Question about Amana DRS2462B Side by Side Refrigerator
Water leaking underneath icemaker, dripping into ice tray
Water is dripping at a slow pace underneath the icemaker, between the motor housing and where the ice is formed, and is forming icicles from under the icemaker, down into the ice tray below. The inner painted liner of the icemaker, on the wall adjacent to the motor housing, has delaminated, and it is (perhaps coincidentally) in that same area underneath the icemaker, where the leak is occurring.
  • Amana Master
  • 19,396 Answers
Either the inlet valve is stuck or the icemaker solenoid is shored.
Most likely the first one.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Posted on May 22, 2009
Ice maker overfills the ice tray, ejecting large block of ice instead of individual cubes.
What is your model number? Sounds like you may need a new icemaker. Sometimes when the icemaker motor goes bad it causes the icemaker to keep filling even though it hasn't kicked out the ice in there. Also, are you sure there isn't 2 valves on the refrigerator?
Nov 15, 2015 | Refrigerators
My icemaker fills the tray but when the water shuts off it drips on the the ledge under the tray and ice builds up. Also now my ice cube tray seems to be leaking.Are parts available or does the entire unit...
My ice maker would not return to a level position after dumping out the ice. When the water turned on to refill the ice tray, it would run off the tilted ice tray and into the ice basket thus freezing all the ice cubes in the basket together. To remove the icemaker, there are two screws that hold the icemaker to the top of the freezer. Turn off the icemaker. Remove the left screw and loosen the right screw by removing the screw on the left. Slide the icemaker outward and it should come loose. Unplug the power connector from the icemaker to the freezer. The ice tray can be removed from the icemaker by gently pulling the tray to the right and the slot it goes into on the left side of the icemaker to the left. Once the tray is out of the assembly, inspect the round plastic shaft on the left side of the ice tray. Mine had two flat spots that were worn into the plastic from use. I used a dremel tool with a round barrel sanding disk at the tools lowest speed to remove the flat spots and decrease the overall diameter of the shaft which stopped the tray from sticking. Reassemble the ice tray in the icemaker.
Mar 10, 2010 | LG LSC26905TT Side by Side Refrigerator
All water underneath.ice in the bottom.freezer working.not making
If I understand you correctly your water line that comes through the back wall of the freezer and into the icemaker is frozen. If so you have a bad water valve. When the valve goes bad it will not seal off the water. It will seep causing a slow drip where the water comes out at you icemaker. It'd slow enough to freez causing a ice blockage. This will not allow water to come through and fill your icemaker when it calls for water.
Aug 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Maytag ice maker will not release cubes
Sounds like it has a " seeping " water valve . Only thing to do is replace the water inlet valve . There is a certain amount of water to go into icemaker at fill . A seeping valve will let water continually drip into icemaker , making large cubes which icemaker cannot dump . A larger amount of seeping , will overfill the icemaker , and drip into the freezer and floor .
Aug 12, 2009 | Maytag Refrigerators
Water leaking from icemaker on outside
If this is your water dispenser leaking
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
Jul 08, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Water Leaks from Ice Maker of Sub-Zero 642
Sounds like the water inlet valve to icemaker is leaking - not closing completely after filling the tray. Rare, but possible. Prove it by shutting off icemaker arm or switch. If that is the cause, the drip will continue.
If dripping stops when I/M is off, then it is ice blockage in I/M fill tube and or diverter funnel at end of ice tray. Remove I/M, clean ice from both, and re-assemble.
Replacing that valve (water supply to refrig connects to it in the back) should solve it.
Jun 13, 2009 | Sub-Zero 30.1 cu. ft. Cabinet Depth...
Icemaker leaking causing icicles
Is it overfilling with water? If so, it may be an problem with the fill valve leaking slightly. I say slightly because if it were a large leak, the freezer would have frozen puddles in it. Also check the water chute to be sure the water is all going into the freeze tray. Sometimes they can work loose.
If the seam is leaking, there could be a crack in the housing - not sure that's repairable - sometimes epoxy will work (5 minute, 2 part) but it can be difficult for glue to hold on the type of plastic used in an ise maker housing.
Mar 27, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Kenmore refer #70162990 ice maker leaking into storage tray
Please confirm you have given the complete model number.
If the icemaker has a bail wire to control how much ice is in the bin, there is a fill switch inside the front cover of the ice maker which allows you to increase or decrease the amount of fill.
You may also have a cracked or corroded ice mold. Check by filling the icemaker with water manually, and watching to see if it drips once the initial overfill stops dripping. This would also be indicated by the ice cubes being smaller than usual.
Jan 04, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Ice Maker Overflowing
i would recommend changing the water valves as they may be sticking or leaking now you can take the icemaker loose get a small baby bottle short the terminals to cycle water fill catch it with the bottle and see how much water it dumps should be about 4 ounces if the valve leaks will over fill the ice maker over a period of time say the valve is leaking a few drops at a time and the bail arm has the icemaker shut off because its touching ice in the bin but the water just keeps dripping down the fill tube till it runs over did you replace the whole icemaker or just the motor module
Jan 01, 2008 | Maytag MSD2434GE Side by Side Refrigerator
Amana DRS2462B Side by Side Refrigerator Logo
604 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
