Question about LG DLG5988 Gas Dryer
LG dlg5988W Gas Dryer - flashing "clean filter" light
I have the same problem. The dryer was working fine. Now, when I start the dryer it flashes "clean filter" . I'vecleaned out the lint screen, washed it and even vacuumed inside the lint area, wiped down the door and I even checked the vent on the back and outside. Still nothing. Help!
  • 1 more comment
  • Anonymous Mar 15, 2009
    Power comes on, but "check filter" light keeps it from running.  When trying to push the "play" button to get the dryer running, it just hums loudly until I shut off the power or "pause" it.
  • Rutele Apr 16, 2009
    same problem, I have done all the same cleaning things too-did not help. it will go on now and then but it will automatically only go on at the normal setting. Help!!!
  • Anonymous May 04, 2009
    I have the same issue with my LG gas dryer. When powering the clean lint flashes. I'd clean the filter and ducts. And it still flashes. Does any one know how to reset this? My dryer too tumbles but no heat. The cooling light stays lit. This might be half my problem.
I got the same problem and no repair man could help . i think i just got mine fixed 6-15-09 .what you do is go behind the dryer , remove the air duct and then remove the pipe that is inside the machine by removing one screw . this will give you access inside the machine .first clean as much as you can of the lint inside by vacuuming it . if you look to the left you will see 2 wires with a black button in the middle this is the ignitor ,clean it good because i think the dirt is not allowing it to light up . i did that and mine is working but the cooling light is still on .
Posted on Jun 16, 2009
It is not nessary to tare the dryer apart simply open the dryer door and remove the two screws holding the lint screen holder on. Remove the screen holder and on the right hand side there are two prongs. just clead them and your good to go.
Posted on Dec 23, 2009
  • gregoryjw220 Nov 18, 2010
    These "prongs" are the leads for the moisture detector. This didn't work for me, but I could see how it would be a problem if lint shorted these two leads. 5 minutes to clean and check.
LG DLG5988W
check your door interlocks and connections
Mar 15, 2008 | LG DLG5988 Gas Dryer
My lg tromm DLG69885 gas dryer is not heating; otherwise it works fine. Dry light flashes cooling light stays on solid
I am using LG Tromm DLE2514 washer dryer. It 's running but didn't dried the clothes. I clean it's lint but still it's not working. The one thing i notice now is it's drying light is blinking and cooling light is turn on all the time during the cycle. So what's the problem with my dryer?
May 20, 2010 | LG DLG5932W Gas Dryer
Lg dlg2522w check filter flashing, motor spins,no
Did you put a load of wet clothes in the dryer and run it?
You can't change the setting while it's running.
The sensors won't let it heat up if there is nothing in the dryer.
This is not your grandmas dryer, this is a high tech machine.
There is probably nothing wrong with it.
Oh and the filter light flashes like that, it is supposed to, it is telling you to check the filter for lint.
Nov 24, 2009 | Zanussi FJD1666W Front Load Washer
LG Gas Dryer (Model # DLG5988W) is not heating, the gas is not turning on. When the dryer is turned on the ''Check Filter'' light comes on and when switching to a drying cycle the ?Cool? light is always...
The dryer has a resettable SAFETY thermostat located on the flame tube inside the dryer. LG recommends replacing the Safety and High limit thermostats if the Safety thermostat is tripped. The dryer Glow bar igniter could be bad as well as the gas valve or Main computer. Time to have the dryer serviced by a qualified LG tech. LG has factory service tech in most large cities. Give them a call at 1 800 243-0000.
Hope this helps.
Mike
Oct 31, 2017 | LG Dryers
Lg dryer tromm dlg5988w flashes filter code will not dry
Check your filter, your vent and clean them well. Shut down the power and let it reset itself.
Jun 09, 2009 | Dryers
My LG dryer will not power up
You may have a broken door switch.  That would be the most likely source of your problem since the machine will not work if the computer senses that the door isn't closed.
Mar 15, 2008 | LG DLG5932W Gas Dryer
My LG gas dryer DLG5988W
somethin might stuck down insinde the channel where the llint filter goes, small sock baby tee or somethin to that effect, it rests against fan and prevents motor from turning, usually lookin down with a flashlight will confirm this
Mar 02, 2008 | Dryers
LG DLG5988W DRyER NOT DRYING
Sounds like you have solved your problem.
Sep 26, 2007 | LG DLG5988 Gas Dryer
LG DLG5988 Gas Dryer Logo
2,081 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
