Question about Kenmore 22422 Top Load Washer
Does not spin and makes noise when trying to spin
  • 4 more comments
  • sweetsjgal05 Feb 20, 2009
    Not sure what you mean by agitate.
    sorry not sure what you mean by agitate.
    Thanks. The agitate does not move.
    The agitation does not move. It only makes a loud noise when it is on the spin cycle, The wash and rinse cycle are fine.
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    Does the agitator in the center of the wash tub move like it normally would during the wash cycle, or does it just sit still while the washer makes noise?
  • Jeff Rockwell
    Does the washer agitate? Or, is this simply a no spin problem?
  • 15,935 Answers
It appears your timer or motor controller board has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 13, 2010
  • 6,784 Answers
HI. the first action is to test the lid switch. The lid switch ensures that the lid is closed before enabling the machine to spin or agitate. This feature was added after serious injuries resulted from people reaching into an operating washing machine. For this reason, the lid switch should never be bypassed. Aside from electrical problems, the switch may suffer from a mechanical problem. The lid may have a striker which depresses the switch when the lid is closed. Make sure the striker is functioning and aligned with the hole over the switch. Inspect the switch and make sure the metal strip is not bent out of position (if present). If your switch uses a mercury switch, make sure the mercury envelops the internal contacts when it is in the closed lid position. Your design may differ, so inspect it for proper operation before proceeding to the electrical testing.There are two primary types of lid switches. One type on which you can directly test the terminals on the switch and another style where you have to test it at the wiring harness. In either case the method for testing the switch is the same. If a wiring harness is used, separate the two pieces of the harness and test the side of the harness that connects to the switch. Test the switch for continuity using a multimeter. Set the multimeter to the ohms setting X1. Place a probe on each terminal. The multimeter should display a reading of infinity. Depress the button on the lid switch and the reading should change from a reading of infinity to roughly zero. If it does not pass both of these tests, the switch should be replaced.
Some lid switches also have a fuse, you can visually inspect the fuse or test it for continuity with a multimeter. If the fuse is bad, replace it with one of the same rating.
If the lid switch is operational, i would move on to the next possible issue. This will be the motor coupler.
Washers with a direct drive motor have a motor coupler instead of a belt. The motor coupler consists of three plastic disks (or tri-stars) with interlocking tabs. Those tabs can wear and break which results in slippage. The slippage causes little or no power to be transferred to the transmission. A worn motor coupling can result in weak or no movement of the agitator and spin basket. Inspecting the motor couplers requires removing the motor, which is fairly easy to do.
Remove the cabinet. Locate the motor. The pump is mounted to one side of the motor. You do not have to remove the hoses from the pump unless they prevent you from moving the pump out of your way. If you must remove the hoses, label where they connect first. To disconnect the hoses, pinch the wire clamps with pliers (or loosen the screw) and slide the clamp farther up the hose. Slide the hose off of the pump port.
There are two clips that secure the pump housing to the motor. Use a screwdriver to pry up the clips and remove the cover. Next, slide off the pump to reveal the motor. Disconnect the wiring harness from the motor, do not pull on the wires themselves. The motor typically is secured with retaining clips and bolts. Remove the bolts and use a screwdriver to pry up the clips (if present). Remove the motor.
Mounted on the shaft of the back of the motor you will find the motor coupler. Separate the three disks and inspect them for damage. If you find cracks or excessive wear, replace the coupler.
***(I would suggest to check the following while you are in the area for faults as well(((Clutch,motor,motor board,transmission))). inspect these areas thoroughly)
Ok, if all the above checks out ok and, there are no signs of damage to any of the above parts stated, this will confirm a timer control module malfunction. replace the control device(timer or control board) asap, if possible.
Posted on Sep 06, 2009
  • 5,911 Answers
Okay...this problem is commonly caused by a broken motor coupling. The washer will still be able to fill and drain, but the agitator and spin functions will not work. The tell-tale sign is also the loud rattling noise. You may also see a black powdery looking residue under the washer. This is usually caused by the bushing of the coupler breaking apart. The following link will give you guidance on how to repair this yourself:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
This is a very simple repair if you follow the step-by-step instructions. The part number is provided with the link as well. You can order on-line by going to any of the following websites:
searspartdirect.com
appliancepartspros.com
repairclinic.com
Search by using the part number I provided. All three sites offer great service and competitive pricing, so shop all three for the best price. If you do not wish to order on line, you can take the part number I provided and go to your nearest appliance parts retailer. this is a common part they should carry in their inventory. If you have questions along the way, or require additional assistance, please let me know. I hope this helps correct your washer problem.
Posted on Feb 21, 2009
The spin cycle is very noisy. What could be the problem?
hi robyn.
A washer making a loud noise during spin cycle can also be caused by a faulty drive pulley. The pulley is what the belt (if applicable to yourwasher) rides on to spin your washers tub. The pulley can be made of plastic or metal. It could be simply worn out or just loose.27 Jul 2015
How To Fix A Washing Machine Making Noise During The Spin Cycle ...
https://removeandreplace.com/.../washing-machine-making-noise-during-the-spin-cycle-...
or try this link might help you.
washing machine spin cycle is very loud Google Search
Nov 18, 2017 | Washing Machines
Know when clutch going bad
Needs agitator dogs in agitator.
Mar 13, 2014 | Whirlpool Washing Machines
Will not spin. Makes an loud noise like its trying to spin but doesn't...
Could you please describe the problem you are having a little better?
Nov 24, 2012 | GE WJSR2070B Top Load Washer
Final spin won't go through... makes a squiky noise and no high speed spin
first how old is your machine. second is it under warranty? third have you tried to spin in all selections to see if your timer is working?
Dec 12, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore 90 series dryer makes noise and does not want to turn. I can make it spin by hand holding the door switch in, grab it and spin it, and get it to spin again. It keeps doing the same thing when
Your motor is worn out. Bearings worn and not enough power to start it. Motor is not repairable it must be replaced or new dryer. Sorry
May 20, 2009 | Kenmore Dryers
Tub makes loud thumping noise when spinning
Good morning! It's common to hear a loud thumping noise during spinning because the load (clothes) are not properly place in the tub. Please try to put the load in order & compress it down. best regards.
May 02, 2009 | Washing Machines
My front load lg model #wm2277hw will not spin, it tries to but just makes noise. At first it started washing and I went back a few minutes later and it had stopped with the code le. I did not have many...
I am having the same problem, and am getting it fixed today. It has to do with the hub, which is on the back of the motor. You can try to tighten the bolt on the hub. Take off the back of the machine and tighten the bolt. If that doesn't work, you need to call a repair man because it can ruin the groves inside the hub making it necessary to replace it.
Apr 25, 2009 | LG WM-2277HW Front Load Washer
Kenmore makes whining noise as it tries to spin
The drive coupling has probably broken. Usually happens when you overload the machine. Easy fix. READ MORE
Jan 21, 2009 | Kenmore 24902 Top Load Washer
Loud noise when it spins
Sounds like main drum bearing noise, try turning the drum by hand, if it feels rough or you can hear it grinding or rumbling, then it is the the main bearings that have failed..
You will probably need to call an engineer.
Dec 03, 2008 | Washing Machines
Washer wont spin
is it draining ok or does it m ake any noises as if trying to spin?
Mar 05, 2008 | Zanussi F1045W Front Load Washer
Kenmore 22422 Top Load Washer Logo
159 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
