Question about 2wire 1800HG Router (RG1800HG00)
I have lost the power adapter for my 2 wire, I went to Radio Shack and bought one but it did not work, the Green light kepps flashing. please tell me where can i fint the original power adapter?
  • Yogs Rotli Feb 20, 2009
    thanks for the advice
    also if i have 2 modems can i use them for diffrent computers in the same house?
  • 447 Answers
You might just want to buy a used router on ebay and use the power adapter from it. Plus you end up with a spare/backup router.
From the prices I found online for that part (and most people had none in stock) it would be your quickest solution.
Posted on Feb 20, 2009
I have a 2Wire 2701 HG-B modem. It was working fine (3 green lights) then the power light turned red. I unplugged all cords and began searching online. After reading tons of similar complaints, I...
Sounds like Radio Shack sold you a bad power adapter or an adapter that doesn't meet the power and current requirements of the modem. Bring the old power adapter and the new one back to Radio Shack and tell them to get you one like the old one.
Nov 23, 2010 | Computers & Internet
I have a sharper image midi and the red light (cleaning overdue)stays on even after cleaning? Will it still work with the light on? My real question how to fix it
Same problem : after cleaning thoroughly inside by removing the Front& Rear Plastic grid and the stainless blades, I also cleaned the 2wires (very softly and carrefully, not to break them), but the Redlight goes on after only few minutes :
Here is my Solution :
1 - Turn on (Low position) although the Red ligt is on
2 - Release the Rear plastic Grid (or Front plastic grid, or both of them) : That stop the unit automatically
3 - Replace it and make sur it's well locked : the unit turns on automatically.
After that, my unit works well, no more Red light. Maybe it will work for you. I also found this other bit of information. Since then I have discovered a lot of information on the midi. Here is some more reading material that might interest you.
Could be a blade replacement needed but Sharper Image2.gifrecalled the product. Since it was proven in court that it wasn'teffectively cleaning the air by Consumer Reports as well as EPA data. As a result of the legal action, Sharper Image filed for Chapter 11.
Here are a few links about it:
http://www.consumeraffairs.com/news04/2008/02/sharper_image.html
http://www.epa.gov/iaq/pubs/ozonegen.htm
Sharper Image was giving customers a small rebate for the product since it was proven to be ineffective for cleaning the air by Consumer Reports as well data by the EPA.
This has caused a mess for Sharper Image that they went into bankruptcy as a result of it. The Consumer Products Safety Commissionis going to be making a decision on ionizers at the end of year sincethere are hazards in the air from using the devices. It could be thationizers are no longer sold in the US next year.
The industry should have been regulated and unfortunately the government never did anything about it until Sharper Image and Consumer Reports went to court on it. The next step to do if you can't get it to work is to file a report with the company.
The Ionic Breeze would work for a short time after cleaning and the bluelight would start flashing again. We checked the wall cube power adapter with a volt meter. It was putting out only 10 volts instead of the needed 12 volts. It seems The Ionic Breeze needs a full 12-13 volts to work. So we went to Radio Shack and bought a universal 12 volt 800ma power adapter. I checked the voltage in the new adapter, it was 13 volts. This fixed the flashing blue light problem. The Ionic Breeze produces harmful Ozone gas, so we don't use it anymore.
Best wishes. Hope this helps you. If not please leave me a comment and I will do some more research.
Aug 22, 2009 | Sharper Image Ionic Breeze GP SI730 Air...
There is a red blinking light and it is not cleaning.
My Ionic Breeze would work for a short time after cleaning and the blue light would start flashing and the unit would stop working. I checked the wall cube power adapter with a volt meter. It was putting out only 10 volts instead of the needed 12 volts. It seems The Ionic Breeze needs a full 12-13 volts to work. So I went to Radio Shack and bought a universal 12 volt 800ma power adapter. I checked the voltage in the new adapter, it was 13 volts. This fixed the flashing blue light problem. However the Ionic Breeze produces harmful Ozone gas, so I don't use it anymore.
Aug 09, 2009 | Sharper Image Professional Plus Ionic...
Hisense TL2020 - Won't come on.
Lay unit flat on table, remove stand and rear cover. When you remove back, you will see a power supply board in the middle of the set.There are (3)1000mfd @25 volt electroltics and (1)220mfd @16 volt electrltyic that have to be replaced to return to normal operation. This is not something to try if you are a novice as you must observe polarity when installing these caps. But this repair WILL return set to normal operation.
Jul 30, 2009 | Hisense TL1700 17 in. LCD Television
Looking for a car power adapter
Radio Shack carries the Protron PDV-288 AC charger. Please visit a local radio shack.
May 31, 2009 | Protron PDV-288 7" LCD Portable DVD Player
Remote control Radio Shack 15-2147 Toshiba HDTV DVD - HOW TO?
The code for a Radio Shack remote control for a Toshiba TV with a DVD built in is: 1945! It worked for me easily! Good luck.
Mar 22, 2009 | Radio Shack (15-2147) Remote Control
2wire 2701HG-B power light red
A sony psp power supply has the same specs and is a lot cheaper than R/Shack Got mine on E-Bay for under 4.00!!!!!!!!!!!! with FREE shippiong
Jan 02, 2009 | 2wire 2700HG-B Router (2700HGB)
Compaq JBL Platinum Series speakers
Make sure that you got 12v 1.0 A adapter. Not .01 A. They have one at newegg.com atrix DVCPA1AA power adapter-12v 1.0 A. you should not need drivers for speakers. Make sure you got it pluged into right port if you got the adapter. Also make sure under control panel under sound that you got it setup for two speakers.
Jun 29, 2008 | HP JBL Platinum Computer Speakers
Lost AC adapter
hey i have the same one, i use the old adapter from a playstation II or playstation should work,,,,,,sure fit and worked fine for years
Jan 21, 2008 | Sony S2 Sports ZS-X3CP CD Boombox
2wire 1800HG Router (RG1800HG00) Logo
331 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
