Question about Electrolux Kenmore 3.5 cu. ft. I.E.C. High-Efficiency Front Load Washer / Dryer
Stops at spin cycle
Hi. I have a Kenmore Super Capacity 3.5 Front Load Washer and it works until the spin cycle. Any help would be great. Thanks.
  • mylpbiz Feb 20, 2009
    Well, it's a front loader so I'm not sure I could hear a click. Is there a way I could check the switch on a it without taking it all apart?
  • 117 Answers
Open the lid to the washer and let it down gently. You should hear a click when the lid closes. If you don't hear it, the lid switch might be faulty and this will prevent the washer from going into spin. Not an expensive repair.
http://tclaundryrepair.com/
Posted on Feb 20, 2009
  • nailuj12 Feb 20, 2009
    Sorry I did not catch that it was a front loader. You will not be able to diagnose it the way I stated previously. Your problem will have to be diagnosed by a tech to find the spin problem.
I have a Kenmore HE 2plus front load washer and during any wash cycle the drum won't spin and at end of cycle displays F01
Front-loading washer Kenmore HE2 plus - spinning not ...
www.shopyourway.com > Manage My Life > Questions
My Kenmore HE2 plus washer has problems with spin funciton. almost all of the ... or twins size blanket, it just won't spin, even with extra spin cycle only. ... Check to see if the washer will spin without any clothes at all in the basket. ... My HE2 will wash a very small load. ... Any bigger loads The drum will try and turn but wont.
Front Load Washer Won't Drain or Spin Video: Washing ...
? 1:54
https://www.youtube.com/watch?v=wlMoT9rgvAg
Jun 1, 2012 - Uploaded by searspartsdirect
... won't drain or spin. For more front load washing machineinformation and repai. ... If the cycle has completed and water is still left in the machine select "Drain and Spin" to remove anywater remaining in the washer. This can be caused .... I have aKenmore HE2 plus front load washer. I can't seem to get it ...
Kenmore HE2 Plus 3.6 cu. ft. Front-Load Super Capacity ...
www.kenmore.com > Laundry > Washers > Front-load Washers
KenmoreFront-Load Super Capacity Washing Machine (4753) .... super wet, and to spin the empty drum after each load to hear if anything was caught in that gap. .... 1st of all: You cannot use any other detergent than HE rated detergent - PERIOD. ... will create too many suds and clog up the machine, and the clothes won't be clean.
Jan 15, 2016 | Kenmore Washing Machines
My washer won't spin out at the end of the load
you should check the brushes on the motor they wear down which stops the motor spinning.you can ring a washing machine repair shop give them yr modal number and they can alder some new ones,this is what i did and my machine worked fine after that.
Mar 24, 2013 | Kenmore Washing Machines
Kenmore super capacity washer3.5 not working lights flashes and stops
This is usually a sign that the drain pump filter needs to be dumped or an object has jambed the pump mechanism.
Jan 30, 2013 | Kenmore 3.5 cu. ft. Front Load Electric...
I have a kenmore washer that does not drain and spin at the end of the wash cycle....Kenmore Super Capacity 3.5...Quiet Tumble Action...Easy Access
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 02, 2010 | Frigidaire ATF6000ES Front Load Washer
Kenmore washer 3.5 super capacity. Machine spins
It sounds like your tub bearing is bad or going bad. It could be the adjustment on your spin cycle. Does your unit allow you to adjust this. Also are you overloading. Can you send me the brand and model of your unit and I help you more.
JimmyC
Oct 05, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
Washer sometimes leaves clothes sopping wet - then the next day O
you can remove the bottom access panel to get to the drain pump. there might be something in the coin trap.
Jun 24, 2009 | Kenmore 44072 Front Load Washer
Won't fill w/ water, Kenmore 3.5 Super Capacity Front Loader
The pressure switch is likely to blame. Change it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 28, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
Washing machine suddenly stopped working during cycle
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Jan 01, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
Kenmore Super Capacity front loading washer that has stopped.
Hello SMCCRAVE,
You are referring to a top loader problem.
A front loader is different the following is from the youtube page that has video explaining the possible issues!
Washing machine not spinning? This video provides information on how to troubleshoot a front-load washer that won't spin and the most likely defective parts associated with this problem. These are sorted from most likely to least likely to be the issue.
Commonly replaced washer parts:
Drive belt
Door lock switch
Motor control board
Stator/rotor
Drive motor
Good Luck!
Rich Lilja
May 21, 2017 | Kenmore 46462 Front Load Washer
Pounding noise after wash and final spin
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
    if this helps please give a fix ya vote
  • Jul 14, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
    Electrolux Kenmore 3.5 cu. ft. I.E.C. High-Efficiency Front Load Washer / Dryer Logo
    841 people viewed this question
    Top Electrolux Washing Machines Experts
    Tim Whalen
    Dan Webster
    Dan Webster
    Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
