Question about InVion GPS-7v1 GPS Receiver
I have an Invion 5v106 and the unit will not turn on at all.
Anyone else having this problem? I plug it into the charger and the red light goes on but when i try to turn the unit on even while plugged in it won't turn on.
  • 111 Answers
Use a paper clip and insert it in the "reset" hole on the side of the unit next to the memory card expansion slot.
Posted on Jul 01, 2009
Charger not working
When the red light is on it is to indicate that the charger is getting power from the wall outlet. If there is a second light that normally comes on Green when charging pay close attention to it when you first plug the charger in. See if it blinks even once then turns off. If it does that means the charger is not seeing any battery voltage at the plug that goes into the chair. If the green light does not blink at all then it usually means the charger is defective. Also most wheelchair battery chargers will not charge the batteries if the chair is to dead to even turn on.
Apr 12, 2015 | Health & Beauty
Motorola s9 headset wont turn on
Mine is doing the exact same thing. Does anyone know what the problem is? If so, what is the fix.
Apr 27, 2012 | Motorola Mobility MOTOROKR S9 Wireless...
Brand new, never used. Plug into wall to charge and just get flashing red light. After 16 hrs on charge, still flashing red and when turn on, screen blinks then shuts down.
check that you have the battery in the correct way
if it has batteries like AA , AAA or what ever the negative terminal of the battery goes against the coil spring so if you have them all facing the same way, that may be why they are not charging
the screen shutting down at this stage would be cause the batteries are flat
of course you could always bet new fully charged rechargeable batteries and put them in correctly to see if the rest works
Apr 30, 2017 | Sylvania SDVD7015 7 in Portable DVD Player
Old or New battery not charging...or so it seems (Discovery 4XXX)
the charger is not charging its not putting any thing out into the batterys the charger clock is working but your not getting any charge from it
Mar 21, 2010 | iRobot Roomba 4210 Bagless Robotic Vacuum
My bold wont turn on. when charging, red light goes on and off
did you try the car charger,wall charger might be faulty,if that does'nt pan out,might need new battery
Oct 20, 2009 | RIM BlackBerry Bold Smartphone
Hello, when I turn my Invion GPS model: gps-4v506-ius, and then seect the navigation screen, it says "map not found." It's been like that for a couple months now, HELP!!!
Believe it! if it says maps not found putting it away for a few months wont repair it Ypu need to have the maps reinstalled. possible to corrupt maps easily by a spike from car charger or even leaving unit in a hot car or starting the engine while unit connected.
Jul 28, 2009 | InVion 4v1 GPS Receiver
Charger red light on
I have heard of one other doing this. Either the charger or the battery is toast. If it's under warranty, call Humminbird.
If not, have a look around for a new battery or charger. They can be had at a good electronics store for not a bad price.
Best of luck!
Jul 02, 2009 | Humminbird Piranhamax 210 Portable
I have been trying to charge my samsung wep200 but the red light keeps turning off, does that mean its fully charged or is there a problem with it?
I had the same problem. Red light would be on for a second, then nothing.
This sounds like the dumbest, most obvious thing, but I started playing with the connections. Assumed it was the two contacts inside the box not touching, but that wasn't it.
Finally wiggled the charger plug that goes into the hole in the box, and when I pushed it in really hard, tada, the red light went on and stayed. I still have to jam the plug in for it to work, but it charges the headset fine now.
Must be a design flaw. If your unit is still under warranty, you might try to get a new charger with a better plug fit, if your problem is similar to mine.
Nov 26, 2008 | Samsung WEP200 Wireless Headset
Mx 3000 universal lcd remote
There are 4 reasons why your unit is behaving this way:
1. Charger is the problem.
2. The docking station is the broken.
3. The battery is broken or not accepting charge.
4. The actual unit is the problem.
It is very hard to tell which one is causing this to happen.
Let us do some troubleshooting first:
1. Plug your charger in an A/C outlet and make sure the red power light (left) is lit, otherwise the charger or the docking station is broken.
2. You can test the charger with a multimeter. Unplug the charger from the docking station and measure the voltage across the outside and inside, it should register more than 5 volts DC. If there is a 5Volt DC the docking station is the problem otherwise the charger is broken.
3. If the red power light is lit and the status light (right) is lit too, your docking station is broken.
4. If the red power light is lit, dock the unit into the charger, the status light (left) should turn red when your battery is accepting charge or turn blue when your battery is fully charged.
5. If the status light will not lit at all (while the red power light is on), tap the screen while the unit is docked on the charger. If the unit will become alive, you need a new battery otherwise you need a new unit.
12 hours is very long time to charge, the status light should turn to blue in less than 2 hours especially for a new battery.
Aug 29, 2008 | Universal Remote Control MX-3000 LCD...
De walt de9118 charger
when charger is plug in to ac it will blink once.normal voltage out for the unit in between 36v to 55 volt. the reading u have is normal.
Aug 07, 2008 | Dewalt 7.2-18.0 Volt One Hour Charger
InVion GPS-7v1 GPS Receiver Logo
233 people viewed this question
Top InVion GPS Experts
Will Halftowaite
Are you an InVion GPS Expert? Answer questions, earn points and help others
