Question about Palm Tungsten E2 Handheld
The screen keeps going blank on my palm tungsten E2. I turn it off and then back on and it works for a few minutes and then goes blank again. Any ideas on the problem and a fix for it?
SOURCE: Need to delete contacts in Palm Tungsten E2
try 2 select all amd delite
Ravindran
bs.ravindran@gmail.com
Posted on Jan 03, 2008
cfpalmguy
  • 38 Answers
SOURCE: Audio doesn't work on Tungsten E2.
I was reading about this guy who'll do it for alot less here's the URL to the page
http://www.alaskarails.org/palm.html
If you wanted to do it yourself youll need to get a PDA repair kit for 9.95 from pdasmart.com and pop it open (4 torx screws and use a shim tool to pry it open , be careful) and follow anti static procedures ( touch a metal object frequently ) once open check the contacts for the speaker and while your at it the head phone jack if they look fine they may need cleaning. use your favorite electronics cleaner and clean them. This is only if your lucky you'll probably need to replace one/both by placing a soldering iron and melting the contacts off and getting a replacement part and soldering it carefully in place, you'll get a replacement from another broken T|E \ T|E2 or from a PDA replacements parts store of your choice
a refurbished T|X at PDAsmart will cost you $199 if I were to spend any money it wouldn't be at the Palm repair shop
Posted on Jun 19, 2008
Just_Bobz
  • 448 Answers
SOURCE: Palm Tungsten E2 error
Everytime I got that error, press soft reset on back and it should reboot normal
Posted on Jan 01, 2009
Just_Bobz
  • 448 Answers
SOURCE: Palm Tungsten E/E2 digitizer - fragile?
Palm one is in trouble because of problems like this. They don't work on it but you can buy parts to try it yourself. I never had the problem myself but similar conditions. I do windows based units now.
Posted on Jan 02, 2009
SirSolveAlot
  • 3 Answers
SOURCE: Forgot my password for my Palm Tungsten E2
well you have to think deep go into a spiritual memory laps and try and resolve your deep inner confrontations help your self and YOU will find the answer.
Posted on May 18, 2009
My Palm Tungsten e2 keeps turning itself back on...it stays off for about 15 seconds after pushing the power key and then comes on again. Anything I can do?
I too was having this problem all of a sudden. I found another post about an apparent bug in the Palm OS. Do you have a birthday or appointment in the calendar with reminders that started in 2009? Try removing the reminders or making them start in 2010. I did that and my Palm now stays off when I power it off.
Jan 02, 2010 | Palm Tungsten E2 Handheld
My palm e2 screen brings a frozen screen even after reset and no button whatsoever works, it can reset but freezes on the screen again,that is 0 alerts. even the power button does not work, only reset,...
You can try doing a hard reset. A hard reset will delete everything on your device. All your data will be deleted, and formats, preferences and other settings are restored to their factory default settings. Don't perform a hard reset unless you've backed up your data, or you're willing to lose everything. Here is the link for directions for the Hard Reset:
http://kb.palm.com/wps/portal/kb/na/tungsten/e2/unlocked/solutions/article/42094_en.html#tx
Nov 18, 2009 | Palm Tungsten E2 Handheld
May 18, 2009 | Palm Tungsten E Handheld
Tungsten E2 just stopped while adding data said fatal error
Well had to do a hard reset- lost everything, had no back up, long story don't think I'll bother with palm ever again!
Apr 11, 2009 | Palm Tungsten T5 Handheld
Tungsten E2 has lit screen & not responding
You can take the back off and unplug the battery for a few mins, this sometimes will clear a logic lock
Feb 27, 2009 | Palm Tungsten E2 Handheld
Dec 30, 2008 | Palm Tungsten E2 Handheld
Palm tungsten e2 will not turn on, replaced batttery,
Plug you E2 into your PC for 8 hours to slow charge. Press reset button on back and later in life your E2 will come on by itself.
Dec 23, 2008 | Palm Tungsten E2 Handheld
My e2 frozen on the palm powered logo
Okay here it goes, your going to want to leave it on for however many hours it takes to completely drain the battery then you're going to want to recharge it back to normal charge, and try restarting it again. This will delete completely anything that is keeping it from restarting properly. If you did open up the machine without following "antistatic procedure" you may have fried a component on the board and then your in trouble
you'll need to salvage a board from another tungsten and put it back in your PDA and hope you put it back together right
May 28, 2008 | Palm Tungsten E2 Handheld
Is this a battery problem?
If it's not the E2 going to sleep mode ;-), have it checked by a Palm service center http://www.palm.com/us/support/contact/repair.html .It might just need a new battery. Worst case scenario the charging system is faulty. Have it checked.
Hope that helps. Let me know how you make out.
Jan 19, 2008 | Palm Tungsten E2 Handheld
Palm Tungsten E2 Handheld Logo
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
