dispenser lever you should have power if not replace the control board or micro switch. Check control switch or microswitch. Put icemaker in test mode. Only some are equipped.
Ice cubes to large or small.
Adjust size by removing cover and turn adjustment screw + or -. Check water solenoid. Check water supply line. Make sure it is level.
Ice tastes bad
Clean ice tray. Check supply line. Check water solenoid. Change filter. Run at least a 3 gallons of water thru the line after replacing filter this will flush all old water.
Ice is discolored.
Check water solenoid. Check supply line. Change filter. Clean ice tray. Run at least a 3 gallons of water thru the line after replacing filter this will flush all old water.
Most ice maker problems require either replacing the ice maker unit or the ice dispenser control board or micro switches.
Sep 28, 2012 | Washing Machines
Samsung RS265TD Ice maker does not fill with water. After I press test button and the ice maker cycles I manually fill the tray with water and it will eject on next cycle etc. Good water supply on thru...
Either the fill solinoid is bad or the inlet tube at the ice maker is frozen.
Try running a hair dryer to remove any ice that may be blocking the water from coming into the ice maker tray.
Jul 28, 2011 | Samsung RS265TD
Hi there, We are having problems with our ice maker on our GE Profile Model # SRD2054W, purchased October 1995. I know it's old, but it has been a good appliance until now. The ice maker fills but the...
What you think is probably correct. Water valves can seep water and freeze the fill tube. Remove the ice maker and the fill tube remove ice from the fill tube and replace the water valve.
Apr 16, 2010 | GE Profile 23.1 Cu. Ft. Side-by-Side...
Ice maker not working
Are you sure you have the RIGHT Filter cartridge? If so, does your system have a water dispenser and if so.. is that working? If not.. some but not all ice makers have a test button under the removable service cover.. If your has it and it should fill your ice tray directly after that.. If it doesn't then.. are you sure you have water back on to the system? can you reinstall the old filiter as a quick test to see if that's the problem?.. Thru a few ideas at you and hope one of them will get you going with ice.. BTW.. some systems take a pretty long time to cycle thru ( fill the air cavities with water , before they show any sign of life..meaning ice cubes)
Hope that helps !
Aug 18, 2008 | Roper RS22AQXKQ Side by Side Refrigerator
Water doesnt stop after ice tray is filled
there is a micro switch in the ice maker motor module that shuts power off to the ice-maker water valve when the ice maker is full but i rarely see them go bad this is the easy way to deal with it pull the unit out unplug both the valves and turn the water on a sec if its running in the ice maker with the valves are unplugged then replace the valves if its not replace the ice-maker motor module
Mar 28, 2008 | Kenmore 21.7 cu. ft. Side-by-Side...
Refrigerators Logo
170 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
