Question about Pioneer DEH-1600 CD Player
Radio does not come on
I am trying to install a Pioneer radio in my 1999 ford taurus. It is not a new radio, i took it out of my old car. I am not sure i have all the wires right but i know that the acc, battery and memory are connected right (because there is continuity) but the radio will not come on. How do i even make sue that the radio is not faulty?
btw, i am not sure that the product i selected is the right one but it is a pioneer cd player.
  • omobtomtom Feb 20, 2009
    Thanks a lot. I had checked the fuses and checked the wires you mentioned and there was 12V to the wire. But before i toss the radio, is there a way to be really sure that it is bad?
    Also, i read somewhere that you had to disconnect the negative terminal of the battery before trying to hook a radio up. i didn't do this, does this mess anything up?
  • 41 Answers
There are a few things you may need to check:
1.Make sure you have 12v to the yellow wire on the harness with a good ground at the black wire, and the red wire should be your ignition switched acc wire.
2.Make sure your fuse under the radios wire harness connector is good.
If all of that is in order hook it up, turn the key on and hit the on/off button on the cd player, most aftermarket radios require you to manually turn them on the first time, and anytime the battery is disconnected. If is still doesn't work the unit is more than likely bad.
Posted on Feb 20, 2009
  • Randy McCall Feb 22, 2009
    Most of the time they recommend you disconnect the negative battery terminal, but i never do it is mostly a "CYA" thing. if you were to cut a positive wire with your tool grounded there is a possibility for damage in the vehicle that's the main reason for disconnecting it.
    If you wanted to bench test the unit outside the vehicle you could twist the yellow and red wire together and connect to the positive side of a battery and then ground the black lead and see if the radio will turn on. For this test you can usually use a 9v battery such as a smoke alarm battery if you dont have a car battery laying around. If you do this test and it does turn on dont leave it on for very long or you run the risk of damaging the audio output transistors. but a few seconds to see if it turns on will do no harm.
    If the radio passes the bench test then you have a wiring problem to trace and probably on your grounded side in the vehicle.
What is the code for factory installed radio
Every radio is different and has a separate unique code..
May 09, 2016 | 1999 Ford Taurus
WHAT DOES THE BATTERY LIGHT INDICATE ON A 1999 FORD TAURUS?
Sounds like your only problem is a very dead battery
If it was over 4 years old & you had load tested it,you
wouldn't have all that bad experience
Any idea why you installed a new alternator other than a guess,
no testing,well the dead battery may be an issue there as well
Feb 10, 2013 | 1999 Ford Taurus
Need to figure out what wires r what from the radio
you need to use the right adapter for your car and that radio. you don't want to mess with the wires. get the right adapter and avoid damage to the radio and/or the speakers or maybe a car fire
May 23, 2010 | 1999 Ford Taurus
1999 ford taurus speaker wires color code
the speaker wires are the same color at the rear control module as they are at the head unit
are you trying to replace the "football" type radio?
if so...what you are actually replacing is the "remote" for the rear control unit.
See the place you bought the radio from for a "special" kit to install an aftermarket radio on this system
Jan 21, 2010 | 1999 Ford Taurus
Trying to install a new pioneer radio to a 1999 jeep
try walmart they have the wiring harness that you need to install your radio for about 6 dollars
Aug 10, 2009 | Pioneer DEH-1100 CD Player
1999 ford taurus stalling, phantom wiper pass and radio pops
this is all to common a problem with the wipers, it is caused by the combination wiper switch, it makes connection all by itself, Ford has issued a TSB (tenhnical service bulliten) on this problem, replace the switch.
Jun 10, 2009 | 1999 Ford Taurus
Battery will not hold a charge
I WOULD HOOK UP THE RADIO TO A DIFFERENT POWER SOURCE IN THE FUSE BOX. TRY A WIRE DIRECTLY TO THE FUSE BOX, AND SEE WHAT HAPPENS.
Mar 11, 2009 | 1999 Ford Taurus
Stuck installing my Pioneer DEH-1000E
yes try that. I had a Isuzu Bighorn and put a new Sony CD player in, but i used the old casing to fit the new one. so you could try using the old casing, or buy a new one.
Jan 10, 2009 | Pioneer DEH-1000 CD Changer
No sound
I just installed an aftermarket radio in a 93 mustang and I had to hook up the blue wire for the power amp to work. I am not an expert just passing on what fixed my problem. Good luck
Dec 08, 2008 | 1999 Ford Taurus
Pioneer DEH-1600 CD Player Logo
100 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
