Question about Toshiba Satellite P15-S470 (PSP10U-0GGPGR) PC Notebook (PSP10U0GGPGRPSP10U0GGPGR) PC Desktop
My disk drive is not loading on my Toshiba laptop
When I click on "My Computer" I don't see an icon for my disk drive. When I try to use it get the following message.
disk Drive has been disconnected or turned off.
    Scholar:
  • 53 Answers
I am guessing you have windows xp installed
in your control panel go to admin tools computer management.Open disk management right click rescan all drives it should but your drive back. the computer think you hard disk is a removable drive.
if this did not fix then you have a regestery problem which is very hard to repair because messing around it there can cause windows to stop totally if the wrong files are changed.
Posted on Feb 20, 2009
How do i open my disk drive on toshiba laptop satellite c50-b
There must be a button on the side of the CR-ROM drive. Press it to open the drive. Insert the disk. If autoplay is enabled it will start. If not, explore My computer, locate the CD-Drive and click on its icon.
Aug 09, 2014 | Toshiba Satellite Computers & Internet
My computer do not recognize the toshiba roco HDD
Dose it show up as drive letter E:/ under device manager in disk drives?(Check out:right clicking my computer icon on your desktop,select disk manager)
If so,try right clicking on my computer and selecting map network drive.(You'll get the same results by right clicking on network neighborhood icon on your desktop and selecting map network drive.)This is the method many people use to assign a drive name (i.e.,letter) to a drive.Then you can recover data from external hard drive with data recovery software like Tenorshare Data Recovery.It can recover data after deeply scanning your hard drive to look for lost data.You can get it here: http://www.any-data-recovery.com/product/datarecoveryprofessional.htm
Aug 27, 2011 | Toshiba 120GB USB 2.0 Portable External...
I hav e Zoo Empire for Scholastic on disc, when I try to load it the computer does nothing. Why will it not autplay?
It seems that you have Autoplay disabled on your computer, OR the disk is damaged OR the disk don't have "autoplay.inf" file on his root.
The best solution is to put your disk into the drive and try to access it via FileManager: Double Left-Click on MyComputer icon on desktop -> locate the CD drive and make Right-Click on the CD icon followed by the "Explore" option selection. A new window appears which shows the CD content.
Locate a file called "setup.exe" or "install.exe" or similar, and make double left-click on it! That's it!
Jun 27, 2011 | Computers & Internet
HOW CAN I RESTORE TOSHIBA SATELLITE A205-S5804, I JUST WANT TO RESTORE MY LAPTOP TO FACTORY
I am glad to HELP YOU!
You will need to use RESTORE PARTITION [existing on your hard drive] or the RECOVERY DISKS.
Some details you have HERE.
GOOD LUCK!
... and don't forget to RATE, please...
Apr 26, 2011 | Toshiba Satellite A205-S5804 Notebook
When I connect WD 250 GB external harddisk ..I am getting error message" USB device Not recognized due to malfuction"..please guide me my laptop is toshiba and operating system is windows xp
Please trouble shoot by trying the device on another laptop.
If it works on another system, it simply means it is not compatible with yours and you have to get a device that is compatible with your toshiba system.
Good try.
Oct 17, 2009 | Western Digital WD Passport 250GB Portable...
Toshiba satellite memory stick problem
Sometimes when a flash memory stick fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so.
When the flash memory device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Healthy.
You need to format the external drive. Format the drive as primary drive and in FAT32. (FAT32 will allow data to be exchanged between MACs and PCs).
Insert the external hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Oct 09, 2009 | Toshiba Satellite A135-S4527 Notebook
Reformatting an external hard drive
Id you have a xp disk when it loads it will ask you how do you want to set up the drive even though you have and external drive on your computer in the my computer icon Right click and open manage open disk management and you should see your usb drive right click on the drive and you should see format it has a dropdown menu check quick format and click ok and it will start to format the drive make sure you chose ntfs in the drop down menu .good luck
Apr 08, 2009 | Toshiba 250GB TOSHIBA USB 2.0 PORTABLE...
"disk error" occurs when disk is inserted
the drive cannot read data from the disk, follow these instutions:
if you are using vista, right click on "computer" then select "manage" then select "device manager". look down the list until you find CD/DVD and click on the + icon next to it, then right click on the CD/DVD and select un-install (make sure that there is a disk in the drive, preferably a movie or music CD) then restart the computer, when the computer restarts vista will detect the drive and install the drivers again, look in computer to see if the disk has been recognised
let us know how you get on
and please remember to rate us
regards
Nov 28, 2008 | Televison & Video
Can't find DVD drive under My Computer and regedit fix doesn't work for it
you may have to check the registry manually and if this will not work, you may have to reinstall windows.
1. click start > run > regedit > ok.
2. In Registry Editor, expand the following registry path:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class
3. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}.
4. Delete Upper and Lower Filters. (If only one is availabel, that's fine).
5. Restart system and check your drive again.
NOTE: Make sure to do this correctly or else, system will not load to windows.
If manually deleting upper and lower filters will not work then you may have to backup your files and reinstall windows.
Aug 26, 2008 | Toshiba Satellite A70 Notebook
Toshiba Satellite A75-S206 DVD\CD-RW drive problem
Hello GeneMat,
I am Romeet,i will try and help you with this problem.Seems it could be an issue with the Combo DVD Drive's Driver Software or Firmware.
Try This:
From your Desktop:
Right Click " My Computer" Icon and select "Properties"
Go to "Hardware" Tab and select "Device Manager"
Under Device Manager, scroll down to the "DVD/CDROM Drives" menu and click on the plus ( + ) Sign next to it
Right Click the Drive name eg " Toshiba DVD-R TSST 2313" and select " Uninstall" Click yes to any prompts and restart your Laptop.
After rebooting, Windows XP should pick up the drivers again, so wait a while for it to complete and until it notifies you that " Windows successfully completed installing your new hardware" or something to that effect and then try using the software cds again
Best of luck!
Regds
Romeet
Dec 01, 2007 | Toshiba Satellite A75-S206 Notebook
Computers & Internet Logo
456 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
