The RCA TV codes for an Innovage Jumbo Remote are: 000, 003, 004, 005, 007, 009, 011, 015, 048, 082, 092, 094, 096, 098, 101, 102, 103, 107, 113, 125, 129, 167, 179, 187, 188, 191, & 194.
To program your remote by entering a code, follow these steps:
- Turn on your TV.
- Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
- Press the TV button on the remote so that the LED blinks once and then remains solid red.
- Enter the first set of 3-digit codes from the list. The LED will
blink once every keypress. After the 3rd digit, the red LED will turn
off indicating that the code was recognized for the device. If the code
was not compatible, the LED will flash several times and you need to
return to step 2 to try that code again or to try the next code in the
list.
- After the LED has turned off, aim the remote at the TV and press
ON/OFF. If the device turns off, you have used the correct code and the
remote was successfully programed. If the device does not power off,
return to step 2 and try again with the next code in the list.
There are so many codes to try, you may want to try the auto-search function that I am going to describe below.
I don't see a code for a Motorola cable box, so I advise using the auto-search function for CABLE or SAT.
To have the remote try each CABLE or SAT code it knows one at a time, follow these steps:
- Turn on your cable box.
- Press the CABLE or SAT button on the remote so that the LED blinks once and then remains solid red.
- Press the ON/OFF button slowly and repeatedly until
the cable box turns off. The LED will blink once each time you press the
ON/OFF button.
- Once the cable box turns off, press the ENTER button to store the code and the LED will turn off.
To program the remote for your TV, repeat this process starting with
turning the TV on, then follow the steps substituting the TV button
for the CABLE or SAT button.
I hope that helps.
Faulty lopt/fbt. Replaced and set OK now - just for everyone elses' reference...
rca wont turn on and it is blinking
